Factory Amp w/ JBL fuse.
Discussion in 'Audio & Video' started by tundriver, Oct 27, 2017.
  1. Oct 27, 2017 at 5:40 PM
    tundriver
    tundriver [OP] New Member
    Puyallup
    2017 Tundra Crewmax Limited
    Linex Bed Spray, Tint matched, Truck Gear tonneau cover,6112 Bilstein and 5100.Black Rhino Warlord on Nitto G2.
    Hi,
    What fuse does the factory amp uses. Put on a multi meter at the tip of the red wire I’m not getting any voltage. Head unit works except no volume(yellow bar doesn’t show up).
    Thanks
  2. Oct 28, 2017 at 5:50 AM
    MT Madman
    MT Madman Just an ordinary guy
    Hawk Point MO
    2020 Silver Platinum
    TRD dual exhaust TRD Rear Sway Bar SnugTop Hi-Liner
    Here's a schematic for a '15 and would probably match up, check out page 3 where it shows power going to the amp a 7.5A and 30A run to it, it looks like the 30A fuse. I don't know where it's at but check the owners manual. I hope it's a simple as replacing one but if it's still under warranty take it to the dealer and have them fix it.
  3. May 29, 2019 at 5:25 PM
    MMichaelJJ
    MMichaelJJ New Member
    14 Platinum CM
    Did you ever get it figured out? Mine is doing it now.
  4. Aug 30, 2022 at 3:36 PM
    2016ToyotaTundra
    2016ToyotaTundra New Member
    RW
    2016 Toyota Tundra 1794
    This just happened with my 2016 tundra as well. Did you find the solution or cause? Thank you for sharing!
