Drum backing plates rusted out
Discussion in '1st Gen Tundras (2000-2006)' started by Dunk, Dec 2, 2021.
  1. Dec 2, 2021 at 9:32 AM
    Dunk
    Dunk [OP] New Member
    Michigan
    2001 White TRD SR5 V8
    Hi everyone,
    My tundra has some pretty bad corrosion on the rear drum backing plates:
    Has anyone else run into this problem? OEM parts are rather hard to find and expensive from what I’ve seen.
  2. Dec 2, 2021 at 9:59 AM
    Jack McCarthy
    Bill
    North of Boston
    02 Tundra AC SR5 V8 4x4
    I don't usually say this, but that's worse than mine.
    HAL69000, w666, Punk1974 and 2 others like this.
  3. Dec 2, 2021 at 10:23 AM
    rock climber
    rock climber New Member
    2001 Sequoia 4X4, 2000 AC 4X4
    I had a different issue on the sequoia with the wheel bearing and it's a $200 part plus labor so I bought a rear axle from a junkyard for $100, been going for 20,000 miles with no problem. It's not the full rear axle and diff, just the axle that slides into the diff.
  4. Dec 2, 2021 at 10:44 AM
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    You'll have to pull the axle to replace them, then press out the studs. It wouldn't be hard, but if you can't find just the plates you may have to get axles.
    Punk1974, Jack McCarthy and des2mtn like this.
  5. Dec 2, 2021 at 11:32 AM
    Jack McCarthy
    Bill
    North of Boston
    bmf4069 likes this.
  6. Dec 2, 2021 at 2:24 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    I bought all the parts for the V6, backing plates, brakes, parking brake, bearings, seals, and all. Had a local mom/pop shop do the install. Charged me about $450. Well worth the money to me.
    Punk1974, w666 and bmf4069 like this.
  7. Dec 2, 2021 at 11:28 PM
    NickB_01TRD
    Nick
    KY
    01 Tundra V8 4X4 AC SR5 TRD
    I know you posted recently that your diff cover was rusted and needed replacement and now your backing plates are rusted too. At what point does it make sense to just find a whole used replacement axle and start fresh? That or just buy a new replacement "bare" axle and swap over internals and replace wheel bearings and backing plates. Definitely the pricier way to go about it but would give you a fresh start.
  8. Dec 3, 2021 at 9:24 AM
    HAL69000
    HAL69000 New Member
    2004 Double Cab 4WD
    Had the same thought. Thanks, thread poster!
  9. Dec 3, 2021 at 12:22 PM
    rock climber
    Does the backing plate come off without removing the bearing and ABS ring?
  10. Dec 3, 2021 at 4:30 PM
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    I'm pretty sure you have to unpress everything.
    Punk1974 likes this.
  11. Dec 5, 2021 at 10:34 AM
    HAL69000
    HAL69000 New Member
    2004 Double Cab 4WD
    Hey @Dunk , look what I found
  12. Dec 30, 2021 at 1:52 PM
    nickrick78
    nickrick78 New Member
    Nick
    Pittsburgh PA
    2004 DC
    Dorman started making pre pressed axle assemblies for our trucks
  13. Dec 30, 2021 at 3:23 PM
    Richid
    Richid New Member
    And that's exactly where I ended up. After getting the plates (which were bent to hell as they just put shipping labels on them) and having to return them - I just replaced the whole axle with one from an AZ truck. Set of U-bolts, rear brakes, and some fluid was way cheaper and easier than dealing with the rusty plates and leaky housing.
