Engine Vibration at high RPM & at Idle
Discussion in '3rd Gen Tundras (2022+)' started by BDATundra, Aug 5, 2024.
  1. Aug 5, 2024 at 4:21 PM
    BDATundra
    BDATundra [OP] New Member
    Bob
    2024 1794 Edition 4x4 (non-hybrid)
    None - yet...
    Wondering if someone can duplicate my issue. I have a new 24 Tundra 1794 (non-hybrid). Love the truck. Have less than 1000 miles on it. At about 700. The other day while sitting idle following at 20 minute highway drive, I punched the accelerator to about 4-5k. I did this 3 times and each time, upon releasing peddle, I had a significant engine vibration. Makes me worry. Is that normal? Thanks for any insight.
  2. Aug 10, 2024 at 12:20 PM
    BDATundra
    Bob
    None - yet...
    Bump…
  3. Aug 10, 2024 at 12:42 PM
    SWB Tundra
    SWB Tundra New Member
    T
    Cenral Arkansas
    2024 Tundra Platinum 4x4 CM Hybrid
    Don't know I don't do mine that way. Have no reason too. If it still drives normal and that is only time it does that when rev it up in park. I wouldn't do it.
    BDATundra[OP] likes this.
  4. Aug 10, 2024 at 1:19 PM
    Lee.M
    Lee.M New Member
    TN
    24tundra limited 4x4
    Level/35s
    If you’re punching the gas pedal in park. You are hitting the rev limit at 4k it will shake.
    nodak67 and BDATundra[OP] like this.
  5. Aug 10, 2024 at 1:21 PM
    BDATundra
    Bob
    None - yet...
    Thanks. I won’t do it anymore! Drives fine. No other vibrations.
    SWB Tundra likes this.
  6. Aug 10, 2024 at 2:00 PM
    SWB Tundra
    T
    Cenral Arkansas
    I didn't know it hit rev limiter at 4000. I learned something. But, it doesn't do it while engine is under load.
    BDATundra[QUOTED][OP] likes this.
  7. Aug 10, 2024 at 8:03 PM
    Lee.M
    Lee.M New Member
    TN
    Level/35s
    In park your revs are limited to the 4k “ish” When in drive the rev limit is at its normal limit.
  8. Aug 10, 2024 at 11:41 PM
    MadMaxCanon
    MadMaxCanon New Member
    '21 CM SR5 4x4 6 seater
    Too many, but not enough....
    My old ranger did this too. It's so you don't blow your engine being stupid or if your accelerator gets stuck somehow or something. Actually one of the safety features in cars I think makes sense lol
  9. Aug 12, 2024 at 6:53 AM
    mayan
    mayan One pull a day keeps the engine debris away.
    Mayan
    DFW
    2023 SM Tundra Limited
    There’s a soft limiter at 4-5k rpms in Park truck will keep the waste gates open so you can’t build boost. The shaking at limiter is normal and has to do with the slight give from the motor mounts as your engine speed rapidly changes.
  10. Aug 12, 2024 at 7:14 AM
    BDATundra
    Bob
    None - yet...
    Thanks so much!!
