EZ oil change valve money savings
Discussion in '3rd Gen Tundras (2022+)' started by Rockpig, Jun 4, 2024.
  1. Jun 4, 2024 at 7:14 AM
    Rockpig
    Rockpig [OP] New Member
    08 Limited
    If your thinking of getting the EZ oil change valve from Amazon or somewhere else, check this out.
    So the valve with the hose end is $40.83
    $41 EZ-103(12mm-1.25) EZ Oil Drain Valve with removable Hose End Combo
    Amazon.com: EZ-103(12mm-1.25) EZ Oil Drain Valve with removable Hose End Combo : Automotive
    The valve alone without the hose end is $21.80
    $22 EZ-103 EZ Oil Drain Valve
    Amazon.com: EZ-103 EZ Oil Drain Valve : Automotive
    The hose end is $7.62
    $8 EZ Oil Drain Valve (H-001) Straigt Hose End - 3/8" Straight, Small, Silver
    Amazon.com: EZ Oil Drain Valve (H-001) Straigt Hose End - 3/8" Straight, Small, Silver : Automotive
    So to buy them separately instead of together as a kit the total is $29.42, a savings of $11.41, use that savings to buy 3/8 hose to go on the end of the drain or better yet if you're worried about the drain lever being hit by something causing it to open get this, better than the wire ring clamp. $6.99
    $7 The Hillman Group 59737 11/16" Spring Action Hose Clamp, 12-Pack
    The Hillman Group 59737 11/16-Inch Spring Action Hose Clamp, 12-Pack - Amazon.com
    Silicone hose $5.99:
    $6 Rebower 1m(3.3ft) 10mm(3/8") ID x 13mm(1/2") OD Silicone Tubing Clear Industrial Plastic Tubing Pure Silicone Hoses for Pump Siphoning Draining Irrigation Brewing
    Amazon.com: Rebower 1m(3.3ft) 10mm(3/8") ID x 13mm(1/2") OD Silicone Tubing Clear Industrial Plastic Tubing Pure Silicone Hoses for Pump Siphoning Draining Irrigation Brewing : Industrial & Scientific
    Get these 4 items together instead of paying $40.83 for the drain and hose end together and it's $42.40, a whole $1.57 more and all you need is a pan to drain the oil into.
  2. Jun 4, 2024 at 7:29 AM
    DIYReid
    DIYReid New Member
    KC
    2024 Ice Cap Tundra Limited
    I use Fumoto valves on all my stuff. Works great. Oil change on my Tacoma was easy with the filter on top.
    Tom976, dJunior, coldcanuk and 4 others like this.
  3. Jun 4, 2024 at 7:32 AM
    eddiefromcali
    eddiefromcali New Member
    Eddie
    2022 Tundra Platinum
    100% Stock
    Same, I'll just stick with Fumoto.
    coldcanuk and machd08 like this.
  4. Jun 4, 2024 at 8:42 PM
    Sixty9Four20
    Sixty9Four20 TRD is not a trim
    2023 TuRD Pro
    I didn’t spend the money to just swap out stuff.
    But what size tube do you need for the oil filter catch thingie?
  5. Jun 4, 2024 at 9:41 PM
    Hella Krusty
    Hella Krusty New Member
    Just makes me think of a home made KEG tap lol
    Blufin and Black widow TRD like this.
  6. Jun 5, 2024 at 1:12 AM
    brhodea
    brhodea New Member
    Michigan
    '24 CM Limited
    been happy with Fumoto for years now, I'll add it to the Tundra when the dealer is done with their 2 oil changes
    coldcanuk likes this.
  7. Jun 5, 2024 at 4:20 AM
    Rockpig
    08 Limited
    I have no doubt that the Fumoto is a great unit. The post was more about saving money for those interested in the EZ unit. In reality it's a valve constructed in the same way with the only real difference being the mounting surface itself.
    The big difference between the Fumoto and the EZ unit is the inner diameter of the drain itself with the EZ unit being larger (EZ unit on right). I'm sure that doesn't make much of a difference but when isn't bigger better sometimes?
    bulldog93, Black Wolf and Woocawachie like this.
  8. Jun 5, 2024 at 8:49 AM
    904garys
    904garys New Member
    Gary
    2024 Tundra SR5 Doublecab
    Once installed, does its length protrude inside the oil pan, thus possibly not allowing the oil to completely drain?
    trazerr likes this.
  9. Jun 5, 2024 at 10:04 AM
    Rockpig
    08 Limited
    That I am not sure, I have not received mine yet from Amazon. Keep in mind that the oil drain is not on the bottom of the pan, it's on an angled portion, the only way to get all the oil out is to lift the truck at an angle. The drain hole on the pan has a thread pitch of 1.25mm, at most I count 10 threads on the EZ unit from looking at the amazon photos, that would equate to a hair shy of half an inch. The pan most likely has a bolt or something welded to the inside of the pan so the plug has enough thread engagement, probably not enough to make a difference.
  10. Jun 5, 2024 at 10:35 AM
    dJunior
    dJunior New Member
    CT
    already slapped mine in there- I dont think the dealership would say anything but who knows.
    For what it is worth on their website:
    Fumoto has been granted Genuine Parts status in Japan by major auto and truck companies such as; Toyota, Nissan, Mazda, Fuso, UD Trucks, and Isuzu.
    bulldog93 likes this.
  11. Jun 5, 2024 at 2:16 PM
    brhodea
    brhodea New Member
    Michigan
    '24 CM Limited
    They don't care, my son was a lube tech last winter at a local Chevy dealer, he said they would actually remove them to drain the oil because they didn't want to wait the extra minute for the oil to drain. I'm sure they don't care about if the valve safety is put back or the gasket is put back etc. I'll have it on hand to replace at my 25k mile oil change.
  12. Jun 5, 2024 at 2:26 PM
    2mchfun
    FWIW, the Fumoto has a secondary lock clip and the Valvomax is a step above both.
    mayan and ArmygreenTRD like this.
  13. Jun 5, 2024 at 11:41 PM
    ArcticFox
    ArcticFox New Member
    California
    Fair enough —it's probably better to put it in once you don't plan to let the dealership change oil anymore.
  14. Jun 6, 2024 at 3:58 AM
    dJunior
    dJunior New Member
    CT
    Yeah makes sense ill switch back to the plug at my 5k... get to take a bath on the 15 and 25k change though- ugh!
  15. Jun 6, 2024 at 3:59 AM
    dJunior
    dJunior New Member
    CT
    Fumoto does not according to their website...
  16. Jun 6, 2024 at 8:58 AM
    Tom976
    Tom976 New Member
    Tom
    I like to get the oil nicely warm (not blazing hot but up there)
    Open the drain and let it flow. While that is going on I put a hose by the catch under the filter and then start to work on getting that unscrewed. By the time you get the old filter off, new one on and clean up things the oil will be done flowing from the oil pan.
    Close it up the fumoto valve and put the extra lock on it.... you're done!
    I really dont like going to the dealers for anything. Too many stories of them taking off skid plates etc and not putting them back on correctly or at all.
  17. Jun 17, 2024 at 4:22 PM
    Ranger 1/75
    Ranger 1/75 New Member
    Justin
    2024 Limited TRD Off Road
    For those of you who have the fumoto, which model do you have? I have a F-133S I saved from my 2017 tacoma. 12mm-1.25. Will that work?
  18. Jun 19, 2024 at 5:11 AM
    Tom976
    Tom976 New Member
    Tom
    According to Fumutos website.... f133s looks like it'll work on the Tundra.
    Ranger 1/75 likes this.
  19. Jun 19, 2024 at 5:20 AM
    ocman40
    ocman40 New Member
    used the fumoto on my tacoma and now the Tundra. I just make sure the oil is warm, attach a small drain tube and put it directly in my oil recycling pan, take off the oil fill cap and go inside for a bit. No spills and no worries about leaks...
  20. Jun 19, 2024 at 6:53 AM
    2wheelsforfun
    2wheelsforfun New Member
    • I was going to say EZ drain valves are a Chinese knockoff of the Japanese Fumoto valves. Like you I run Fumoto valves on all our vehicles. I love that I no longer have to remove 6-8-12 bolts to remove a skid plate to change oil. I just leave a short hose attached to the nipple tucked up onto the skid plate when not in use and bring it down to drain oil into my drain pan. not all over the skid plate etc.
