Driveshaft pulled out of transmission
Discussion in '2nd Gen Tundras (2007-2013)' started by georgewade, Aug 24, 2024.
  1. Aug 24, 2024 at 4:10 PM
    georgewade
    georgewade [OP] New Member
    2013 Tundra SR5
    So I got stuck in the sand today and it took some good hard yanks to get me out. Upon driving away I heard a clunking noise coming from the driveline and discovered this. Any advice on what to do from here? My truck is currently parked and I don’t plan on driving it. Just looking for some answers on what exactly needs to be done.
  2. Aug 24, 2024 at 4:17 PM
    TILLY
    TILLY Gently Used Member
    Massachusetts
    2019 MGM TRD Sport D/C
    How did they pull you out of the sand, what did they attach to?
    FrenchToasty likes this.
  3. Aug 24, 2024 at 4:42 PM
    Cruzer
    Cruzer Wheeling Full Size
    Cruz
    Sunnyvale, CA
    There WAS a C-clip that held the splined shaft in place from within the transmission but now it’s loose somewhere in the transmission. You’d have to open it up to retrieve it and place a new one on. Might as well rebuild the transmission since you have to take out practically everything just to get to the splined shaft.
    Pig Rig likes this.
  4. Aug 24, 2024 at 5:11 PM
    snivilous
    snivilous snivspeedshop.com
    SW UT
    300k+ Supercharged 2008
    Why wouldn't the C clip be attached to the splines still?
    rockmup likes this.
  5. Aug 24, 2024 at 5:15 PM
    FrenchToasty
    Mo
    The SoAz….. big surprise
    Bone stock
    Maybe the c clip broke? But that still doesn’t explain why the shaft was jerked on so hard
  6. Aug 24, 2024 at 5:22 PM
    snivilous
    SW UT
    I would think the C Clip would stay attached like on a CV axle. Not being able to pull the output stub without disassembling the trans sounds insane, but maybe I'm wrong. Frankly I'm surprised there's even a C Clip, I would've thought a 2WD shaft would just slide in and be the slip yoke. I agree it's wild the shaft came out, probably got yanked from the rear axle.
    My suggestion was going to be just rotate the shaft until the splines realign and shove it in, and if that's not possible due to it coming up short then the leafs are bent.
    mayan, Jowett, des2mtn and 1 other person like this.
  7. Aug 24, 2024 at 8:07 PM
    georgewade
    2013 Tundra SR5
    I was pulled from the front shackles
    I was pulled from the front shackles.
  8. Aug 24, 2024 at 8:23 PM
    I feel like there’s more to this story
  9. Aug 24, 2024 at 8:29 PM
    georgewade
    2013 Tundra SR5
    It recently put a 6 inch lift on my truck. I also installed a carrier bearing drop kit. I was told my the alignment shop that I had installed my rear lift blocks backwards and that it could cause problems with my leaf springs down the road. That’s really all the info I left out.
    KNABORES[QUOTED] likes this.
  10. Aug 24, 2024 at 8:34 PM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    The story is his drive shaft did not feel ready for a baby just yet
  11. Aug 24, 2024 at 8:34 PM
    TILLY
    Massachusetts
    Did any of your rear-end get damaged/bent during the pullout?
    KNABORES likes this.
  12. Aug 24, 2024 at 8:35 PM
    snivilous
    SW UT
    Can you take a photo of the carrier bearing and rest of the driveshaft? More photos the better for troubleshooting.
  13. Aug 25, 2024 at 4:09 AM
    This makes it all make more sense. I would definitely revisit the suspension work done in the back. Something has probably gotten pulled out of position due to the lift install.
    NewImprovedRon likes this.
  14. Aug 25, 2024 at 5:10 AM
    bfunke
    bfunke Tundra Curmudgeon
    South Carolina
    Photos of entire driveshaft, rear axle and leaf springs needed.
  15. Aug 25, 2024 at 5:58 AM
    rockmup
    rockmup New Member
    Todd
    Greenwell Springs LA.
    The exploded view of the tail shaft/housing doesn't show a "C" clip. Sadly I can copy the image.
    Something moved in the rear, thats the only way for that to happen.
    Jowett and KNABORES like this.
  16. Aug 25, 2024 at 6:28 AM
    centex
    centex New Member
    That could snap the pins on the springs and cause the axle to shift. Something got seriously jacked because driveshafts don’t pull out for no reason.
    des2mtn, KNABORES and Leo's first like this.
  17. Aug 25, 2024 at 6:39 AM
    Those lift blocks generally have some correction built into them for the change in pinion angle. So the block is more like a wedge. Installing them backwards not only fails to correct for pinion angle change, it actually takes the problem and makes it worse. Definitely need to correct those blocks.
    texasrho83 and NewImprovedRon like this.
  18. Aug 25, 2024 at 7:14 AM
    Jowett
    Jowett New Member
    North Adams, MA
    2011 Regular cab long bed 5.7 Work Truck Package
    Many on the way.
    The lift effectively lengthens the distance between the trans/axle. Then the blocks allowed massive axle wrap, which then caused the already overextended slip joint to travel past the slip limit.
    Hbjeff and centex like this.
  19. Aug 25, 2024 at 7:22 AM
    texasrho83
    texasrho83 DGAF#1
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Bingo.
    Do a block delete altogether.
  20. Aug 25, 2024 at 9:10 AM
    Cruzer
    Cruz
    Sunnyvale, CA
    You are correct, there is no C clip. The female end inside the housing is attached to all of the planetaries and what not. This male end that the drive shaft attached to does slide in.
    reywcms likes this.
  21. Aug 25, 2024 at 9:53 AM
    georgewade
    2013 Tundra SR5
    Here’s some more photos.
  22. Aug 25, 2024 at 10:51 AM
    centex
    centex New Member
    Maybe it’s just me but that carrier bearing looks bent upwards towards the rear.
    ZappBrannigan likes this.
  23. Aug 25, 2024 at 10:59 AM
    huntertn
    huntertn New Member
    Tennessee
    2008 White CrewMax Limited 4x4
    Carried bearing also looks all chewed up on top.
    First thing I would do is get those blocks swapped around the way they should be. The pinion angle has to be off in relation to the transmission output.
