Fault code P0138
Discussion in '1st Gen Tundras (2000-2006)' started by Klingon4x2, Feb 14, 2022.
  1. Feb 14, 2022 at 7:26 PM
    Klingon4x2
    Klingon4x2 [OP] New Member
    2006 Tundra 4x2 Double Cab
    None
    I have a 2006 4x2 Double Cap. I got a P0138 which points to Bank 1, Sensor 2 which is the driver side post catalytic convertor sensor. I replaced with an OEM sensor. I also cleaned the MAF sensor. Cleared the fault code and a day later the fault code came back. What else can produce the same code? I look around the exhaust to check for leak but could not find anything that will jump out at me. Any help? Thanks,
  2. Feb 14, 2022 at 7:30 PM
    Toyoda Tundra
    Toyoda Tundra Boxing and Tundras
    2WD 2004 AC Tundra. V8 strong
    Bank 1 sensor 1 could be on its way out causing irregular performance on the one you just replaced, sensors work together, that’s why it’s usually recommended to replace all of them.
  3. Feb 15, 2022 at 12:28 AM
    NickB_01TRD
    Nick
    KY
    01 Tundra V8 4X4 AC SR5 TRD
    Agree with this. At the bare minimum do Bank 1 sensor 1. If possible do the other 2.
    5N0W808 likes this.
  4. Feb 15, 2022 at 4:19 AM
    Jack McCarthy
    Bill
    North of Boston
    02 Tundra AC SR5 V8 4x4
    Don't you mean Bank 1 and Bank 2 sensor 1s at a minimum?
    5N0W808 likes this.
  5. Feb 17, 2022 at 7:53 AM
    Filthyphil
    Filthyphil Lions Not Sheep
    Phil
    2000 Toyota Tundra TRD 4.7
    Swap sensors from on side to the other and see if the code follows.
  6. Mar 24, 2022 at 4:25 PM
    remington351
    remington351 New Member
    2006 SR5 DoubleCab
    I chased the cat inefficiency code for a while and finally solved it with the anti-foulers
    https://www.tundras.com/threads/bad-cat-w-02-sensor-obd-data.95762/#post-2489829
    Reading elsewhere said the software on these Tundras is way too sensitive. One post said that once cat efficiency drops from 100% to 96% the cel will light and throw a code preventing you from passing emissions. I'm all for clear air but I'm not gonna spend $1,400 on a new cat just to gain 4%.
    Filthyphil and 5N0W808 like this.
