Dryer sheets for rodent damage??
Discussion in 'Other Toyota Vehicles' started by jeffw6236, Mar 5, 2024.
  1. Mar 5, 2024 at 1:24 PM
    jeffw6236
    jeffw6236 [OP] New Member
    Jeff
    San Antonio
    2019 MGM CrewMax 4x4
    Just had our 4Runner serviced 2 weeks ago. Now, this. Have stray cats prowling my driveway all night. Should’ve known why….. they could’ve done a better job. :( Good news is it is covered under my comprehension insurance… and I’ve only got a $50 deductible
    I asked the shop about deterrence and they suggested that putting some dryer sheets in the engine bay will keep them out. Just zip tie somewhere. Anyone ever hear of that?
    bulldog93 likes this.
  2. Mar 6, 2024 at 4:43 PM
    BigTrout
    BigTrout New Member
    2024 Tundra Platinum TRD Off Road
    I’ve heard that from many people but I don’t have faith in it. It’s a popular theory in my RV circles. I’ve tried it without any luck. It’s my experience that once rodents get in it becomes a constant battle.
    IMHO I think that the scents they leave behind attracts others. I would try to steam cleaning the engine compartment and treat afterwards with a spray repellent on surfaces that won’t get too hot and smell bad from the repellent.
    ….and leave a dish of milk out for those cats so they will hang around closer!
    good luck , that sucks man.
    jeffw6236[OP] likes this.
  3. Mar 6, 2024 at 8:39 PM
    Chuy!
    Chuy! New Member
    Lakeside, CA
    2007 Tacoma 4X4
    I have a friend that lives in a rural setting and rodents ate through some of the wiring in his FJ. He now keeps them out by leaving the hood open. Claims rodents will avoid and not nest in open settings. I don't recall what other measures he has taken but that is one of them. I myself use spearmint spray around sheds and fence gates. It seems to work. I still see rat poop but not as much as before I used that spray.
  4. Mar 6, 2024 at 8:50 PM
    2mchfun
    I've had good luck with pine sol soaked rags and bars of pink Dove soap wedged around the perimeter of the engine bays in both my 4RUNNER and Tundra.
  5. Mar 6, 2024 at 9:21 PM
    helidave
    helidave Hellacopter
    flagstaff
    2015 DC 4x4
    Peppermint essential oil seems to work good as well.
  6. Mar 7, 2024 at 4:12 AM
    Retired...finally
    I stuffed my new travel trailer with drier sheets when we bought it. Does it work? I guess. No mice but that may not be the reason. It's down south for the winter and north in the summer. Even when at home we are in and out of it on a regular basis.
    I used the copper chore boy scrub pad to seal off any holes that might allow entry and keep all food sealed.
    During the winter I store our Fiat 124 in the garage at home. A log home in the middle of the woods. Every year so far I see evidence of mice in the engine bay but no damage so far. Mouse poison is spread around but inside and outside the garage and every year I find at least one poison pellet under the hood when I come home in May.
    This past September I tried the peppermint oil placing oil in small pill bottles with a 1/8" hole drilled into the caps to allow controlled release of the smell. One inside on the floormat, one in the empty battery tray, one in the trunk and one on the garage floor under the car. I will report back when we get back home in May with the results.
  7. Mar 7, 2024 at 4:52 AM
    bflooks
    bflooks New Member
    Metrowest MA
  8. Mar 7, 2024 at 4:57 AM
    jeffw6236
    Jeff
    San Antonio
    Thanks for all the good ideas above. I’ve got some of the peppermint spray. I’ll try spraying under the hood and wheel wells. And maybe throw a bunch of dryer sheets inside the cab and maybe the soap. I like the pill bottle idea too. Maybe zip tie one in the engine bay just like another reservoir.
    Retired...finally likes this.
  9. Mar 7, 2024 at 5:12 AM
    Johnsonman
    Johnsonman New Member
    Austin
    Sequoia
    Are you sure mice did that? The wires are cut straight thru. When I found wires like that in my Runner, it was squirrels, one bite and its cut all the way thru, no chewing.
    I use powdered type ant poison sprinkled around my tires and just a dab here and there under hood.
  10. Mar 7, 2024 at 5:15 AM
    Retired...finally
    I like the zip tied idea. The peppermint oil I got on Amazon had an eye dropper included. This would be handy for refilling through the hole in the cap. Now it comes with a sprayer too.
    https://www.amazon.com/Peppermint-E...541-4cec-9016-f6d550369643&pd_rd_i=B00QVNKSA2
    jeffw6236[QUOTED][OP] likes this.
  11. Mar 7, 2024 at 8:25 AM
    jeffw6236
    Jeff
    San Antonio
    I’m not sure exactly what it was. I even wondered if it could be cats or another animal like a skunk - we do have one that wanders by every few days - or something. I’ve heard of squirrels chewing them up. We don’t have any squirrels so I know it’s not that. No visible droppings to help ID. But the hood liner is all chewed up so rodents make the most sense - but I don’t know that it’s definitive.
  12. Mar 7, 2024 at 8:48 AM
    coldcanuk
    coldcanuk New Member
    2021 Tundra Platinum
    Did you check your cabin air filter just to be safe? I'm sure it's fine.
    I bought some little steel cups with screw tip lids, drilled holes in the lid, and put foam on the inside. I put some peppermint oil in each one and they have a magnet on the back. One on each side of the engine bay. Not sure if it works, no trouble yet. Rodents......
  13. Mar 7, 2024 at 8:51 AM
    PKFan
    PKFan my pronouns are (she/it) - c'mon, say it fast
    2018 Inferno! DC SR5 4x4
    Tyger Blade running boards, Valhalla's Shield cat plates
    Bastages! I've had squirrels and mice. For squirrels, I used rat snap traps behind the front tires and got several of them before the problem stopped. I've more recently had mice or rats and tried essential oils, which did not stop them. I doubt dryer sheets will work. I've been using an ultrasonic deterrent under the hood for a couple of months and have not had any issues. I also spray bitter apple under the hood occasionally, which is supposed to deter squirrels, but, like the ultrasonic unit, it's hard to determine its efficacy other than I haven't had any issues for a while.
    Several of us have also added screening to help prevent cabin intrusion as detailed here. Rule #1 for the cabin is no food left inside.
  14. Mar 7, 2024 at 9:33 AM
    ENOK
    ENOK New Member
    Paul
    Adirondack Mountains, NY
    2000 SR5/AC/TRD BLACK 4X4
    I have used a ultrasonic determent to protect my corvette sitting in the shop all winter.
    I have two of them, one for the cabin and one for under the hood. The noise it makes
    has worked perfect for many years. Both of mine run off a small wall wart power supply.
    Pau;\l
  15. Mar 21, 2024 at 9:33 AM
    Hummer
    Hummer New Member
    2023 Tundra CrewMax Limited 10K miles
    Studs Baby, Studs!
    I believe that dryer sheets have worked for me. In the past, mice have entered the cab where I found nests in the heater and ducts, and in the engine air filter box. I found mouse droppings on the engine valve cover, set three traps and caught three deer mice the next morning. I sealed the engine air boxes on the '03 Tundra, '85 pickup, and '17 Highlander with metal screen. I cleaned the ducts, and the carpet/upholstery with an water extraction cleaner/rug doctor. This is to reduce the urine attraction, and because hantavirus is deadly.
    So, I tie fresh dryer sheets throughout the vehicles every 3 months, and haven't noticed a mouse problem in the 3 years since.
  16. Mar 21, 2024 at 9:46 AM
    clownkillerloaf
    clownkillerloaf New Member
    Logan
    '21 SR 5.7
    i used dryer sheets till they made a nest with it :rofl: we live out in the sticks, so we'd occasionally hear scratching in the ceiling. Put out poison packs and it stopped overnight
  17. Mar 21, 2024 at 10:50 AM
    Lifer
    Lifer New Member
    Vince
    2000 Ltd 4x4 2008 SR5 4x4 LB 2021 SR 4x4 LB
    Fab tech on the 2000
    I use dryer sheets in all my classic cars that sit around more than they should-they do work. The mint pack deterrents as well in RV compartments etc. My daily drivers I generally don't have an issue with and I am in rural foothills. Between the snakes here and my efforts, I am not seeing evidence like I use to of mice.
  18. Mar 21, 2024 at 10:53 AM
    TRDPRO.TX
    TRDPRO.TX @trdpro.TX on Instagram
    2024 TRD PRO TUNDRA
    2023 Dodge Demon 170
    Nothing a pack of coors and a .22 cant solve. Just leave out wet cat food and sit outside for a night. If you got a lady y'all can make it a date!
    Lifer and BigTrout[QUOTED] like this.
  19. Mar 21, 2024 at 12:22 PM
    BigTrout
    BigTrout New Member
    Hell yea! Im in!
    “Shoot the rodents, not my truck Orville! You blind SOB!”
  20. Mar 22, 2024 at 7:21 AM
    Lifer
    Lifer New Member
    Vince
  21. Mar 22, 2024 at 7:36 AM
    trilrunner
    trilrunner New Member
    2024 Tundra Platinum Lunar Rock
  22. Mar 22, 2024 at 8:37 AM
    2mchfun
    I'm not sure it's wise to consider all poison effective immediately. I've literally seen a mouse running around for several hours on top of about 2" of poison pellets inside of a bucket. During that time, much damage could be done. Furthermore, who wants poison particles coming out their dash vents? Yes, I know there's plenty of toxins in the air already. Just things to consider.
  23. Mar 22, 2024 at 8:43 AM
    trilrunner
    The bait stations are next to my trash cans which is also close to where I park. It's definitely not immediately effective but works to keep the population of rodents under control. Under the hood, I put the botanical/herb deterrent. Hopefully, both do enough to put the odds of it happening again very low.
    2mchfun likes this.
  24. Mar 22, 2024 at 8:46 AM
    Hugemoose
    Hugemoose New Member
    David
    Philly
    2016 Tundra Crewmax
    Not enough....
    I have had issues in the past, and I still get mice in my garage no matter what. My best course of action is a 5 gallon bucket trap for the little bastards. It's not very ethical, but it's incredibly effective. A ramp up against the wall, a bottle with PB in the center on a cut clothes hanger, and water in the bottom. Example picture from the internet below, but mine looks very much the same.
