Factory Wireless Charging solution (I believe)
Discussion in '3rd Gen Tundras (2022+)' started by wirles, Jul 25, 2024.
  1. Jul 25, 2024 at 6:26 PM
    wirles
    wirles [OP] New Member
    I did a search and couldn't really find thread that I felt I could post the solution that worked for me. I have a Samsung S24 Ultra and I had trouble with the Toyota Qi charging maintaining a connection. It would say it was charging and then would start blinking saying there was an error and stop charging. I will say my S23 positioned correctly would charge every time. I read a lot of the posts and saw that the Toyota charger is pretty weak and it got me thinking.
    So I decided to try a test and I went into my settings under "Battery", Charging Settings, and turned off "Fast Wireless Charging". Now my phone charges continuously and does not have an issue maintaining the wireless charging connection. It does slowly charge but no slower than it did before. It is about the same rate that my S23 would charge.
    I hope this helps some folks. I am not sure where the same setting is on an iPhone. But I would be interested to hear if this fixes anyone else's wireless charging issue on the factory charger.
    Good luck.
    Blufin and teab like this.
  2. Aug 18, 2024 at 5:10 PM
    LayK
    LayK New Member
    Layton
    Baton Rouge
    2022 Silver Tundra TRD 4x4 Limited Hybrid
    I was looking for a thread here that went over this. I am looking for a solution as well for my iPhone 15 plus. I don't use a case and it doesn't charge my phone at all. The Qi chargers are partcularly sh*t, and I don't know what made Toyota think they were a good idea.
    Has anyone found aftermarket replacements? I would even consider ripping apart my dash to swap it out it is that bad.
  3. Aug 18, 2024 at 7:15 PM
    strangiato
    strangiato New Member
    I have no issues with my iPhone 13 Pro. It connects and charges just fine.
    My wife has a Samsung Galaxy Z Flip 4. If it's folded, we have to add a small block under the phone to lift it up high enough to reach the charger coil.
  4. Aug 18, 2024 at 7:21 PM
    Breathing Borla
    Northern Illinois
    try moving it a touch to the left of the retaining bar thing, try 1/4”-1/2” to the left.
  5. Aug 21, 2024 at 4:31 AM
    LayK
    LayK New Member
    Layton
    Baton Rouge
    I have tried every which way, and looking at the tear down of an iphone 15 plus, and the layout I think is in the QI charger, I even tried flipping my phone upside down to charge. I feel like even if I have it perfectly connected, it still goes off an on.
  6. Aug 22, 2024 at 8:38 PM
    LVTundra2024
    LVTundra2024 New Member
    G
    2024 Limited 4x4
    I just picked up my 2024 Limited and have the same issue with my iPhone. Will not maintain a connection. Will keep an eye on this thread for a possible fix.
  7. Aug 22, 2024 at 9:47 PM
    GutenWurst
    GutenWurst New Member
    Middle Tennessee
    '23 Army Green 1794 w/TRD
    I had the same issues with the factory setup on my Pixel 7 Pro. Swapped out to the EFF and have ZERO issues maintaining connection. The Pixel 7 Pro doesn’t fast charge with the EFF (well documented) but considering how frequently the stock unit disconnected, the charging speed is a wash for me.
    I really like the EFF unit because it can be installed without any easily reversible modifications to the truck and maintains the stock appearance of the truck.
    EFF Thread: https://www.tundras.com/threads/eef-qi-charger-v2-release-and-dual-charger-sneak-peek….115096/
  8. Aug 26, 2024 at 6:15 AM
    LayK
    LayK New Member
    Layton
    Baton Rouge
    I said I would consider ripping apart my dash to get in there, and this looks to be the solution I am after. So I will put my money where my mouth was and order this. I'll update this thread when I order and it comes in and I install. Thank you for the link.
    TiimmyTheT likes this.
  9. Dec 10, 2024 at 3:01 PM
    TiimmyTheT
    TiimmyTheT New Member
    I flipped also, replaced case with a MagSafe (same model case), removed cover, held in place with finger….. thanks for this, thought it was just me. iPhone 15 plus also
  10. Dec 11, 2024 at 4:34 PM
    Jcallip
    Jcallip New Member
    Jeff
    2025 Limited
    I have a Peak Design case on my iphone 13 pro, I just put a piece of 1”x 1” under the phone, it connects and charges no probs
