Falken Wildpeak A/T ATW3 missing 3 peak snow logo
Discussion in '3rd Gen Tundras (2022+)' started by martinhh, Jan 14, 2024.
  1. Jan 14, 2024 at 1:23 PM
    martinhh
    martinhh [OP] New Member
    Martin
    2024 Tundra TRD Pro
    I just got a 2024 Tundra TRD Pro and it has Falken Wildpeak A/T ATW3 tires on it. All online material from Falken and from tire stores says that is should have a 3-peak mountain snowflake (3PMSF) logo on it. But it does not.
    Is this a known issue between the OEM and after-market part? Picture of the time included.
    We go up to the mountains every weekend to ski, and I was looking forward to not having a set of winter and summer tires/wheels.
  2. Jan 14, 2024 at 1:25 PM
    GoTTi74
    GoTTi74 New Member
    Bay Area, California
    2022 Tundra Ltd TRD OR CM LB
    Noticed the same on mine…
  3. Jan 14, 2024 at 1:47 PM
    martinhh
    Martin
    2024 Tundra TRD Pro
    Well, that is disappointing. So, if I go places that require 3PMSF during snowstorms I need to either: 1/ get a set of winters; 2/ replace these with the real deal.
    Colotundie likes this.
  4. Jan 14, 2024 at 2:55 PM
    TRDoffroadPRO
    TRDoffroadPRO New Member
    2023 Hybrid CM Limited TRD OFR
    Toyo open country's and nittos are vastly superior than this tire.
    The first thing I did is take off those falkens. They are great street tires and okay in wet but suck in snow and mud.
  5. Jan 14, 2024 at 2:58 PM
    PBNB
    PBNB Needy
    Peter
    Vancouver, BC
    2023 Z71 3500 HD
    Lots of stuff!
    I got some Falkens for my trailer. In order to get the load rating I went to a 10 ply 3Peak version of AT3/W and I can tell you that they are heavy and the treads are quite deep. I really like them compared to the Goodyears that were on the trailer.
    For the Tundra, if you went to a 10 ply tire, you should see a mileage hit. I went with a 10 ply Toyo for my Tundra and I can feel the added weight. I am not too sure if the hybrid would help but I think it should make a difference when starting up from a stop which is where you will notice the weight of these tires the most.
    TRDoffroadPRO likes this.
  6. Jan 14, 2024 at 3:02 PM
    TRDoffroadPRO
    It is a little different but not much, the benefits far out weigh the negatives by going to a 10 ply. If they make or eventually make a 116t all terrain the that would be a good option.
  7. Jan 14, 2024 at 3:14 PM
    Winning8
    Winning8 New Member
    Da Bay Area
    2019 MGM DC 4x4 SR5
    Don’t worry about it, I saw a lot of posts about them oem wildpeak don’t even last 20k, get your credit card ready and get some bigger tires.
    22whatwedo likes this.
  8. Jan 14, 2024 at 3:14 PM
    PBNB
    PBNB Needy
    Peter
    Vancouver, BC
    2023 Z71 3500 HD
    Lots of stuff!
  9. Jan 15, 2024 at 7:49 PM
    TundraDan723
    TundraDan723 Not as new as I used to be...
    2023 Celestial Silver Tundra 1794 TRD CM
    Same here. Very disappointing.
  10. Jan 16, 2024 at 8:01 AM
    Hadelson
    Hadelson New Member
    Allentown - Pennsylvania
    23 Tundra TRD Pro. Fun Ride 2019 RS3 Roush SC Mustang
    My Experience. These tires not good in Snow. Have a new set with just over 1000 miles on them (Toyota replaced due to alignment issue). This morning with 200LBS in back over rear axle, good traction but the fronts tend to plow as soon as you start into a turn. This is second snow with these. Not confident at all with them and They will be replaced late next summer..
    Our 24 Rav4 Limited AWD with Michelins Primacy's does better in snow compared to the Tundra. It has dynamic AWD system and with MTS set for snow runs 4WD. Pretty slick system.
  11. Jan 16, 2024 at 8:04 AM
    b6graham
    b6graham New Member
    2020 Voodoo 1794 RW Wheels 315/70
    where do you ski that requires a 3PMSF?
  12. Jan 16, 2024 at 8:16 AM
    Hella Krusty
    Hella Krusty New Member
    If you don’t need a E rated tire, Nokian Outpost nAT are fantastic. Quiet, smooth, and 3psf. They look real good too. My neighbor runs Toyo AT3 and removes them for winter. I run the Nokians 365 days a year.
    TundraDan723 likes this.
  13. Jan 16, 2024 at 8:35 PM
    1bad2k
    1bad2k New Member
    Check out the Falken rt01 in a 35x11.5x18. They are c load rated.
  14. Jan 16, 2024 at 8:56 PM
    Tripleconpanna
    2021 TRD PRO CM; 2008 SR5 CM
    Yes, and when you start looking to replace them, make sure to check the notes/descriptions from the various manufacturers when selecting sizes, load ratings, etc...
    IE>> Not all aftermarket ATW3s coming 3-peak rated in all sizes, and it's the same for other brands as well...
  15. Jan 16, 2024 at 8:58 PM
    40man
    40man New Member
    The Falken AT4W was just released. Falken rates it as better in the snow than the AT3.
  16. Jan 17, 2024 at 5:57 AM
    b6graham
    b6graham New Member
    well...they're not going to say a new version performs worse are they?
  17. Jan 17, 2024 at 6:10 AM
    trucksareforgirls2
    trucksareforgirls2 New Member
    Northeast USA
    2020 Voodoo Blue TRD Off-Road
    I thought those usually have an A to signify that. So it would say A/T 3W A
  18. Jan 17, 2024 at 7:07 AM
    kilocharlie106
    kilocharlie106 mmmm Bourbon
    TRD Pro in LR
    Yes I have these tires on my Pro, but the OP asked about 3peak mtn tires, and these do not have a snow rating which he says is required on some roads. The Wildpeak RTs seem ok in the snow, but lack of siping will hurt snow traction
    1bad2k[QUOTED] and ryanwgregg like this.
  19. Jan 17, 2024 at 7:37 AM
    martinhh
    Martin
    2024 Tundra TRD Pro
    Every year we drive from Seattle area to Kelowna, BC to go ski at Big White. British Columbia has pretty strict tire requirements on any highway that regularly get snow and requires a 3-peak logo, M+S or chains (Passenger Vehicle - Tire and Chain Requirements - Province of British Columbia (gov.bc.ca)). Not that I think I need it most days, and yest, I think I can get away with M+S. But we sat on the Coquihalla highway for 7 hours in a foot of snow and ice one time because two trucks, without chains, jackknifed blocking the snowshed. When we started back up, you were not getting out of there without winters. So call me paranoid, but I do drive here sometimes - Highway Thru Hell (TV Series 2012– ) - IMDb.
    On normal weekends, it is Snoqualamie Pass, and the various other mountain passes in Washington.
    Mattedfred and b6graham[QUOTED] like this.
  20. Jan 17, 2024 at 7:40 AM
    PBNB
    PBNB Needy
    Peter
    Vancouver, BC
    2023 Z71 3500 HD
    Lots of stuff!
    We have those signs on most of the highways but still have too many drivers running around with summer tires. We are getting our first snow this season today and it is a smash up derby out there :)
    ZappBrannigan likes this.
  21. Jan 17, 2024 at 9:00 AM
    b6graham
    b6graham New Member
    Tbf a '3PMSF' isn't all much different than "organic" certification. Gotta pay to play
  22. Jan 17, 2024 at 10:24 AM
    b6graham
    b6graham New Member
    I mean more along the lines of the same tire but in different sizes, for example Cooper AT3 XLT, having a 3PMSF for the more standard sizes but they haven't paid for the other sizes most here would use so they don't get the snowflake
  23. Jan 17, 2024 at 2:04 PM
    PBNB
    PBNB Needy
    Peter
    Vancouver, BC
    2023 Z71 3500 HD
    Lots of stuff!
    Okay "boring"
    But seriously, I had them and swapped them out just to get a tire that fit the truck better than those donut holes! (If Timmys made tires they would be tiny Michelins) :)
    Mattedfred likes this.
  24. Jan 17, 2024 at 2:13 PM
    PBNB
    PBNB Needy
    Peter
    Vancouver, BC
    2023 Z71 3500 HD
    Lots of stuff!
    Falken has been around for a long time and have a pretty decent reputation. When I got mine Toyo's I was looking at the Falkens as well but it came down to a bit better price.
    I did put Falkens on my Airstream to replace my Goodyears and I am very impressed with the improved stability after that switch.
    ryanwgregg likes this.
  25. Jan 17, 2024 at 2:21 PM
    PBNB
    PBNB Needy
    Peter
    Vancouver, BC
    2023 Z71 3500 HD
    Lots of stuff!
    This guy can learn a new trick!
    And he is an old dog too :)
  26. Jan 18, 2024 at 10:30 PM
    1bad2k
    1bad2k New Member
    Ah, that's right.
  27. Jan 18, 2024 at 10:35 PM
    Rodtheviking
    Rodtheviking New Member
    Vancouver, WA
    Sequoia
    Mikey Thompson Baja Boss A/T, done.
