Exhaust Manifold replacement/upgrade
Discussion in '1st Gen Tundras (2000-2006)' started by Splashbrother13, Mar 11, 2022.
  1. Mar 11, 2022 at 12:51 PM
    Splashbrother13
    Splashbrother13 [OP] New Member
    Aaron
    AZ native
    2000 SR5 Tundra
    Currently looking into addressing the exhaust manifold leaks on the 340k+ Tundy.
    Originally my thought was to swap for new OEM manifolds/gaskets but recently I’ve been looking into upgrading to some jba headers and possibly upgrading to a cat-back muffler system as well. Main priority is making it reliable for the future, but getting some extra horseys would be cool.
    Ive been browsing JEGS for some JBA shorty headers I read recommended on another forum.
    https://www.jegs.com/i/JBA/578/2010S/10002/-1#reviewTab
    Would adding a Cat-back duel system add or take away from overall performance and reliablity? Thanks.
  2. Mar 11, 2022 at 1:13 PM
    frichco228
    frichco228 Valued Member
    2016 Crewmax 4WD, TRD Offroad
    I would contact @dirtydeeds, has lots of experience with headers and exhausts for tundras
  3. Mar 11, 2022 at 1:38 PM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    I installed jba shorties in 2009, not a single problem with them. They will discolor if you don't get a coated option, I can't say how well the coated options stand up because I went with raw.
    I've also had a custom cat back since 2009, no problems there either. If you want a little sound just get a good muffler and swap the big stock muffler for what you like, keep as much of the stock pipe as you can since it is well made. Some mufflers will drone pretty bad in these trucks. If you have the stock resonator you might want to keep it there to prevent drone at low speed.
    FrenchToasty likes this.
  4. Mar 11, 2022 at 2:54 PM
    Splashbrother13
    Aaron
    AZ native
    2000 SR5 Tundra
    Thinking about wrapping the jbas in fiberglass header wrap if anything
    Looking into some Borla, Magnaflow and Jba options for muffler/tailpipe. All I’m really looking to replace unless my Cat goes bad
    Also seeing lots of flowmaster and Gibson options
  5. Mar 11, 2022 at 3:24 PM
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    I ran a Flowmaster and it had a lot of drone but admittedly it was dumped before the rear axle. Whatever you run you want to have the piping run all the way out from under the truck.
    I replaced that with a Spintech Pro Street and haven't heard a better muffler yet on these trucks. They're a little bit loud outside but inside the truck it's quiet. I don't even have a resonator anymore, just shorties, stock cats, y pipe, a little muffler and stock piping.
  6. Mar 11, 2022 at 3:28 PM
    FrenchToasty
    Mo
    The SoAz….. big surprise
    Bone stock
    Is that where or why they drone? Is it the reverb back and forth between the under-bed and the road?
  7. Mar 11, 2022 at 3:37 PM
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    It usually makes things worse. If the exhaust is dumped under the truck the sound waves will be emanating under the truck rather than away from the truck. With the sound hitting the ground and reflecting there is a stronger chance of resonance getting amplified, kind of like when you drive into a tunnel and your exhaust gets louder. That can hit your cab and cause a lot of headache.
    Two things that will help avoid drone are to have the exit out from under the truck, and keep the stock intake airbox. Intake gets super loud on these trucks with a cone filter. The sound frequency of the intake can match the frequency of the exhaust and cause a weird sound wave. If you ever see somebody tune a guitar by ear, plucking a note on one string and hitting the same note on the other to balance the sound, its the same concept.
    All that said, my truck has the section of pipe where it bends to go behind the rear wheel cut off. The exhaust still escapes my truck once I'm driving.
  8. Mar 11, 2022 at 3:44 PM
    FrenchToasty
    Mo
    Bone stock
    Thanks for the explanation.
    I had originally wanted my exhaust dumped out of the rear fender pre tire, but that presented it self to be to difficult so I’m dumped down and back past the axle, maybe one day I’ll get back under and see how or where else I could route/extend the tubing to
    Darkness[QUOTED] likes this.
  9. Mar 11, 2022 at 5:57 PM
    Splashbrother13
    Aaron
    AZ native
    2000 SR5 Tundra
    So ideally exiting just below the rear bumper instead of bending out & exiting just past the passenger side rear wheel?
  10. Mar 11, 2022 at 6:53 PM
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    Either would be good, as long as the pipe can carry the exhaust out from under the truck.
  11. Mar 11, 2022 at 7:09 PM
    gascap
    gascap New Member
    2002 Tundra
    Did someone already say shorty headers do nothing for added HP, but long tube headers do. Duel exhaust is good and running straight off headers is best. Someone did mention Borla or Corsa muffler system. Those two have good sound with personality to me, and not the boring red neck loud mufflers that all others are. Slow moving stock vehicles with loud mufflers are plain stupid. I have no idea if the 4.7 has enough oomph to create the sound those are known for. Both Borla and Corsa have 0 drone. You'll get nominal/insignificant hp with headers and dual mufflers, and it stays the same with aftermarket cold air intake added to them on any stock run of the mill engine. The OEM TRD muffler system is quite but puts out a good tone when stepping on it. These motors don't have aftermarket cams that add horse power nor have I heard of someone doing a dyno tune. Those are two items to look for for if around and can be done. They marry well with dual exhaust, aftermarket intake and long tube headers. Throw the correct torque converter in there with limited slip and your done with the around town daily driver fun stuff. To me the gearing is already right for all around driving.
    Splashbrother13[OP] likes this.
  12. Mar 11, 2022 at 7:23 PM
    RR60
    RR60 New Member
    2003 SR5 Tundra long bed
    If I could add. Is this still true.
    I remember reading that one problem is you would not be able to replace one of the 02 sensors if you changed to headers and had the need in the future.
  13. Mar 11, 2022 at 7:54 PM
    Isn't @empty_lord the one to ask, pretty sure he's done it and general consensus is you can throw all the upgrades in the world you want at the engine shy of forcing induction (FI/SC) and you'll be lucky to net a 30-40HP gain?
  14. Mar 11, 2022 at 8:35 PM
    Ghostly.-
    Ghostly.- Tragic.
    Mitchell
    Montana
    Cams are $2,000, and should only be done if boosted IMO. Dyno tuning ATM can only be done with a standalone or piggyback like the MAP-ECU on mine, at least until VF tuners gets to our ecu(they just added support for 4runners with vvti 2uzfes)
    5N0W808 likes this.
  15. Mar 11, 2022 at 8:36 PM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    Shorties will add something (anything’s better than the god awful factory manifold design.) but long tubes will be the most potent. Past that proper exhaust design will dictate if you will gain or lose power. It’s an art to extract the most power out of a exhaust on N/a engines.
  16. Mar 12, 2022 at 11:26 AM
    Fish River Tundra
    Fish River Tundra New Member
    JD
    Nashville
    ‘16 Platinum
    Keith told me that wrapping the headers will promote them rusting. I have a set about to be installed
  17. Mar 13, 2022 at 3:33 PM
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    K&N barks. I loved using mine to scare pedestrians.
  18. Mar 13, 2022 at 3:51 PM
    empty_lord
    05 rollover special
    Yea header wrap is notorious for rotting out manifolds. Coated headers help with heat and d protection
    5N0W808 likes this.
  19. Mar 13, 2022 at 6:14 PM
    gascap
    gascap New Member
    2002 Tundra
    $2000 for cams! Is that the current inflation price or what they'll be by the end of next week. That price is crazy. I looked for cams and found none.
    Who makes them? Are they for the Tundras before the VVTi came out? Would like to look into that.
  20. Mar 13, 2022 at 6:16 PM
    empty_lord
    05 rollover special
    the price for 4 billet cams is usually in the 2-3k range. has been for years. regrinds are cheaper. but billets are far superior
    XAT racing sells the cams. vvti and non vvti i believe. high lift and a less aggressive. the high lift requires pocketing of the head.
    gascap[QUOTED] likes this.
  21. Mar 13, 2022 at 6:17 PM
    Ghostly.-
    Ghostly.- Tragic.
    Mitchell
    Montana
  22. Mar 13, 2022 at 6:18 PM
    empty_lord
    05 rollover special
    high lift for sure. the mid lift likely would end up with a respectable gain. but you'd want to be spinning a little more RPMs with a proper tune
    wish someone would post a dyno graph of these suckers.
    gascap likes this.
  23. Mar 14, 2022 at 4:33 AM
    gascap
    gascap New Member
    2002 Tundra
    5N0W808 likes this.
  24. Mar 14, 2022 at 6:04 AM
    912
    912 @best_gen_tundra
    Fulltime RV traveler
    2005 DC 4x4
    Great videos! I love how the Turbo Tundra has the gas light on during the "Freeway Fun" portion of the vid - very relatable! :rofl:
    Darkness likes this.
  25. Mar 14, 2022 at 10:41 AM
    Splashbrother13
    Aaron
    AZ native
    2000 SR5 Tundra
    Even with the shorties?
    just swapped all my O-2s , looking to pass emissions
  26. Mar 21, 2022 at 10:25 AM
    Splashbrother13
    Aaron
    AZ native
    2000 SR5 Tundra
    Just received some JBA shortys
    Thinking about getting some OEM gaskets for the swap
    Is getting a y-pipe recommended?
  27. Mar 21, 2022 at 3:45 PM
    Ghostly.-
    Ghostly.- Tragic.
    Mitchell
    Montana
    While the factory Y pipe looks really restrictive, from what I've heard an aftermarket doesn't yield any performance gains.
