Factory wireless phone charger useless!
Discussion in '3rd Gen Tundras (2022+)' started by SDT, Mar 7, 2022.
  1. Mar 7, 2022 at 9:13 PM
    SDT
    SDT [OP] New Member
    B
    2022 Limited Tundra Mesquite
    TRD running boards/skid plate
    I have a 2022 Limited and the factory charger in the front dash seems essentially useless. I have an iPhone with an Apple case and if the screen is on (Waze etc), the battery is slowly draining even while charging. If the screen is off, the charge rate is so slow that it's pointless - maybe a couple %/hr.
    Anyone have similar results or is my charger defective? It also seems very easy for the phone to move out of alignment during normal driving and the amber light starts blinking to indicate an issue. There's no chance this thing will charge on any sort of trail.
    25Yota likes this.
  2. Mar 7, 2022 at 9:49 PM
    TFT
    TFT New Member
    Troy
    2017 Tundra Limited
    I have the center console charger, works ok. Slower then plugging in. Is your case made to pass the wireless charge? The further from the pad, the worse the charge rate. Try without the case. I use it for convenience, not speed. Plug it in if you need the phone charged.
    Hadelson and Elevatormatt like this.
  3. Mar 7, 2022 at 9:50 PM
    xc_tc
    xc_tc New Member
    All Qi wireless chargers in any manufacturers vehicle are garbage. Waze is also trash, it’s so resource heavy that it’ll drain your battery much faster than Google or Apple Maps.
    shellshock, KK6PD, Kagisexton and 5 others like this.
  4. Mar 7, 2022 at 10:11 PM
    19TurdPro
    19TurdPro New Member
    2019 Tundra TRD Pro
    It's the same for all Qi chargers.
    TMack77 and Elevatormatt like this.
  5. Mar 8, 2022 at 4:52 AM
    Buckeye88
    Buckeye88 New Member
    Nate
    22 Tundra Limited
    I had a 2 hour drive yesterday. My phone was running android auto (google maps and spotify) the whole way. The battery went from 40% to 20% in that time, while on the charger. I plan to have it plugged in for for anything longer than that. In the day-to-day commute (~30 min), the wireless charger does pretty well to keep me charged up, assuming 100% to start the day. Using Pixel 3XL, FWIW.
    Hadelson likes this.
  6. Mar 8, 2022 at 9:21 AM
    EvilSteve
    EvilSteve New Member
    2022 Lunar Rock Tundra Limited
    A lot of times the charge rate will be limited due to the phone temperature. If you have a big, heavy case on the phone, try removing that and seeing if it helps. Alternately, things like waze and other intensive applications do use a lot of resources which not only drains the battery faster but also creates heat which is one of the key issues with wireless charging.
    Wheelboss7177 and theripper like this.
  7. Mar 8, 2022 at 9:32 AM
    Danman34
    Danman34 New Member
    Danny
    2018 White Tundra TRD Sport
    It was dinosaur charging technology when it was released 3 years ago.
    TMack77 likes this.
  8. Mar 8, 2022 at 9:38 AM
    Taco-Spike
    Two Trucks
    My Tacoma is the same. Never use it. Didn't see a reason to put one in my 17 Tundra that a lot of people are doing. Cord does the best job
  9. Mar 8, 2022 at 9:51 AM
    19TurdPro
    2019 Tundra TRD Pro
    I went wireless Android Auto specifically so I could use a cord to charge. :rofl:
  10. Mar 8, 2022 at 9:31 PM
    SDT
    SDT [OP] New Member
    B
    Does anyone know if you can pop out the Qi plate? I'd love to replace it with a flush Apple MagSafe charger..
    25Yota and murtro like this.
  11. Mar 9, 2022 at 8:15 AM
    wired
    wired New Member
    David
    2022 Tundra Black SR5
    I don't have the OEM charger, but mounted a MagSafe thin one in that location. It charges fine through my case or my wife's case for her phone even running waze. I'd like to eventually mount it true surface, but don't have the time to mess with it now. It is a great location for the phone to sit and I hate messing with charging cords.
  12. Mar 9, 2022 at 8:22 AM
    jeffiance
    jeffiance New Member
    Jeff
    2020 SR5 CrewMax
    I have the wireless Toyota console charger in my 20 and it fast charges my phone with a case on. Take a volt meter to the connection and make sure you're getting the proper output then you'll know if it's defective
    EvilSteve likes this.
  13. Mar 9, 2022 at 12:20 PM
    SDT
    SDT [OP] New Member
    B
    Anyone know how to pop this plate out to take a look? What should the voltage be? Thanks!
    NewDadSameTundra and murtro like this.
  14. Mar 9, 2022 at 12:29 PM
    Breathing Borla
    Northern Illinois
    when I test drove one recently, more important than the voltage (im interested in that too), but it would lose connection all teh time, I wonder if they have a small connection area as well as underpowered
  15. Mar 9, 2022 at 12:47 PM
    SDT
    SDT [OP] New Member
    B
    Wait, so you've been using a computer all day to post on this website and not a phone? What do you use to charge your computer on that bike? o_O
  16. Mar 9, 2022 at 12:48 PM
    Breathing Borla
    Northern Illinois
    nah, then I can't blast Crowbar while Im driving so thats out, HA :headbang:
  17. Mar 9, 2022 at 12:51 PM
    Sirfive
    Sirfive Master Procrastinator
    SATX
    ‘02 Limited AC TRD
    Bassani cat-back
    Lolz. Im just jelly cause my headphones dont fit in my helmet.
    grandpas taco has an iq charger and will charge his tiny phone, but the trucks screen needs him to be plugged in, so we use an old phone to leave in the truck and download map updates at the house on a pc.
  18. Mar 9, 2022 at 12:53 PM
    1lowlife
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    Does that writing change when there is a backup ahead, and then offer an alternative route?
    I'm sure you would hate sitting in traffic on your Vespa scooter.
    Unless you're one of those assholes that cuts thru traffic in a backup.:thumbsup:
    Sirfive[QUOTED] likes this.
  19. Mar 10, 2022 at 12:57 AM
    Sirfive
    SATX
    ‘02 Limited AC TRD
    Bassani cat-back
    i am. Its air cooled, so im not sitting around and waiting for anyone. And i can change routes, i’ll eventually come to one of the roads im looking for. Hell, sometimes i move to the front of the line at redlights just cause i can.
    1lowlife[QUOTED] likes this.
  20. Mar 10, 2022 at 8:16 AM
    1lowlife
    DADA
    2014 MGM DC SR5
    Yes, that is how we used to do it, back in the day..:thumbsup:
  21. May 31, 2022 at 10:56 PM
    murtro
    murtro Life is unpredictable. Eat dessert first!
    Alberta
    Following! The Qi charger does not work with Iphone 13's.... we need a better solution!
  22. Jun 1, 2022 at 4:12 AM
    pursuit2550
    pursuit2550 New Member
    2020 Tundra SR5 Maggie 1900
    More useless technology just to jack up the price on the vehicles. I just plug it in and use Apple car play. I could run my maps and play Spotify at the same time and battery stays at 100%.
    Breathing Borla likes this.
  23. Jun 1, 2022 at 6:54 AM
    Breathing Borla
    Northern Illinois
    it must be a toyota thing now, I have a 2022 Sienna as a loaner for the wires van while they fix it, the wireless charger doesnt work for shit either, just constantly drops connection.
  24. Jun 1, 2022 at 8:36 AM
    hivetyrant
    hivetyrant New Member
    2022 Limited Tundra
    Works fine if you don't have a thick case. It's not a high powered charger, and was never advertised as such.
    Waze in combination with wireless carplay is using a lot of juice so don't expect to increase battery levels. I see the thing as more of a "battery level maintainer" in most cases, but I'll be replacing with a higher power one eventually.
  25. Jun 1, 2022 at 8:47 AM
    eick
    eick New Member
    2020 CrewMax TRD Off Road
    I plug mine in and use Apple CarPlay. And I don’t connect Bluetooth. Everything works great even can put Gaia on the factory screen if I want.
    Krusher22plat likes this.
  26. Jun 1, 2022 at 11:23 AM
    TWade
    TWade New Member
    Tanner
    2023 Tundra TRD Pro Black on Black
    Hmm, I have a Samsung S20 with a case (not very thick) and I run Android Auto with Waze and mine charges just fine. Not as much as my fast charger, but it always charges with a decent rate.
    Donas likes this.
  27. Jun 1, 2022 at 11:38 AM
    Breathing Borla
    Northern Illinois
    the problem I had on my tundra test drive and the current Sienna I have is the connection would not stay, it keeps disconnecting
  28. Jun 1, 2022 at 1:04 PM
    murtro
    Alberta
    it seems to be a problem with Iphone 13's primarily. Some say because the camera sticks out more creating a gap. I think its only 0.5mm but maybe?
  29. Jun 1, 2022 at 1:12 PM
    Kagisexton
    Kagisexton New Member
    Christopher
    2022 Tundra Platinum
    The only thing the QI charger is good for is a second phone
  30. Jun 1, 2022 at 9:03 PM
    Donas
    Donas New Member
    TN
    22 Tundra Platinum
    I'm thinking it's either the case or phone brand. I use a Samsung Z Fold with a case and it charges fine. The charger isn't said to be a "fast charger" and doesn't perform as such. Mine chargers as fast as the Samsung brand charger I have on my desk, that isn't a fast charger.
