Engine runs rough when cold. No check engine light.
Discussion in '1st Gen Tundras (2000-2006)' started by MS22, Apr 25, 2020.
  1. Apr 25, 2020 at 10:47 AM
    MS22
    MS22 [OP] New Member
    02 Tundra 4x4
    A couple weeks ago my truck started running rough when it was cold, didnt think much of it because it wasnt too bad. About 50-60 miles later it has become worse, almost where the truck will barely take off. It gets a lot better after the truck warms up, almost running perfect but still a little miss in the engine. I wasnt worried thinking it would throw some codes and I can start from there but none have come up, no check engine light. I did hook up my Obd reader to see if there were any codes but none came up. Truck has 217,000 and T belt was changed @ 198,000.
    I pulled all plugs they look like they are all firing no gunk build up. The gap was around .40 so regapped them to .31 as it states in the owners manual. Put 15 gallons of fresh premium gas, cleaned the MAF sensor, checked all vacuum lines and cleaned the throttle body but has made no difference.
    Before I start throwing parts at this, fuel filter, coil packs etc... I was wondering if anyone else had a similiar problem and point me in the right direction. I do appreciate all the help and advice.
  2. Apr 25, 2020 at 5:37 PM
    PCJ
    PCJ New Member
    State of Jefferson
    2004 DC Limited 4X4
    Lift, Rims, Bigger Tires, Nerf Bars, Black Out Emblems
    If the plugs were worn to. 040 my first thought is how many miles are on them, what brand and type.
  3. Apr 26, 2020 at 10:36 AM
    Filthyphil
    Filthyphil Lions Not Sheep
    Phil
    2000 Toyota Tundra TRD 4.7
    Run some fuel injector cleaner too
    NewImprovedRon and MS22[OP] like this.
  4. Apr 26, 2020 at 11:45 AM
    BENWALES
    BENWALES New Member
    Ben
    2020 Tundra White SR5
    Replace the plugs and run a can of Seafoam p/n SS14 through it.
  5. Apr 29, 2020 at 8:28 AM
    MS22
    02 Tundra 4x4
    Not sure how many miles are on the plugs but Im going to change the fuel filter today, if the problem is still there I will change out plugs.
    Thanks
    I usaully run Top tier gas in it so I would think that the injectors would be clean. I guess it wont hurt to run a can of BG44k through the system.
    I thought about the seafoam but I heard it was bad for your catalytic converters.
  6. Apr 29, 2020 at 8:44 AM
    Rex Kramer
    Rex Kramer Vinyl Spinner
    Georgia
    I've been using SeaFoam in my oil & gas since the mid 90's, it has never caused a problem - it only solves / prevents problems.
    BENWALES likes this.
  7. Apr 29, 2020 at 8:44 AM
    MS22
    02 Tundra 4x4
    I never have used seafoam but I have read that it can clog up your cats with all of the carbon and gunk that the Seafoam cleans off. Thats what I have read but never tried the stuff myself. I might try it if the filter and plug change doesnt work out.
  8. Apr 29, 2020 at 8:52 AM
    SouthPaw
    SouthPaw The headlight guy
    2000 Limited 4x4 AC
    Sounds like you've done all the obvious stuff so I would move on to the not so obvious.
    As cheap/easy as they are to replace, I would do the plugs and fuel filter. I'd also test/check your charging system (battery cable tighness/cleanliness and alternator). I had some weird issues with mine doing a rough cold start and actually dying and once I replaced the negative battery cable, it runs like a top. The next item on my list was going to be fuel pump but mine has been great ever since. Here are the threads of me chasing it down:
    https://www.tundras.com/threads/slight-hesitation-while-stopped-sometimes-dies-when-starts.54963/
    https://www.tundras.com/threads/occasional-crank-no-start.57039/
    TTund16 likes this.
  9. Apr 29, 2020 at 5:09 PM
    MS22
    02 Tundra 4x4
    Thanks, I checked the negative cable and grounds and all looks good. My alternator was charging at 13 something volts so it's fine. Replaced the fuel filter, same problem but now she finally threw a code. Shows misfire on #6 so I need to do a little homework and see how to check that coil with my multimeter. Oh and might as well get new plugs.
  10. Apr 29, 2020 at 5:33 PM
    SouthPaw
    2000 Limited 4x4 AC
    These coils are known for cracking. Again, as as easy as they are to work on, swap #6 coil to a different cylinder and see if it misfire follows. Also inspect them.
    tvpierce and MS22[OP] like this.
  11. Apr 30, 2020 at 11:32 AM
    MS22
    02 Tundra 4x4
    Pulled out #6 (on left) which the code indicated misfire and # 4 (right), defintely a discoloration on the #6 boot and plug. I see I can buy a replacement boot for $7.00. Would just a bad boot cause a misfire, or should I just buy a brand new oem coil from the dealership for $90.00?20200430_113032.jpg 20200430_113032.jpg
  12. Apr 30, 2020 at 12:57 PM
    SouthPaw
    2000 Limited 4x4 AC
    Replace the plugs and swap the #6 coil to cylinder #4. If the misfire follows, you know you have a coil problem.
    Are there any cracks along the coil? Here is an example:
    Filthyphil, NewImprovedRon and PCJ like this.
  13. Apr 30, 2020 at 1:39 PM
    MS22
    02 Tundra 4x4
    I read through your thread awesome to see you got your truck up and running.
    The coil looked good no cracks just the boot had discoloration. As you mentioned I swapped the coil to #4 and for some reason it's finally throwing me codes. Now it shows misfire on #4. I just went ahead and ordered a new Denso coil and plug, should be here tomorrow. Hopefully this fixes the missfire. :fingerscrossed:. Out of curiosity I'm going to take off the new boot and put it on the old coil just to see if that would have fixed the problem.
  14. Apr 30, 2020 at 1:55 PM
    SouthPaw
    2000 Limited 4x4 AC
    Sounds like you are on the right track!
    Wild guess but maybe the boot discoloration is from the coil arcing through it and causing it to get hot/light colored.
  15. Apr 30, 2020 at 2:48 PM
    MS22
    02 Tundra 4x4
    You could be right. I just switched over boots on the coils and it still pulls up misfire on #4, so I answered my own question lol. The boot had nothing to do with it looks like a bad coil.
    Just got the new coil in and she runs like she used to.:yes:
    Appreciate the help :thumbsup:
  16. May 2, 2020 at 5:08 AM
    Professional Hand Model
    Hand Protectors
