Error codes: C1331 and C1465 (Pre-Collision System Malfunction...)
Discussion in '2.5 Gen Tundras (2014-2021)' started by Zaoka, Jan 13, 2025.
  1. Jan 13, 2025 at 9:08 AM
    Zaoka
    Zaoka [OP] New Member
    Tundra 2020 SR extended cab
    Tundra 2020
    This error occurs intermittently, turning on and off. I’ve seen many threads, but nobody is posting a solution. I checked the wires from the left ABS sensor to the control module using a multimeter. I tried moving and stretching the wire, and it’s not loose. The ABS sensor costs around $500—is that a common problem?
    What else should I check?
  2. Jan 13, 2025 at 3:00 PM
    blanchard7684
    blanchard7684 New Member
    Check connector on the radar “plate” at front of vehicle.
    I had this same issue and the connector was loose.
  3. Jan 13, 2025 at 3:58 PM
    Tundra family
    Tundra family New Member
    /\ this. I've also had crud caked up on the sensor cover (emblem) and have had the same thing. I get it coming and going for what seems like no reason, but my grill has taken a hit so I just assumed something is misaligned or whatever. It usually goes away with a restart so I haven't given it much thought
  4. Jan 14, 2025 at 4:26 AM
    blanchard7684
    I must admit… it was my fault. I took connector loose when doing the genuine cooling system transmission cooler install. I thought I pushed it together.
    playing around with the grill off I noticed I could reliably repeat the same error message.
    I pushed in connector and heard auditable click.
    that was two years ago with no issues since.
    so it may be the case that it is a loose connection somewhere in that part of circuit just based on past experiences.
    Tundra family[QUOTED] likes this.
  5. Jan 18, 2025 at 1:20 PM
    Zaoka
    I hit that camera location above the rear view mirror with hand and its working now.. so looks like there is something wrong, its been ok for 2-3 days.
  6. Jan 27, 2025 at 6:33 AM
    Zaoka
    Error is back...
  7. Jan 27, 2025 at 7:43 AM
    moredogs
    moredogs New Member
    i get this periodically along with the trailer/towing warning, always at the same time. For lack of a better fix or taking it to a shop, I just disconnect the battery for a few minutes to make it go away.
  8. Jan 27, 2025 at 9:12 AM
    Tundra family
    Have you had the windshield replaced? When they did mine they had to recalibrate something in that system
