Fair price for coil over install & alignment?
Discussion in 'Suspension' started by Jebber3, Jul 3, 2023.
  1. Jul 3, 2023 at 2:13 PM
    Jebber3
    Jebber3 [OP] New Member
    2018 Tundra TRD Off Road
    Hi Friends, what’s the going rate for coil over replacement and alignment on a 2018?
  2. Jul 3, 2023 at 2:24 PM
    RobertD
    Robert
    DFW, Texas
    Like changing the springs or just swapping out the whole assembly. Are you changing height or just putting in newer stuff?
  3. Jul 3, 2023 at 2:33 PM
    Jebber3
    R&R the whole assembly… I’m removing the stock coilovers and installing fox 2.5 coilovers from a Trd pro. It should be the equivalent of a 2” lift up front. Thx
    RobertD likes this.
  4. Jul 3, 2023 at 2:39 PM
    RobertD
    Robert
    DFW, Texas
    So when I was looking to do something similar I was quoted $600 for all 4 corners with the alignment. I then did the work myself (not to terrible if you have some time and tools) and then just took it in for an alignment.
    This was like 2 years ago though
    Jebber3[QUOTED][OP] likes this.
  5. Jul 3, 2023 at 3:37 PM
    MadMaxCanon
    MadMaxCanon New Member
    '21 CM SR5 4x4 6 seater
    Too many, but not enough....
    If the coilovers are assembled uts really not too bad, especially with a buddy
    Jebber3[OP] and RobertD like this.
  6. Jul 3, 2023 at 3:55 PM
    Cthulhu
    Also about two years ago, 4WP charged me $750 labor to install new TRD Pro Fox shocks all around on my Limited, as well as Coachbuilder +3 shackles and poly bushings, (replacing OEM shackles can be a pain if the bushings don’t come out of the leaf eyelets easily), Coachbuilder .5” shims, and an alignment. They did a great job in about 1/2 a day. Took back to shop and they retorqued everything, and I brought it home and verified all torque settings. I was more than willing to pay that as it was worth my time (it would’ve taken me two days because I am SLOW:rofl:), and, the shop in my area is one of the good 4WP stores. As you’ll see in this forum, some of their stores are good, some are horrible. So if you consider them, check the reviews on your local store. I hope this helps! :thumbsup:
    Jebber3[QUOTED][OP] and RobertD like this.
