Falling out control arm bolt?
Discussion in 'Suspension' started by therealjonwick, Jan 12, 2025.
  1. Jan 12, 2025 at 12:33 PM
    therealjonwick
    therealjonwick [OP] New Member
    JR
    2019 OR
    Did the oil change and tire rotation. Noticed a strange sound last couple days. Noticed the bolt for my driver control arm is almost all the way out…. Anyone ever deal with this? The nut must have fallen off the other side and it’s been slowly sliding out. Is this a fluke? Or did the shop who put my lift on last summer not tighten it all the way?? I’m assuming I should get it towed to a shop.
  2. Jan 12, 2025 at 12:42 PM
    Ryuu
    Ryuu Hwat!?
    Oscar
    SouthEast, TX
    2017 TRD PRO Barcelona Red
    a few
    I'd assume the shop that installed your lift forgot to torque down the nut. I wouldn't see a need to have to tow it to a shop. Get you a M16 - 1.5 nylock nut and a washer, since it looks like the washer is gone too, from the hardware store slap it on and torque it to spec.
    I replaced both of mine with nylock nuts just to avoid ever having them back out.
    snivilous likes this.
  3. Jan 12, 2025 at 1:06 PM
    therealjonwick
    JR
    2019 OR
    Thanks for the info. I hope nothing is bent. What do I have to take off in order to get the bolt back through as I didn’t put the kit on? I can prob find a video.
  4. Jan 12, 2025 at 1:08 PM
    snivilous
    snivilous snivspeedshop.com
    SW UT
    300k+ Supercharged 2008
    Just lift that side up so the suspension can droop and you can wiggle the upper arm and the bolt will pop right through.
    Ryuu likes this.
  5. Jan 12, 2025 at 1:21 PM
    therealjonwick
    JR
    2019 OR
    Perfect! Thanks. Anyone know torque specs?? I have zone off-road control arms. I think the bolts are factory.
  6. Jan 12, 2025 at 1:24 PM
    Ryuu
    Ryuu Hwat!?
    Oscar
    SouthEast, TX
    a few
    I looked up the spec for the zone uca, 173 ft-lbs. Same as stock.
  7. Jan 12, 2025 at 1:29 PM
    therealjonwick
    JR
    2019 OR
    Awesome. Thanks. I think it’s the stock bolt. Will be going to the hardware store tomorrow.
  8. Jan 12, 2025 at 1:32 PM
    Be sure when you get the bolt re-inserted and the nut back on to have the truck weight back on the suspension before torquing the nut down.
    EDDO likes this.
  9. Jan 12, 2025 at 1:51 PM
    therealjonwick
    JR
    2019 OR
    Yup! Thanks. Does the bolt need to be greased at all? I know the bushing were supposed to be before the arms were installed.
    koditten likes this.
  10. Jan 12, 2025 at 1:54 PM
    therealjonwick
    JR
    2019 OR
    My only other concern is fitting my torque wrench on that bolt. Looks like a tight fit. Might have to find a shorter socket.
  11. Jan 12, 2025 at 2:50 PM
    BrandonL812
    BrandonL812 New Member
    Brandon
    2021 Tundra Platinum
    No need for grease. You can put some antiseize compound on the shaft of the bolt..light coat will do. Do not put it on the thread portion..
  12. Jan 13, 2025 at 4:40 PM
    therealjonwick
    JR
    2019 OR
    Got it in. Went right in. Used a normal hex nut. No store had the flat back or nylock ones. Might order some and replace later. Should hold for now. Thanks everyone.
  13. Jan 13, 2025 at 5:04 PM
    As long as it's torqued you should be good to go. If you want the nylon nuts, your local Grainger or fastener place usually will have them. I'm betting that they just didn't torque it. For reference here is the OEM nut https://www.sparksparts.com/oem-par...9dHVuZHJhJnk9MjAyMCZ0PXNyNSZlPTUtN2wtdjgtZ2Fz
  14. Jan 13, 2025 at 5:45 PM
    therealjonwick
    JR
    2019 OR
  15. Jan 13, 2025 at 5:57 PM
    koditten
    Kirk
    Midland of the Mitten
    Most definitely grease the bolt. I'm actually surprised yours were not seized. My '21 with 13k miles has 2 siesed bolts. Gotta cut them out.
    It's pretty common with Toyota trucks.
  16. Jan 14, 2025 at 2:38 AM
    therealjonwick
    JR
    2019 OR
    I know it happens with the lower control arms all the time. Didn’t know the uppers did that as well.
    koditten[QUOTED] likes this.
  17. Jan 15, 2025 at 9:00 PM
    lr172
    lr172 New Member
    07 DC
    Did bunch of suspension work on 11 tacoma and 07 tundra. Both from midwest and both hadn’t been touched since the factory. Lower bolts all seized. Upper bolts all free. Believe the problem is limited to the lower arm bolts/ adjusters
  18. Jan 15, 2025 at 9:38 PM
    Jhon
    Jhon New Member
    On the Oregon Trail
    2021 SR5 TRD OR
    Out of curiosity were you able to squeeze a torque wrench onto the nut? What was your trick?
    I fiddled with it for a bit before I figured it wasn't feasible without risking a brake line. I gave it the old ugga dugga with a box end and a cheater pipe. Figured between that and the Loctite 263, it's not going anywhere.
    koditten and FrenchToasty like this.
  19. Jan 22, 2025 at 4:54 AM
    therealjonwick
    JR
    2019 OR
    I used the torque on the other end. Squeezed it in front of the wiring harness. Used a long wrench on the nut side.
  20. Jan 22, 2025 at 6:41 AM
    Totmacher
    Totmacher New Member
    Daniel
    West TN
    mesquite Tundra or blue 4Runner
    Some
    For future reference, you can remove bolt holding the brake hard line and "GENTLY" push lines out of way just enough to fit torque wrench on the UCA nut if you want. Never had a problem on my trucks doing that anyway.
  21. Jan 22, 2025 at 7:57 AM
    VWTim
    VWTim Mid-Travel Crew
    Corvallis, OR
    Not easy, but I torqued mine with a 3" extension and universal joint. Took 2 hands to hold everything and it was not easy. But click click...
  22. Feb 5, 2025 at 3:41 PM
    therealjonwick
    JR
    2019 OR
    Welp… have to do the other side now. Thought it was good but it too had the nut fall off and started sliding out. About to call the shop that put my lift on and wring them out. Could have been a bad accident if it came out. Any how… can’t seem to locate a grade 8 or stainless nut. Found a regular steel one. Will that work? Or should I order something like this? Need the truck tomorrow so might put the one I have on and replace later. Thoughts? https://www.amazon.com/dp/B077GL6RSD
  23. Feb 5, 2025 at 3:54 PM
    VWTim
    Corvallis, OR
    Just put whatever on it for now and order an oem nut or other nylock to change out.
  24. Feb 5, 2025 at 5:24 PM
    Ryuu
    Ryuu Hwat!?
    Oscar
    SouthEast, TX
    a few
    Like VWTim said, use what you have for now if you need the truck tomorrow. If you have some blue loctite put some on there to avoid it backing out until you get your nylock nuts in.
    VWTim likes this.
  25. Feb 6, 2025 at 4:44 AM
    therealjonwick
    JR
    2019 OR
    Ordered those nylocks off Amazon. Should I also blue locktite those when I install?
  26. Feb 6, 2025 at 4:52 AM
    therealjonwick
    JR
    2019 OR
    I see what you mean now that I’m doing passenger side. Much tighter and brake lines are right there. Should be interesting.
  27. Feb 6, 2025 at 5:44 AM
    therealjonwick
    JR
    2019 OR
    So I can get a long wrench on the bolt, moved the brake line a bit, but my torque wrench is too long and hits the tire on the bolt side. Any ideas on how I can do this? Can’t torque it from the top due to the metal mud guard bracket. Can’t get the torque wrench onto the bolt side. Ny only idea is to just tighten as much as I can with a shorter ratchet. Worried I’ll go too tight.
  28. Feb 6, 2025 at 8:03 AM
    ZPhilip
    ZPhilip Custom title here
    Philip
    West Chester, PA
    2015 Platinum Super White Crewmax
    Harrop supercharger, TRD Pro Fox suspension, CB +1 shackles, 295/70-18 Toyo ATIII, TRD Pro forged rims
    Torque spec is like 170 ft lbs. I don’t think that’s possible to tighten too much with a short ratchet.
    I was barely able to get 150 ft lbs with a long torque wrench.
    caboj likes this.
  29. Feb 6, 2025 at 8:28 AM
    texasrho83
    texasrho83 DGAF#1
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    This has happened to me and only on the driver side. I remember finding the nut sitting on the frame but no washer. Once I got another washer, I cleaned up the threads and ran the bolt back through then torqued to spec. I forget how long after that, but I noticed the nut had backed off again, so I ordered another through bolt, nut, and washer from the dealer. Installed it and used red loctite this time.
    Haven't had an issue since.
  30. Feb 6, 2025 at 11:16 AM
    therealjonwick
    JR
    2019 OR
    Yea I’m worried I may have the same issue. I marked the nuts with a paint pen so I can keep an eye on them. Eventually I’ll put on the nylock nuts and hope those hold. If not, I’ll purchase new bolts from Toyota also.
