Exhaust size before tip?
Discussion in 'General Tundra Discussion' started by Iowa12tundra, Apr 10, 2020.
  1. Apr 10, 2020 at 7:14 AM
    Iowa12tundra
    Iowa12tundra [OP] New Member
    2012 tundra crew
    I've been searching around and message a member about the size of our stock exhaust. I know the tip is 3 inches but what about when you go back to the standard size before it expands at the tip? I want to order a new tip and cut out the existing tip. I've seen people mentioning 2.75, 2.5 and 2.25. :help:
  2. Apr 10, 2020 at 9:15 AM
    Iowa12tundra
    2012 tundra crew
    This is what I was thinking of getting.
    https://www.ebay.com/itm/372786390536
    I came across reviews of people not being happy with tail pipe changing colors or getting black coated pipes that don't hold up. I figured if I need to spruse up the tail pipe I can easily take it off. I just want to know the size of the exhaust system before it goes to the stock tail pipe. I guess I can chop it off and go from there but I figured people on this forum would know. Have a good weekend tundra dudes and dudettes!
  3. Apr 10, 2020 at 2:17 PM
    Tundyfundy
    Bay Area, CA
    Magnetic Grey DC SR5 4x4 2016
    SUSPENSION: Bilstein 6112 coilover (1.9") w/ Powder Coated Springs and Spring Perch (TRD Red), JBA Upper Control Arms, Bilstein 5160's w/Billet Aluminium Reservoir Brackets, +2 Coachbuilder Shackles, Diff Drop Kit, Carrier Bearing Drop Kit, Brakeline Extensions, ABS Extension, Poly Bushings for Leafs, Coachbuilder Shims (2 Each Side), Coachbuilder Bumpstop Extensions, TRD Rear Sway Bar, TRD Front Sway Bar, Air Lift 5000 airbags w jounce bumpers, Daystar Airbag Cradles WHEELS AND TIRES: BF Goodrich KO2's 275/70/r18, BORA wheel spacers 1.25", TRD Wheel Caps,TRD Valve Stem Caps, Spare Tire Lock PERFORMANCE: Bullydog GT Tuner(Performance Tune), TRD Intake, TRD Dual Exhaust (with Modified Exhaust Hangers for Levelling Tail Pipe),TRD Brake Pads, TRD Oil Cap (US), TRD Radiator Cap, TRD Oil Filter, Optima Yellow Top Battery,GP Battery Distribution Blocks, StopTech Slotted Cryo Treated Rotors, Goodridge G-Stop Steel Braided Brake Line Kit PROTECTION: PNP Engineering Type 4 Rock Sliders (With Full Dimple Plate) ,ADD Stealth Fighter Rear Bumper w Red/Blk Shackles and Custom Stomp Pad, TRD Skid Plate with ReadyLift Spacer Kit, Victory 4x4 LCA Skid Plates, JOMAX ABS Sensor Armor, Rear Diff Breather Mod, ARK splash guards INTERIOR: Husky Liners X-Act (Front and Full Coverage Rear and Front Weather Beater Trans Hump), Interior LED Bulbs, WheelSkins Genuine Leather Steering Wheel Cover(EuroPerf), Clazzio Genuine Leather Seat Covers(BLK/DRK GRYwith custom stitching and embroidered headrests), Clazzio Seat Heaters (Front and Rear), Entune Startup Screen MOD, Entune Off Screen Mod, Tinted Windows with Windshield Visor, AJT Key Fobs,Eagle Claws Floor Mat Clips, Bodyglove Visor Organizer,Custom Door Cup Inserts, Glass Break Sensor,AJT Radio Knobs, Custom Dior Cup Inserts EXTERIOR: Full Debadge, LED Brake Light Bulbs, LED Rear Turns, LED Reverse, LED Plate Lights, LED Cargo Lights, LED Third Brake Lights, LED Front Marker Lights, LED Fog Light Bulbs, Lamin-X Fog Light Covers (Amber),2018 OEM LED Headlights, iHacker harness, VLED Universal Puddle Lights, VLED Interior Footwell Lighting (Front and Rear),VLED Extreme Amber Fornt Turns, NSV Knight Rider Light bar, Baja Designs Sport Squadron Pods in Rear Bumper (Driving/wide), Painted Red Tow-hooks, Bed Rail System, Blind Spot Mirrors, Hitch-safe, Tail-gate lock, EAG Raptor Grille, Custom Grille Badge,Full Vinyl Wrap (Matte Black/Matte Pine Green Mettalic), Charvonia Designs Tie Bed Tie-Downs, Bull Ring Bed Rail Anchors, Line-X, Tundra Bed Mat, Bakflip F1 Bed Cover SOUND: Noico 80Mil Sound Deadening and Noico 170 Mil Thermal Insulation (All 4 Doors, Roof, Floors, Rear Panel, Dash). Hertz Uno K170's Component Speakers (Front Doors with Upgraded Sail Panels), Hertz Uno K170 Coaxial Speakers (Rear Doors), JBL C1-075ct Tweeters (Total 4) in Side Dash and Center Speaker, JBL Stadium 5 Amp w/Remote Bass Adjustment Knob and Amp Rack, 12" Infinity Reference Subwoofer in Custom Enclosure w/ “TUNDRA” Logo, Fast Rings Foam Speaker Rings System(4 Doors), Fix 86 DSP
    Bump
    I cut up and tossed my factory exhaust but hoping someone will chime in.
    Iowa12tundra[OP] likes this.
  4. Apr 10, 2020 at 2:19 PM
    canadianguy
    canadianguy New Member
    Kevin
    Lloydminster Alberta
    2017 SR5 trd off-road
    All the usual stuff!
    It’s 2.75”
    Iowa12tundra[OP] and Tundyfundy like this.
  5. Apr 10, 2020 at 2:22 PM
    canadianguy
    Kevin
    Also the chrome Toyota tips for the newer Tacoma is 2.75” too
  6. Apr 10, 2020 at 2:28 PM
    dpast88
    dpast88 New Member
    Dennis
    Furlong, PA
    2015 Tree
    I agree with 2.75” but it just barely worked for me. With the clamp as tight as it would go I still needed an exhaust shop to throw tack weld on. I think it varies from truck to truck. I wish I went with a 2.5” in hindsight.
  7. Apr 10, 2020 at 3:17 PM
    Iowa12tundra
    2012 tundra crew
    Thanks for replying back! Have a good Easter
