Easy to verify if catalytic converters are stock or been replaced?
Discussion in '2.5 Gen Tundras (2014-2021)' started by dadtrucklife, Jul 9, 2024.
  1. Jul 9, 2024 at 11:23 AM
    dadtrucklife
    dadtrucklife [OP] New Member
    2021 SR5 TRDOR 4x4 (Army Green)
    I am in the market for a used 2nd gen and one of the areas I plan to check are the catalytic converters. Is it easy to tell if they’re stock or been replaced? Maybe certain welds or brackets to look out for? Pictures would be super helpful too.
  2. Jul 9, 2024 at 3:44 PM
    Saltyhero13
    Saltyhero13 Throbbing Member
    Their might be a quick way to visually verify stock cats.
    The easier approach is to look at a stock set up.
    off vehicle:
    dadtrucklife[OP] likes this.
  3. Jul 9, 2024 at 3:47 PM
    Saltyhero13
    I don't know if there are any aftermarket functional cats that look identical. A common complaint here is most nonperformance aftermarket cats don't run well and will usually throw codes sometimes sooner than later. If you have a code scanner you can scan the code history to see if you see any cat related codes.
    RobertD likes this.
  4. Jul 9, 2024 at 5:48 PM
    JaxJacket
    JaxJacket New Member
    21 DC
    Pray tell, how did you get the driver's side off without cutting? I wiggled every which way until I gave up.
  5. Jul 9, 2024 at 10:27 PM
    Saltyhero13
    Lots and lots of lube. Turn the lights down low....
    In all seriousness, not my pics my friend. Second was posted by @dirtydeeds on a different Tundras forums. He might be able to answer your question.
  6. Jul 16, 2024 at 3:18 PM
    luxury4play
    luxury4play New Member
    any of the aftermarket ones wont look near the same as the OEM ones. One for sure thing is to look at the exhaust hanger.
