Energy Suspension - Control Arm Bushings 1st Gen!
Discussion in '1st Gen Tundras (2000-2006)' started by NWTundra11, Aug 15, 2018.
  1. Aug 15, 2018 at 8:30 AM
    NWTundra11
    NWTundra11 [OP] New Member
    http://energysuspension.com/Product-Updates.html
    Just talked to these guys about 1st Gen Tundra/Sequoia Lower Control Arm bushing options. Basically was hoping that something would cross over, or be close enough.
    What I was told, was that they are, FOR THE FIRST TIME, this year rolling in a tundra to start developing poly bushings for (previously only offered steering rack set based on same P/N as other toyotas). They start with the oldest models and work forward as their business model is to only build for a purpose, not just to replace for the sake of replacing.
    Long story short is that possibly in the next 6 months we could see some poly bushing sets for these trucks. AND if we reach out to them and tell them that there is a need for these parts it might help.
    Shoot them an email and tell them how stoked you'd be to buy a set of control arm bushings rather then risking buying some shitty rockauto set, OR worse spending $400 for a set at the dealer - hyperflex@energysuspension.com
  2. Aug 15, 2018 at 4:00 PM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    I'm down with that, I'm rebuilding my whole front end next month and the only part I'm leaving alone is the lower arm bushes. If they make some bushes that work well with the alignment cams I'll buy immediately.
    Jflor484 likes this.
  3. Jun 4, 2019 at 10:35 AM
    tvpierce
    tvpierce Formerly New Member
    Maine
    Any developments on this?
  4. Jun 22, 2019 at 2:08 PM
    DRABNOR
    DRABNOR New Member
    RJ
    Temecula
    00 Tundra 4x4
    Tons
    StrongMerlin likes this.
  5. Sep 14, 2019 at 8:52 PM
    StrongMerlin
    StrongMerlin New Member
    2000 Tundra SR5
    thank you for this info. I need to replace my lower control arm bushings. Found this thread and it has change everything for me. Thanks!!
  6. Sep 14, 2019 at 9:08 PM
    Scuba
    Scuba Sober member
    Austin, Tx.
    2012 Texas Edition CM.
  7. Sep 14, 2019 at 11:55 PM
    SoCalPaul
    SoCalPaul New Member
    Paul
    San Fernando Valley, CA
    2006 Tundra Access Cab Limited 4wd.
    Front Bilstein 6112 shocks & Bilstein springs. Rear Bilstein 5160 remote Reservoir shocks, Wheeler’s Off-road add-a-leafs. LED lighting. Pioneer Avic 7200NEX Nav Head unit. Borla cat back exhaust.
  8. Sep 15, 2019 at 1:20 PM
    StrongMerlin
    2000 Tundra SR5
  9. Sep 15, 2019 at 2:44 PM
    SoCalPaul
    Paul
    No, I don’t know anyone running them, but I liked the fact that they had the bonded metal parts.
    tvpierce likes this.
  10. Sep 15, 2019 at 9:52 PM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    My big question is, does anyone make poly body mount bushings for these trucks? Mine took a little tumble and I’m sure those took a beating when the cab was upside down for that second before it landed on its right rear bedside then rolled again and hit the drivers front wheel...
    theblurry1 likes this.
  11. Sep 16, 2019 at 4:12 AM
    tvpierce
    Maine
    That's interesting. I've used poly bushings on other vehicles, but have never seen them offered like this with a metal sleeve. These are considerably more expensive than the Daystar set, but may be worth it. I'd be interested to get some real world feedback on them.
  12. Sep 16, 2019 at 6:50 AM
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    Ok, so this brings up questions. I have TPR bushings everywhere I can, solid AL subframe bushings, and solid motor mounts in my car to stiffen things up. But why would you need poly bushings in a truck? It doesnt need to stiffen up, and a lot of people just d/c the swaybar when offroading anyways. So wouldn't looser rubber bushings be better?
  13. Sep 16, 2019 at 7:46 AM
    tvpierce
    Maine
    Poly is stronger/more durable.
  14. Sep 16, 2019 at 10:54 AM
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    So it's more about wear resistance, not stiffening? But would it not also stiffen things up? I'm not really knowledgable in all the 4wd mods, I come from a car background.
  15. Sep 16, 2019 at 10:59 AM
    empty_lord
    05 rollover special
    It stiffens things up. Body mounts make a noticeable difference. Steering rack bushings. Leaf spring, it all helps tighten up the feel of the truck. I prefer rubber lower control arm bushings off-road though. When I had them on my taco it did make the ride a bit rougher offroad
    theblurry1 and bmf4069[QUOTED] like this.
  16. Sep 16, 2019 at 9:19 PM
    02goes
    02goes New Member
    2002 Tundra Limited 4X4
    So, poly bushings last longer but give a stiff ride whereas OEM rubber bushing give a smoother less rough ride, and both cost relatively the same.
    For the smoother ride and lasting to somewhere around 200,000 + miles I go for the rubber. For me the trks used for regular everyday boring street driving and a few short tows each month. With the poly bushings you will feel every bit of the road like you do in a sports car, and to me that becomes annoying and tiring on long drives.
    OEM rubber bushings for normal street driving should last 15 to 20years of comfortable driving before needing replacement, and that's a good deal when comfort is priority.
  17. May 5, 2022 at 9:18 PM
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
