F Load (12 Ply) rated tires
Discussion in 'Wheels & Tires' started by a_double, Dec 21, 2021.
  1. Dec 21, 2021 at 2:19 PM
    a_double
    a_double [OP] New Member
    Are they really that bad for the 2.5 Gen Tundra? I've seen references about weight but looking at manufacturers specs, a F load tire isn't much heavier. In some cases, there are F rated tires from one manufacturer on par with E rated tires of others.
    I've read the stiff side walls translate to a rougher ride as well.
    Do these need to be run at higher pressures?
    The max load my truck will see is a camp gear load plus some bikes.
  2. Dec 21, 2021 at 2:23 PM
    MadMaxCanon
    MadMaxCanon New Member
    '21 CM SR5 4x4 6 seater
    Too many, but not enough....
    It will ride rougher, how much would depend on many, many factors like what you had before, psi, weight, load. I for one am a huge fan of overkill tires. That philosophy has resulted in me never, ever getting any tire issues such as punctures or any other tire damage over 5 vehicles and 10+ sets of tires.
    AZBoatHauler likes this.
  3. Dec 21, 2021 at 2:24 PM
    AZBoatHauler
    So.Arizona
    There is no upside. There are better options no matter what you’re trying to achieve.
    And I agree with having tires rated above your use but what are the F load rated for? 5,000lb/tire?!?
    JLS in WA and FrenchToasty like this.
  4. Dec 21, 2021 at 2:25 PM
    frichco228
    frichco228 Valued Member
    2016 Crewmax 4WD, TRD Offroad
    stick with e load which is way beyond what the tundra needs. I run e load, stiffer for sure. Would not even consider running F load on a 1/2 ton
  5. Dec 21, 2021 at 2:29 PM
    AZBoatHauler
    So.Arizona
    I also run E but would be happy to go down to C if I could find them in a flavor and size I like. C rated is still overkill for our trucks but that’s how I like it…
    JLS in WA likes this.
  6. Dec 21, 2021 at 2:32 PM
    MadMaxCanon
    OP are you planning on pulling the space shuttle?
    JLS in WA and AZBoatHauler like this.
  7. Dec 21, 2021 at 2:33 PM
    a_double
    I see how the increased ply's make them stiffer but how stiff...like a car on cut springs? :)
    Can it be mitigated with compression settings on your dampers?
    From what I can tell, the common sizes run on a custom 2.5 Gens are generally overkill to begin with.
  8. Dec 21, 2021 at 2:34 PM
    a_double
    If I win that contract, sure.
    MadMaxCanon[QUOTED] likes this.
  9. Dec 21, 2021 at 2:38 PM
    a_double
    But really, the point being made about what you're pulling with your truck can be made about a lot of other mods. In some cases, mods are done for personal taste and not function. Maybe a product checks all the boxes but 1, and you're considering the trade-off.
  10. Dec 21, 2021 at 2:43 PM
    I ran 12 ply tires on my 14K rated trailer. Overkill but you could tell the difference. On my goosenecks I run 14 ply (moving up to 16 after these dry rot).
    Are you saying your camping gear and assumed dirt bikes is going to justify going to a LR J?
    I'm confused.
    I don't even run J's on my one ton. I run Load Index 124 tires. If I step up in tire size I can run the 125's. Zoom into my rear tires. They have 72 lbs in them (cold) and are barely bulging. This is pretty much max of what my truck can handle.
    Saltyhero13 likes this.
  11. Dec 21, 2021 at 2:51 PM
    a_double
    I'm saying, what's the drawback to running F load when not warranted? I've seen the weight argument. Stiffness, can that be quantified somehow? What else? Does the tire turn square if running a light load?
  12. Dec 21, 2021 at 2:51 PM
    JLS in WA
    JLS in WA New Member
    2008 White DC Limited 4x4
    Drahthaar Transport Unit
    What purpose will it serve? I wouldn’t do it.
  13. Dec 21, 2021 at 2:59 PM
    Ryuu
    Ryuu Hwat!?
    Oscar
    SouthEast, TX
    2017 TRD PRO Barcelona Red
    a few
    I run 12ply/F rated 35" tires, only cause the Milestar only makes them F rated for my 18" wheels at that size, and fill them to 33-34psi. They're not that bad honestly but you can notice a difference in ride comfort.
    If you're looking to get the most comfort then I honestly wouldn't run them, just stick to 8ply or 10ply. If you don't really care too much, I'd say go for it, especially if the price is better than other options.
    a_double[QUOTED][OP] likes this.
  14. Dec 21, 2021 at 3:01 PM
    MadMaxCanon
    Aside from weight and stiffness, cost and easy of locating tires when your in a pinch would be other drawbacks. You are essentially asking us, i know about drawbacks, but what are the drawbacks......it wont blow your truck up.
  15. Dec 21, 2021 at 3:45 PM
    a_double
    In terms of ride comfort, does it make you dodge stuff cause it’s too jarring. Jokingly, would I need a chiropractor and use a mouthpiece while driving?
    I have E loads on my 4Runner riding on Kings. They felt stiff initially but I had my compression settings closer to closed. The stiffness went away after backing off on the compression settings.
  16. Dec 21, 2021 at 4:04 PM
    Ryuu
    Ryuu Hwat!?
    Oscar
    SouthEast, TX
    a few
    Lol nah, it's not that bad, yea my suspension plays a part of it but I don't dodge anything, couldn't even if I wanted to. I'm in a refinery town, a lot of the roads out here are crap; holes, cracks, bumps, chunks gone or almost no road left.
