Factory rims with 35’s
Discussion in 'Wheels & Tires' started by matth66, Dec 10, 2023.
  1. Dec 10, 2023 at 12:45 AM
    matth66
    matth66 [OP] New Member
    matt
    Nor cal
    2023 Black Tundra Trd Pro
    Wondering if any of you running 35’s on factory rims used spacers ?
    Pros/cons?
    Taikowaza likes this.
  2. Dec 10, 2023 at 4:06 AM
    Hunter1699
    Hunter1699 New Member
    Have 23 Platinum in which I kept the OEM wheels. Swapped tires with 35x11.5x20 Nitto Recons. Was going to put a leveling kit on but canceled once tires went on. Still wanted it to fit in garage. Swapped out lug nuts and center caps. Tires gave me the height/look I wanted. I had/have no rubbing but still added 1" spacers to widen stance.
    Cons: tires are 10ply so gas mileage suffers but knew that/didn't care.
    -stiffer ride but not bad in my opinion.
    -with the spacers I had to put mud flaps on for the mud sling. Will be adding Pro flares to add more protection.
    That's it and am satisfied. Had initial plans to do lift, tires, wheels but saved $$ not doing it. $$ saved will be put to other mods.
    Bryzzo, CrayCray, ARCOVT23 and 14 others like this.
  3. Dec 10, 2023 at 10:44 AM
    matth66
    matt
    Nor cal
    Right on good info. Truck looks awesome
    Hunter1699 likes this.
  4. Dec 10, 2023 at 7:11 PM
    Spakylpm
    Spakylpm New Member
    2024 Tundra
    Looks great! I was looking at those recons...
  5. Dec 10, 2023 at 7:22 PM
    Porkchop253
    Porkchop253 New Member
    2023 Platinum Hybrid
    Trd lift. Heritage grill. Painted grill surround. Ceramic tint. Bfg ko2. Leer canopy.
    Running 285-65-20 on factory wheels with a 1 inch bora spacer. I wanted it flush and the 1 inch spacer provided it
  6. Dec 10, 2023 at 9:12 PM
    Hella Krusty
    Hella Krusty New Member
    Good looking truck. Well done
    Hunter1699[QUOTED] likes this.
  7. Dec 10, 2023 at 9:39 PM
    matth66
    matt
    Nor cal
    You guys have any down the side shots?
  8. Dec 11, 2023 at 6:17 AM
    JNeemus
    JNeemus New Member
    Arroyo Grande, CA
    2024 Tundra Limited
    Factory 20s with 35x12.5 using a 1 inch spacer and here’s a down the side shot IMG_4084.jpg IMG_4141.jpg
  9. Dec 11, 2023 at 8:16 AM
    JayDee
    JayDee New Member
    I expect the biggest Con is fuel efficiency. What kind of MPG are people getting with 35's? I expect close to a 3MPG hit.
  10. Dec 11, 2023 at 8:18 AM
    Henry2019
    Henry2019 N/A
    Houston, Texas
    2019 SR5 CM CEMENT GREY
    3/1 Lift Kit 20X9 Fuel Assaults +1 295/60R20 Falken Wildpeak A/T3W
    KO2’s?
  11. Dec 11, 2023 at 8:38 AM
    JNeemus
    JNeemus New Member
    Arroyo Grande, CA
    2024 Tundra Limited
    I’m averaging 16 driving very conservatively.
    Yes K02s!
  12. Dec 11, 2023 at 8:41 AM
    Timmy23
    Timmy23 New Member
    OR
    25 1794 MGM Tundra
    None
    if using the 7-8% difference from display to real mileage, then around 16.5 for me as a combined city/highway.
    Consistently for the past year. 11,000 miles.
  13. Dec 11, 2023 at 12:17 PM
    Bailey1794
    Bailey1794 New Member
    Houston
    2023 Smoked Mesquite Hybrid 1794 Tundra
    Diode Dynamics Ambassador & Talons Garage Affiliate (See Below for discounts) Use code Bailey for Diode Dynamic free shipping Current Build & Pics Instagram.com/Bailey1794 Discounts & Affiliate links below https://linktr.ee/bailey_1794?fbclid=PAZXh0bgNhZW0CMTEAAaYH-pwfNz76E_oAQekLat2ZdcSY0VrV7a8O3_UxaU15mlBifUGV3lGaU4s_aem_Aamyw5XakyTlp6h_WyGSA8wBSO-cFzK1Z0t3EQBBaXEgDCnQI49fSwGFqQNWOCNd5OxDNGhVrMYRcfs_DEuuCXSy
    What lift are you on?
  14. Dec 11, 2023 at 12:27 PM
    drewpweinerMD
    drewpweinerMD MPG’s are for your moms Prius.
    Jeremy
    2024 Limited TRD OR
    RB20 Slims, BAK X4s, Fabtech Level, Cooper 35's
    @matth66 Looks like you're piloting a TRD PRO, so you're suspension setup is different. The stock pro can fit 35's no problem. Evidenced by the many visitors of this fine establishment. Also, see below....
    ElectricMan likes this.
  15. Dec 11, 2023 at 1:03 PM
    Bailey1794
    Houston
    From what i've read if you have the trd black 20" they can work with the 35x12.5 as they are 20x 8.5 sized rim.
    ryanwgregg likes this.
  16. Dec 11, 2023 at 10:40 PM
    matth66
    matt
    Nor cal
    Will a 35x12.5x18 fit on a factory trd pro rim?
  17. Dec 12, 2023 at 5:53 AM
    JNeemus
    JNeemus New Member
    Arroyo Grande, CA
    2024 Tundra Limited
    This is a factory 3 inch TRD lift.
  18. Dec 12, 2023 at 9:38 AM
    Hunter1699
  19. Dec 12, 2023 at 9:42 AM
    Hunter1699
    I was getting between 16/17 not driving it hard. Last trip ti GA I decided to use 93 octane and mileage improved to little over 19. Not bad. Thats 65-75 mph. Is it worth the extra cost-I don't know but probably will continue.
  20. Dec 12, 2023 at 9:44 AM
    Bailey1794
    Houston
    Was there a reasoning on needing the spacers because of rubbing or just aesthetics?
  21. Dec 12, 2023 at 10:23 AM
    JNeemus
    JNeemus New Member
    Arroyo Grande, CA
    2024 Tundra Limited
    Aesthetics, I only started rubbing after the spacers were installed and ended up removing the mud flaps and pushed the fender liner in.
    Bailey1794[QUOTED] likes this.
  22. Dec 12, 2023 at 10:55 AM
    JayDee
    JayDee New Member
    I've been getting 18.5MPG average on stock 32" tires with mostly city driving. On the highway I get around 20MPG (80+ MPH), 22MPG (70+ MPH), or 24MPG (60 MPH). I tend to go as fast as the speed limit allows (plus a little extra) so I don't seem to mind paying for a shorter (time wise) trips. It is cool to poke along at 60MPH and see how high the MPG will go but I typically only do that on short trips.
    Judging by what people are reporting I'm figuring that the 35" tires cost about 2.5MPG.
  23. Feb 7, 2024 at 5:55 AM
    EOTundra
    EOTundra New Member
    Los Angeles
    2023 CM WCP Platinum 6.5
    Did you do any other modifications or is it completely stock aside from the wheel spacers? Is yours the regular 4X4 without any of the TRD Packages?
  24. Feb 7, 2024 at 6:05 AM
    Porkchop253
    I have the trd lift kit also.
    EOTundra[QUOTED] likes this.
  25. Feb 7, 2024 at 6:43 AM
    kilocharlie106
    kilocharlie106 mmmm Bourbon
    TRD Pro in LR
    I imagine you got your answer by now, but yes they will fit. I am on 35x11.50, and plenty of others have 35x12.50 on pros
  26. Feb 7, 2024 at 7:33 AM
    KrissyMattAlpha
    KrissyMattAlpha New Member
    2023 SR5
    Bro I would love to see your vehicle data on your fuel economy numbers. I have a frequent 30 mile commute on open highway at 75 miles per hour with a stock Tundra on stock tires with the cruise control engaged. Most often I get in the left lane and never have to touch the brakes. I've never seen a fuel economy number above 17.5 at the end of drive summary like yours. Apparently I have a malfunctioning truck if I'm missing out on and extra 4.5 mpg that you're achieving.
    Am I the only one with the shitty fuel economy? I drove a 2006 DblCab before this 23 Crewmax and figured the fuel economy I was getting seemed normal.
    Jongie123 likes this.
  27. Feb 12, 2024 at 9:49 AM
    TheCrazyludwig
    TheCrazyludwig New Member
    Can confirm...35'' on stock TRD Pro wheels (westcott collar lift .... hence the extra space):5B83DA43-EA90-40D1-850C-8293E86FF73C_1_105_c.jpg 29FDE81B-0E2A-4D32-9949-F1775A37BCB3_1_105_c.jpg D01C083B-6E31-4E8E-94F1-8F75C960FB3F_1_105_c.jpg
  28. Feb 12, 2024 at 7:05 PM
    matth66
    matt
    Nor cal
    Me too! 35” on factory rim with wescott lift
  29. Feb 12, 2024 at 8:47 PM
    PVT Pablo
    PVT Pablo
    Paul
    Kitsap County, WA
    2023 Tundra Platinum Hybrid
    Dobinsons IMS 2"/1", BMS 1" Wheel spacers with OEM Platinum Wheels. Icon Sway Bar Spacer. 285/65/20 Firestone Destination XT Tires.
    Those of you with 35's, have you checked your sway bar? I was having enough contact that I was rubbing a small spot of paint off.
    1" spacers and 2" of front lift solved the problem.
    Just curious it if it was just me.
  30. Feb 14, 2024 at 7:34 AM
    LopezAd909
    LopezAd909 New Member
    Adrian
    2024 Lunar Rock Tundra
    Icon suspension, 37s on OEM 20s
    I'm on 37s on stock 20s with 3" of lift and just discovered my sway bar problem this past weekend. I thought I was rubbing the felt liner the whole time. I have some 1.5" on order that will hopefully take care of the problem.
    PVT Pablo[QUOTED] likes this.
