Factory top speed limit
Discussion in 'Performance and Tuning' started by frichco228, Oct 13, 2021.
  1. Oct 13, 2021 at 12:00 PM
    frichco228
    frichco228 [OP] Valued Member
    2016 Crewmax 4WD, TRD Offroad
    Is there a way to remove the factory speed limit on a Tundra? Is a tuner like bullydog or similar able to remove the factory set limit or are there any other ways?
    dirtydeeds likes this.
  2. Oct 13, 2021 at 12:02 PM
    Bully dog can
    dirtydeeds and frichco228[OP] like this.
  3. Oct 13, 2021 at 12:46 PM
    Dr Doobie
    Dr Doobie Growing member
    Talkeetna,Alaska
    '07 RCSB 5.7 SC'd 4x4 SSM
    What is the mph factory set speed limit?
  4. Oct 13, 2021 at 12:52 PM
    Netmonkey
    Netmonkey Don't be a Dumbass
    Georgetown, TX
    2016 Texas Edition, 5.7, CM, MGM
    Icon stage 2 lift, 295 60 20 nitto ridge grapplers, fuel kranks, TRD dual exhaust, TRD rear sway bar
    About 107.
  5. Oct 13, 2021 at 12:54 PM
    frichco228
    My truck is stock, but does have 275/70-18 tires. Power cut out at 110 for me, which makes me think it would cut out at 105/107 with stock truck on stock tires. Not condoning driving that fast, but I needed to today in an emergency, and having the power cut at that speed was unsettling/distraction right at the time when you don't need a distraction! Otherwise the truck was very strong and stable.
  6. Oct 13, 2021 at 1:12 PM
    Dr Doobie
    Talkeetna,Alaska
    Thanks, I had not done any hard pulls with my regular cab before I had a dealership put the TRD SC tune in my truck. And was curious what the factory cut off point for mph was,now I know.
    dirtydeeds and Platinum714 like this.
  7. Oct 13, 2021 at 1:16 PM
    Taco-Spike
    Two Trucks
    haven't found out yet in 2.5 gen but in 2 gen it was about 97
  8. Oct 13, 2021 at 1:16 PM
    snivilous
    snivilous snivspeedshop.com
    SW UT
    300k+ Supercharged 2008
    I would go as far as to say it's not a tuner if it can't do that. Bullydog, VF, HP, all of them can disable the limiter.
    frichco228[OP] likes this.
  9. Oct 13, 2021 at 1:19 PM
    War Machine
    War Machine SSEM # 5 3MW
    On my second gen it was around 110. About the same in my 21.
    Taco-Spike[QUOTED] likes this.
  10. Oct 13, 2021 at 6:43 PM
    dirtydeeds
    Keith
    USA
    more than I can list here
    What year is your truck?
  11. Oct 14, 2021 at 9:02 AM
    frichco228
    2016 5.7 standard, non flex fuel
    dirtydeeds[QUOTED] likes this.
  12. Oct 14, 2021 at 10:05 AM
    dirtydeeds
    Keith
    USA
    Bullydog should remove. They advertise it will. I’ve personally installed several and it did. I’ve read forums where some guys say it didn’t. But I’ve never personally seen that.
  13. Oct 14, 2021 at 8:46 PM
    NueveTundra
    NueveTundra Mod list in Bio
    Planet Earth
    07, Black Tundra SR5 CrewMax
    So a fallow up question with the speed limiter taken out what is the top speed It can do?
  14. Oct 14, 2021 at 8:54 PM
    Dr Doobie
    Talkeetna,Alaska
    If you have deep pockets,master tech status and own a private island, your Tundra should do a 9sec QM!:rofl:
    I'm not sure, mine stops at 122-125
    ( not wot)
