Electrical Gurus Wanted: Power Folding Mirror issue
Discussion in '2.5 Gen Tundras (2014-2021)' started by TundraPJ, Jul 19, 2020.
  1. Jul 19, 2020 at 8:58 PM
    TundraPJ
    TundraPJ [OP] New Member
    JP
    DFW, Texas
    '19 SR5 TRD Off-Road
    Fox TRD Pro Shocks BFG KO2’s Dirty Deeds 14” BAMF n-fab nerf bars
    I have a 2019 SR5 and installed power folding tow mirrors earlier this year. Followed the instructions and write ups referenced on this and other forums. Things worked great for a few weeks.
    Over time, they’ve started working intermittently. My mechanical skills far surpass my electrical skills, so over the last few months I’ve been trying to pattern the issue in hopes of discovering a fix, but I’ve exhausted my abilities with regard to electrical systems.
    The variable with the highest correlation to working vs. having issues seems to be temperature. In the cooler months right after install they were working great. a
    As temperatures started to warm up issues began. Now that it’s summer and my truck is parked outside, my mirrors work less than 25% of the time during the day (sometimes driver or passenger will work, sometimes neither, other times they’ll both open/close halfway). I can usually partially depress the fold button on the switch to get them to open/close fully, but sometimes it’ll take several tries to get it done.
    Even now though, at night when temps are cooler, the mirrors work 99.99%, if not 100%, of the time.
    I don’t know enough about electrical systems to know what could be susceptible to heat causing issues. I’ve tried two different switches (one from Amazon and one from eBay, haven’t tried a true OEM switch). All connections/splices seem to be solid.
    I’d appreciate any ideas or suggestions!
    - JP
  2. Jul 19, 2020 at 9:28 PM
    tttrdpro
    tttrdpro Former Naval Person
    SWGA
    2024 GMC 2500 AT4
    In progress…
    It’s obviously a problem with a high resistance connection. I would double check and triple check every connection involved. You will find the problem if you do so.
  3. Jul 19, 2020 at 10:13 PM
    MGMTundra251
    MGMTundra251 New Member
    2020 Platinum 4x4 MGM
    When I swapped power folding mirrors on my 2017 SR5, I had intermittent problems with the folding operation. I tried to wiggle the connector and it would work some time. That tells me that my pins were not making proper connection. I went with aftermarket pins that just didn’t fit right. Anyhow, I finally bought oem pins from Roman and that fixed all of my issues.
    timdske likes this.
  4. Jul 20, 2020 at 5:08 AM
    TundraPJ
    JP
    DFW, Texas
    Thanks for the responses. I’ll go back and check the connections and see if wiggling gets them to move. I did have a connection problem right after install and found the pin that wasn’t seated right by messing with the wires going into the mirror. Maybe there are other connection issues that aren’t as obvious.
  5. Jul 20, 2020 at 4:10 PM
    chrisbusnut
    chrisbusnut New Member
    Pasadena, CA
    2020 Tundra Crew Max SR5 4x4 w/TRD Off Road pkg
    DiamondBack bed cover, SDHQ sliders, SwitchPro, Katzkin leather seats, TRD Pro grille, TRD Pro wheels w/Nitto Ridge Grappers, Toyota OEM leather steering wheel, SSO Slimline Hybrid Bumper w/Baja Designs S8 light bar, Warn Zeon Platinum 10-S winch, Baja Design rock lights & flush mount rear bumper lights
    I'm having the same issues, and just ordered the OEM pins from Roman. Hopefully that solves the problem.
  6. Jul 20, 2020 at 6:59 PM
    thomasbus337
    thomasbus337 New Member
    2020 TRD Sport DC
    Are these just crimp on terminals or the pins with a short piece of wire? I’m not having issues here yet but want to be prepared just in case
  7. Jul 20, 2020 at 7:05 PM
    chrisbusnut
    Pasadena, CA
    According to Roman, it’s a pin with a short piece of wire. I will try to remember to post photos when I receive them.
