Drivers seat memory setting
Discussion in '3rd Gen Tundras (2022+)' started by TundraTRDman, Mar 23, 2022.
  1. Mar 23, 2022 at 3:54 AM
    TundraTRDman
    TundraTRDman [OP] New Member
    2022 Tundra Limited TRD off road Double Cab
    Having problems setting the memory position for the drivers seat. Followed the procedure in the manual and it will work a time or two then stop working all together. The seat will retract when I turn the engine off but will not reposition when I get back into the truck and start the engine. Not sure if I’m doing something wrong. Anyone else experiencing this problem?
  2. Mar 23, 2022 at 4:26 AM
    Dick Proenneke
    Dick Proenneke New Member
    Dick
    2022 Toyota Tundra Limited
    Tonneau, 3M, Tires
    I had the same problem. Make sure you go into the screen settings and link your key to you profile. If that's been done, then the seat neats to be calibrated sorta. Move the seat, all the way forward to max, then all the way back to max. Move the seat back all the way forward to max, then all the way back to max. This fixed my problem, after a month of losing my mind. This process is supposed to be done at the factory, or dealer, but sometimes it doesn't happen. Let me know if it works.
  3. Mar 23, 2022 at 5:43 AM
    TundraTRDman
    Thanks! I'll give it a try.
  4. Apr 15, 2022 at 5:12 PM
    cephasiii
    cephasiii New Member
    2022 Tundra 1794 4x4 in Midnight Black and Rich Cream Leather
    Toyota Integrated Dashcam Rough Country Tri-fold Hard Tonneau cover
    did the recommended solution solve your problem?
  5. Apr 15, 2022 at 6:31 PM
    TundraTRDman
    No. I'm waiting until my 5000 mile service to have the dealer look at it. Are you having a similar problem?
  6. Apr 15, 2022 at 7:24 PM
    cephasiii
    No, I think my seats are good. Still getting use to the tech and I seem to fidget with the settings each time I am in the truck.
  7. Apr 22, 2022 at 5:22 PM
    catalac
    catalac New Member
    Argh mine do this won’t hold memory setting…
  8. May 16, 2022 at 6:35 PM
    AZRC
    AZRC New Member
    2022 Limited TRD
    Same here. Garbage. Can't wait until they get hit with a lawsuit because the steering wheel was too far away for someone to reach it causing a crash.
  9. May 16, 2022 at 8:56 PM
    Yoda21
    Yoda21 New Member
    Hayward ,ca
    2022 limited Trd crew max
    The steering wheel pulls out if u try to move it up and down. Also my seat works fine lol I did was set up the key and then set the chair old set then hold number one til he dings. Also on the stereo u can set it up to push the chair all the way back when u turn the truck off
    stilesja and 22PlatWCP like this.
  10. May 17, 2022 at 8:08 AM
    loeky
    loeky New Member
    Ok - this annoyed me for weeks now and finally figured out the real solve to this via a youtube video about another Toyota model. Essentially the seats were not 'prepped' at the dealer and should do the following:
    1. Run front seat all the way forward
    2. Run seat all the way backward
    3. Run seat all the way up
    4. Run seat all the way down
    Then set location of your preference. Press SET. Press #1 or #2 as you prefer.
    Seems basic, I know. It seems this creates boundaries of the seat in space for the computer to then memorize your preferred location. I followed the manual probably 50 times to no avail - not realizing this set up should have already been completed prior to delivery.
    Also, don't forget about the 'half' or 'full' setting for the seat to pull back upon stopping of - this is in the settings via the steering wheel.
    Hope this helps others as it's a neat feature and was really frustrated myself.
  11. May 17, 2022 at 11:08 AM
    nodak67
    nodak67 New Member
    JR
    lol this sounds exactly like my procedure on the passenger side mirror not remembering its tilt down setting that i resolved in this thread
    https://www.tundras.com/threads/recalls-warranty-completed-today.106912/#post-2756106
    PNW Tundra Mike likes this.
  12. May 17, 2022 at 11:18 AM
    loeky
    loeky New Member
    Yeah - that tilting mirror feature is cool on its own and didn't realize how it worked until learning about it on this forum. Really nice to turn off as well in case you need more visibility when backing up.
    Hella Krusty likes this.
  13. May 23, 2022 at 12:42 PM
    stilesja
    stilesja New Member
    2022 Tundra Platinum Supersonic Red
    Thank you, Thank you, Thank you! I've had the truck for 4 days and I kept setting it and it would work until I came back to it after it being off for a while. When I pressed the memory seat button only the steering wheel would adjust. I'm pretty sure this fixed it because now the button recalls everything. I thought I was going to have to go back the dealer. I guess my dealer didn't go through everything when setting up the truck, because I noticed the tire pressure was 44psi also, which probably should have been lowered down to the recommended 35psi before I took delivery as well.
    TK1979 and loeky[QUOTED] like this.
  14. May 23, 2022 at 1:27 PM
    nodak67
    nodak67 New Member
    JR
    44-46 psi is truck carrier setting.
  15. Sep 2, 2022 at 11:28 AM
    Jabba the Slut
    Jabba the Slut New Member
    Black 2010 Tundra Platinum
    forzamrit and cephasiii like this.
  16. Sep 4, 2022 at 8:14 AM
    Upordown
    Upordown New Member
    22 Capstone Supersonic Red
    Thanks guys fornthe thread and responses. Like some other himes and warnings, I had accepted this beep as my destiny and was annoyed with seats not moving back to its memory position.
    I followed the steps on the thread an now ... Beep is gone and the memory function works as well!!
    THANK YOU!
    PS- This came right on time as well, doing Iowa to NY trip this weekend as well!
  17. Oct 7, 2022 at 9:21 PM
    Max713
    Max713 New Member
    I followed all the advice in this thread, still no luck. Anyone else having persistent problems?
  18. Dec 14, 2022 at 9:36 PM
    samigh408
    samigh408 New Member
    I do have a same problem on my 2022 tundra
    Please, someone can make any video and share it with us
  19. Dec 15, 2022 at 5:34 AM
    Limited 23SC
    Limited 23SC New Member
    2023 Limited
    I must have a good dealership. When i took delivery they showed me how to set the seat and it worked the first time. The side mirrors tilting when put into reverse is pretty awsome.
  20. Dec 18, 2022 at 9:16 PM
    paladinkc
    paladinkc New Member
    KCMO
    2022 Black Platinum
    Sorry for the late response ... had exactly the same problem ... took in in for service ... they found that the seats had not been 'initiated' before delivery. Not sure who should have done it .. factory or Dealer ... but after they did their thing ... fixed.
  21. Dec 21, 2022 at 12:58 PM
    Quick_23TundraPlat
    Quick_23TundraPlat New Member
    2023 Tundra Platinum MGM
    Westcott Lift AVS/Rear Air, 35/12.5/18 Toyo Open Country AT3, Method 305 NV 18x9 (+18 Offset), Extang Solidfold 2.0 Tonneau
    Hi all — had this same issue on my 2023 Tundra Platinum. The seating needed to be reset prior to me setting the memory. Here is a great tutorial video for resetting Toyota seats... it worked on mine and is a bit more thorough than the other videos I found on the subject. Try resetting your seats prior to doing what the Owners Manual says to set the memory. Here is how I reset my seats:
  22. Feb 12, 2023 at 2:52 PM
    DarthFisher
    DarthFisher New Member
    Omg, I was losing my mind... glad the Tundra forum was here to help. Was finally able to set my seats and the horrible beeping when moving the seat is gone, thanks all!
  23. Feb 12, 2023 at 3:06 PM
    jsf343
    jsf343 New Member
    jeff
    soon 2023 toyota TRD pro
    Does TRD pro’s have this feature or only higher trims?
  24. Mar 31, 2023 at 12:42 PM
    JTPRO
    JTPRO New Member
    Jordan
    2023 Solar Octane TRD Pro
    I have a pro and have not been able to get my seat to recall using the buttons after my wife drives it. I turned off the easy in and out feature because I felt I did not need it. I am going to try this, front, back, up, down, thing this weekend and see if it works. Ill report back. Thanks to all who have helped.
  25. May 13, 2023 at 9:59 AM
    Kepaniamekolea
    Kepaniamekolea New Member
    Kendall
    Kailua-Kona, HI
    2022 WCP 1794 TRD Off-Road
    Still gotta try this but hope this works. Been driving me crazy trying to figure this seat out. Is it just me seeing the written instructions, but this kinda took me back to up, up, down, down, left, right, left, right, B,A, B, A, select, start.
  26. May 15, 2023 at 9:20 PM
    MrKABC
    MrKABC Not so new Member
    Art
    Corona, CA
    2023 Mesquite 1794 TRD OR Hybrid
    Miller Cat Shield, Sumo Springs Blue, Diode Dynamics Stage Series hidden light bar.
    This video was legit! This is coming from someone that hates YouTube videos.
    In a nutshell:
    • Ignition ON.
    • Seat all the way forward. Hold button for one second after seat travel reached.
    • Seat all the way backward. Hold button one second.
    • Seat all the way up. Hold button for one second.
    • Seat all the way down. Hold button for one second.
    • Seat recliner all the way forward. Hold button for one second.
    • Seat recliner all the way backward. Hold button for one second.
    • Adjust Seat how you want it. Press SET button, then "1" or "2" within 3 seconds.
    You should be good to go! And that's the video content. It worked for me! Thanks for posting it.
    TundraDan723 and PNW Tundra Mike like this.
  27. May 18, 2023 at 9:28 AM
    vegask
    vegask New Member
    Kurt
    Northern NV
    2023 Tundra SR5 Premium
    Tossing a dumb question in here. Where are the seat memory buttons at on the 3rd gen? My SR5 appears to be lacking this feature which is something I just now noticed and now I regret not getting a higher trim level. Wondering if it can be added after the fact.
  28. May 18, 2023 at 9:30 AM
    nodak67
    nodak67 New Member
    JR
    they are on the drivers door. the cost of the replacement door panel, guts and then the seat replacement is going to be hella $$$ if you go oem. not to mention the wiring.
  29. May 18, 2023 at 9:55 AM
    vegask
    vegask New Member
    Kurt
    Northern NV
    Thats what I was afraid of. Oh well.
  30. May 18, 2023 at 9:58 AM
    raylo
    raylo not so new member
    Frederick, MD
    I am in the same boat... have all the option packages for my SR5 and was more than a little surprised at this omission, TBH. I looked briefly into retrofitting this and the switch assembly is only ~ $90, but you also need a very $$ seat computer... and I am not sure that the necessary wiring and connectors are present in the door panel and under the seat to connect to in the first place. I am hoping someone who has access to the real schematics can suss this out for sure or that someone else (besides me!) takes one for the team and tries it.
