Driver's side rear brake noise
Discussion in '1st Gen Tundras (2000-2006)' started by Weagle, Feb 27, 2025.
  1. Feb 27, 2025 at 7:41 PM
    Weagle
    Weagle [OP] I survived my timing belt change
    Prattville, AL
    2006 Tundra SR5 DC 4.7 2WD LSD towing pkg
    Bilstein 5100's with 2883's - close to 2" Replacing the 2883's and going back to the bottom perch ASAP -mobile/apple play stereo with sub and backup cam -Power stop HD front calipers and rotors for towing -20" wheels with 32" tires (305/50's) Toyo AT 3's with no rubbing -Westin nerf bars -Detroit axle new (not rebuilt) steering rack with poly bushings, inner and outer TRE's -Suspension Maxx extended front sway bar links -Overland tuning - medium level -Power front leather seats and steering wheel from 06 Sequoia -fully de-chromed/blacked out trim -all light housings incl 3rd brake light and tag lights replaced with smoked lenses, LED where appropriate -mini projector headlights -fully rebuilt trans and new torque converter -new complete drive shaft with spicer u-joints and carrier bearing -all LED interior lights including backlighting -new lower window seals for all 4 doors -all new hardware and clips for tailgate Next: Dirty Deeds racing exhaust with LT headers, yellow box, 12 hole DD fuel injectors, redo or replace door panels
    This started after I replaced my rear brake wheel cylinders. I used new Toyota OEM Those sumbitches are so much heavier duty than any other wheel cylinders I remember rebuilding in passenger cars years ago
    for what it's worth replacing these wheel cylinders and properly bleeding the brakes including LSPV corrected the mushy feel I had on the brake pedal. I had previously let the shop put the new Power Stop heavy duty for towing calipers, rotors, pads, and brake shoes on. Also a full brake fluid flush
    And I had a good road test when I went on a trip with three adult friends a few hundred miles away A ladder fell off of a truck in front of the 18 wheeler in front of me and I hit to hit them hard and was very pleased. That's the first I've really had to get on them that hard since I put the new 305/32s so I was expecting worse performance and was going to do the Lexus brake upgrade in the future. I'll still probably do the upgrade, but I'm satisfied for now
    anyway, now I've got this squeak at slow speeds only on the driver side
    https://youtu.be/RAgS80pVSRI?si=iV4e6lrlKehWHvkR
    also, it doesn't do it consistently, but it does do it over half the time
  2. Feb 28, 2025 at 7:23 AM
    I hear a rhythmic creak, is that what you're talking about?
    Weagle[QUOTED][OP] likes this.
  3. Feb 28, 2025 at 7:25 AM
    Weagle
    Prattville, AL
    Yes, I should've found a better example of it but a rhythmic creak that happens most but not all of the time as you're flowing down below about 15 miles an hour
  4. Feb 28, 2025 at 7:28 AM
    Is it the driveline rubbing the carrier bearing
  5. Feb 28, 2025 at 7:29 AM
    I have a similair creak, but not rhythmic, it happens when releasing the e-brake, that similar creak/groan noise. I never thought about what it could be, but I've experience that in virtually every truck I've ever owned or driven with drums since my very first truck, an early 80s GMC S15 4cyl/manual damn near 40 years ago now. I just chalked it up to the springs bucking or similar.
  6. Feb 28, 2025 at 7:30 AM
    Weagle
    Prattville, AL
    This is normally much louder than what is in the video. I just happened to catch it when I was making the video for the potential axle wrap issue. Loud enough to be very annoying
