Extang Encore Tonno
Discussion in 'Tonneau Covers, Caps and Shells' started by reequatro, Jul 6, 2017.
  1. Jul 6, 2017 at 9:34 AM
    reequatro
    reequatro [OP] New Member
    2016 Tundra 1794 TRD
    I have a new Encore cover that I installed just a couple of weeks ago. I've decided to find something that will allow me to utilize the stock cargo management system. This tonno is in perfect condition. I paid over $900. Asking $850. Shipping will be an issue, so it needs to be local pickup in the Dallas, TX area.
  2. Mar 31, 2018 at 10:27 AM
    mart1nezdaniel
    mart1nezdaniel AZ
    Arizona
    Tundra TRD PRO 2017
    does this cover require you to relocate the existing rails?
  3. Mar 31, 2018 at 11:01 AM
    duece292
    duece292 Appalachian American
    Greg
    Green Bay, WI
    It requires removal of the rails. Unfortunately, Extang doesn't offer a clamp solution that works with the cargo management system. A guy could certainly fab something to drop the rails down. That's what BAK does but they do it with an aluminum plate and it's kind of flimsy.
  4. Mar 31, 2018 at 11:05 AM
    mart1nezdaniel
    mart1nezdaniel AZ
    Arizona
    Tundra TRD PRO 2017
    Does anyone make or sell rail relocation brackets for these types of covers?
  5. Mar 31, 2018 at 11:08 AM
    sr5shark
    sr5shark Shop smart. Shop S-Mart.
    Alan
    Walnut Creek, CA
    2016 SR5
    Fox & ADS | SCS SR8 | Nitto RG
  6. Mar 31, 2018 at 11:11 AM
    mart1nezdaniel
    mart1nezdaniel AZ
    Arizona
    Tundra TRD PRO 2017
    Sweet. Thanks for the replies.
    Are these BAK brackets stable ? Not sure i want to compromise tie-down stability for the cover.
  7. Mar 31, 2018 at 11:18 AM
    sr5shark
    Alan
    Walnut Creek, CA
    2016 SR5
    This has not been an issue for me. That said, there is some flex if I pull in the track. Instead of being bolted directly to the side, the track is connected to the 1/4" steel bracket that is bolted to the side.
  8. Jun 25, 2018 at 7:01 AM
    Smoofers
    Smoofers New Member
    N TX
    2018 TRD Sport
    Have you already programmed the lock to your truck key?
  9. Jun 25, 2018 at 7:34 AM
    deerfarmer
    deerfarmer New Member
    Just bought a 2016, I put an Extang full tilt, that's what I hat on the 07. No folding, simple to take off if you need the whole bed open
