Factory Orange Peel 2019
Discussion in '2.5 Gen Tundras (2014-2021)' started by Donkeypunch, Dec 23, 2018.
  1. Dec 23, 2018 at 10:04 AM
    Donkeypunch
    Donkeypunch [OP] New Member
    I swear factory orange peel on new cars get's worse every generation. Here on a brand new 2019 Platinum Tundra has worse orange peel than my 1994 Toyota (also super white).
    Anyone else's orange peel this bad? I know robots paint the trucks but I feel like mine was painted on a Monday morning or Friday afternoon. smh. This isn't even the worst I have seen. I have seen worse orange peel on a brand new C7 vette.
    Notachickmagnet likes this.
  2. Dec 23, 2018 at 10:15 AM
    Donkeypunch
    What would the dealership do? If my truck is out of the ordinary and much worse than others, then I would build a case. Kind of the point of making this thread. If this orange peel is the norm, then I guess I am SOL, unless I take this directly with Toyota.
    Anyone else's this bad?
  3. Dec 23, 2018 at 10:29 AM
    bdpeelgren
    bdpeelgren New Member
    Round Rock, TX
    2014 Tundra CrewMax Super White
    Readylift 3/1, Rigid D-series fog lights, Supernova V.4, F/R Coverking covers.
    It’s every truck and car. The only ones I haven’t really noticed it that bad on are metallic colors.
  4. Dec 23, 2018 at 10:31 AM
    LT75
    LT75 Seasoned Pro
    Saint Charles, IL
    No mods yet
    Only thing you can do is wet sand it and respray it. But I wouldn’t have the dealer do it. Research a reputable body shop that knows what their doing.
  5. Dec 23, 2018 at 10:43 AM
    Donkeypunch
    Anyone attempt to have a detailer block it and try to correct it, with a protective ceramic coating on top? I know sanding the top clear coat would take out most of the UV protection, but hoping a good top layer of ceramic coating like opticoat pro plus would help protect it.
  6. Dec 23, 2018 at 10:57 AM
    Boerseun
    Boerseun MGM XP-Series
    Ferdie
    Sarasota Florida
    I would not do that. I bet the clear coat is not very thick and you can sand right through it. I would rather just accept it the way it is (which I have - I have noticed the same on my truck)
    15whtrd likes this.
  7. Dec 23, 2018 at 11:03 AM
    DJFaninTN
    DJFaninTN New Member
    Panama City Beach, FL
    2018 Super White 1794
    dealer is one of the last resorts I would consider. find yourself a good detail shop and let them have at it.
  8. Dec 23, 2018 at 11:21 AM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    You could wrap it. Wraps are really expensive though. I think a good shop could color sand it and shoot a clear over it.
  9. Dec 23, 2018 at 11:29 AM
    malveman
    malveman New Member
    New jersey
    2022 Limited long bed MGM
    My white sport is like a mirror my 16 1794 had the Orange peel. I know how u feel it sucks hope u find a solution
    Donkeypunch[OP] likes this.
  10. Dec 23, 2018 at 12:04 PM
    Donkeypunch
    Well, looks like it helps to know some insiders. I will try to file a claim.
  11. Dec 23, 2018 at 12:10 PM
    Donkeypunch
  12. Dec 23, 2018 at 12:50 PM
    ZPMAN
    Minnesota
    Best thing to do is to have a reputable body shop look over any new Toyota before signing the dotted line.
    Just my .2 cents
  13. Dec 23, 2018 at 1:41 PM
    da_jeep_luva
    da_jeep_luva New Member
    Paul
    2017 CM and 2008 RCSB
    TRD Pro suspension, powder coated bumpers, wheels, tires, lowered, coated, list keeps going.
    That’s compound, (heavy cut pad), Polish, and ceramic. It will still be noticeable. Might help a little, but it won’t be perfect.
  14. Dec 23, 2018 at 1:50 PM
    Blueline
    Blueline New Member
    Jeb
    Temecula, CA
    2016 Tundra TRD PRO crewmax
    Bakflip MX4
    * dealer will do nothing to correct the orange peel.
    * don’t cut and buff the factory clear; too easy to burn through.
    * ceramic will only magnify the flaws.
    The factory paint job has minimal clear, only .0015 maybe .002. THIN.
    The best you can do is go with a lighter color, and don’t look at it at an angle in the shade. I looked at a new 2019 TRD Pro in midnight black metallic, and the orange peel was really bad. Can’t see it so much from 10 feet, but get up close and it is not pretty. Skimping on paint.
    B737 and ZPMAN like this.
  15. Dec 23, 2018 at 1:52 PM
    Blueknights75
    Ron
    Clayton, NC
    Sorry, don’t have this issue.
  16. Dec 23, 2018 at 1:57 PM
    da_jeep_luva
    Paul
    Did mine without any issues. Ceramic made the truck look great. And didn’t magnify anything on my white truck.
  17. Dec 23, 2018 at 2:57 PM
    Pupule Mike
    Pupule Mike New Member
    2015 Tundra Limited Crew Max
    Mine is just as bad (Super White), seems like the truck are worst that the cars
  18. Dec 23, 2018 at 4:20 PM
    mdavis
    mdavis I need a beer.
    Michael
    Rock Hill, SC
    Be very careful if you sand and buff. Toyota super white is single stage paint.... No clear coat.
    NewImprovedRon likes this.
  19. Dec 23, 2018 at 4:20 PM
    Blueline
    Blueline New Member
    Jeb
    Temecula, CA
    Bakflip MX4
    You’re an exception. Most dealers will compare against other white trucks on the lot, find the same condition and call it acceptable. If I’m not mistaken, white is a single stage paint, and a light color sand is not as risky as two stage paint (black or mgm).
  20. Dec 23, 2018 at 8:17 PM
    Boerseun
    Ferdie
    Sarasota Florida
    You can only see it on a clean truck. I keep mine dirty; the orange peel is hardly noticable. Problem solved.
    OHwendTrd, UNTMatt and da_jeep_luva like this.
  21. Dec 23, 2018 at 11:15 PM
    da_jeep_luva
    Paul
    Your very correct on single stage and risk. From what I understand if you use a lighter pad when compounding on a darker color (two stage) paint you will get a better outcome after polish is applied.
    Orange peel will still remain until you decide to sand it down. My 08 had heavy oxidation and i was able to remove it with polish alone (test spots since I was being cautious at first) Although I still decided to compound ( heavy pad)+ polish, the FACTORY ORANGE PEEL WAS STILL THERE AFTER 10 years with the products applied. I said screw it and went with ceramic. Truck looks fine and is easy to wash.
    It boils down to what the owner is good with. Me personally I’m fine with a little orange peel. But I also can see frustration in buying a 50k truck and shits not perfect.
  22. Dec 23, 2018 at 11:50 PM
    kgb4187
    kgb4187 New Member
    If it's not on both sides it could have been damaged and repaired before being sold. I'd try to find a paint depth gauge and see what the measurements are.
  23. Dec 24, 2018 at 3:04 AM
    plumber802
    plumber802 New Member
    Andy
    Vermont
    2018 White Platinum CM
    I never really noticed "orange peel" on mine. I'll check later...
  24. Dec 24, 2018 at 3:12 AM
    astro-jason
    astro-jason New Member
    2022 CHEVROLET 3500 CC L/B Duramax 10spd
    Is it the whole truck or just the l/h side? You are going to have some orange peel on automated paint jobs "no color sanding". You can remove a lot of it by strip wash, clay bar, light compound and polish.
    Contact the selling dealer and see what they have to say, they may buck it because you already took delivery of the vehicle.
    -Jason
  25. Dec 24, 2018 at 3:19 AM
    B737
    B737 Throbbing Member
    Jersey Shore
    2015 Tundra Double Cab Limited
    This ^
    All of us will find orange peel on our garbage paint. Same for most factory paint jobs on run of the mill vehicles today, including the more expensive ones. There is nothing the dealer will do, no matter how much texting you do with them lol
    The guys saying “mines fine!” I’m willing to bet just haven’t looked with proper lighting at the right angles.
  26. Dec 24, 2018 at 5:32 AM
    Cement_Trd
    Cement_Trd New Member
    2018 Cement TRD offroad
    Cement color match (dechrome), Tyger Side steps, TRD rear sway bar, Black badging (dechrome), TRD dual exhaust
    My 2018 cement has noticable orange peel. If you walk around the dealership you will notice it on all of the trucks.
    B737 likes this.
  27. Dec 25, 2018 at 4:06 PM
    619Tundra
    619Tundra New Member
    San Diego, Caifornia
    2017 Black Tundra Double Cab SR5
    Mine has it really bad. I wish I would've noticed at time of purchase (at night). I'm thinking of wet sanding it and polishing it off. There's a huge risk of burning thru the thin single stage 202 Black paint.
  28. Dec 25, 2018 at 5:20 PM
    Cement_Trd
    If your going to have it done. I would have a very reputable body shop that has done it before take on the task. Like have them do the tailgate first or something so you can see what kind of work they do. The tail gate can be removed from the truck and worked on.
    619Tundra[QUOTED] likes this.
  29. Dec 25, 2018 at 8:58 PM
    619Tundra
    I'm in San Diego.
  30. Dec 26, 2018 at 3:24 AM
    Boerseun
    Ferdie
    Sarasota Florida
    I understand the desire to have it done, but the paint is so thin already that I would not do it. The chances of burning throught it just out weights the chances of it turning out a success.
    It would be nice if a shop could add a few layers of clear coat and then color sand that to a glass finish, but that's not feasible.
