Durobump spacer question…
Discussion in '2.5 Gen Tundras (2014-2021)' started by Oey12, Sep 6, 2022.
  1. Sep 6, 2022 at 1:24 PM
    Oey12
    Oey12 [OP] New Member
    Joey
    New York
    2020 SR5 TRD OFFROAD
    In the next few days I am purchasing Durobumps for the front of my 2020. I currently have .5 thick Coachbuilder top hat spacers that provides about an inch of lift (driver/passenger side). I want to install the Duro’s to get A better dampening and B stop my shock from potentially bottoming out and breaking.
    I emailed Durobump who recommended a 1/2 inch spacer.
    I was going to purchase a fat aluminum spacer?.?. Or should I stick with steel or something else… I just want it to be strong enough to absorb the forces and not corrode terribly in NY winters.
  2. Sep 6, 2022 at 1:25 PM
    14burrito
    14burrito IG @14burrito
    2014 SR5 CM 4x4 5.7
    Go to home depot, buy some stock, drill a hole and paint it
    Oey12[OP] likes this.
  3. Sep 6, 2022 at 1:26 PM
    snivilous
    snivilous snivspeedshop.com
    SW UT
    300k+ Supercharged 2008
    It's a spacer in pure compression, it could be made out of plastic and probably be fine. I would do aluminum or stainless steel. It could literally be stacked washers even.
