Finally decided on a lift kit
Discussion in 'Suspension' started by MadMaxCanon, Oct 26, 2021.
  1. Oct 26, 2021 at 7:47 AM
    MadMaxCanon
    MadMaxCanon [OP] New Member
    '21 CM SR5 4x4 6 seater
    Too many, but not enough....
    Hey all, I think i finally decided on the lift kit I am going with and wanted everyones advice if I should change/alter anything.
    Toytec Boss System - 2.5" coilovers set at full 3" prebuilt
    Toytec Shackles
    Diff and carrier drop kits
    Toytec rear add a leafs with 9" Ubolt kit
    Durobump stops for the rear
    Coachbuilder front bump stop extenders
    3 coachbuilder .5" shims (not sure if I have the lean but want to use at least one per side for a little over 3 inchs of total lift)
    Rear brake line extention brackets
    SPC UCA
    So far I will be running stock wheels but plan on getting some SCS SR8 in bronze when they have stock again. Any advice is greatly appreciated, i want to do this once and do it right.
  2. Oct 26, 2021 at 8:01 AM
    Using shims with Toytecs coilovers will void their warranty. The lean can be corrected by adjusting the coilover.
  3. Oct 26, 2021 at 8:19 AM
    MadMaxCanon
    Damn, didnt realize that. Where does it say that on their site?
    Part of me thinks, how would they know? The studs?
  4. Oct 26, 2021 at 9:10 AM
    2mchfun
    Might want to add front sway bar drop spacers. Good luck getting anything soon with the current conditions.
  5. Oct 26, 2021 at 9:12 AM
    MadMaxCanon
    Thanks for that tip. Do you know anyone that sells a spacer kit for the sway?
    Actually everything on my list currently doesnt show a back order. The SPCs I ordered a while back so they should be here soon.
  6. Oct 26, 2021 at 9:23 AM
    2mchfun
    Readylift will have em.
  7. Oct 26, 2021 at 9:24 AM
    I will have to look...it may be on the instruction sheet. You won't need a sway bar drop with this setup. I have the same setup.
  8. Oct 26, 2021 at 9:25 AM
    Toytec told me not to install one when I did mine. However, I wonder if it would reduce creaking...?
  9. Oct 26, 2021 at 9:27 AM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    Ditto in ditching the shims and front bumpstop extenders
  10. Oct 26, 2021 at 9:27 AM
    Backslider
    Backslider Thirsty...
    Tooele, UT
    I know this is an unpopular opinion around here, but having run Toytec suspension on my first Tundra I was really unhappy with the ride quality.
    On the second Tundra I went with Fox with reservoirs and DSC adjusters and it was a huge improvement over stock - even cranked up to 3.5" of front end lift.
    texasrho83 likes this.
  11. Oct 26, 2021 at 9:28 AM
    2mchfun
    No creaking here, lifted about 3"
  12. Oct 26, 2021 at 9:30 AM
    MadMaxCanon
    I am sure the fox is better all around but its way more money and honestly probably more hardcore than I need.
    No front bump stop extenders but what about the back? What height lift would recommend bumpstops?
  13. Oct 26, 2021 at 9:33 AM
    Backslider
    Tooele, UT
  14. Oct 26, 2021 at 9:34 AM
    2mchfun
    Once you add shackle length you want to add bump stop heighth to avoid flattening your springs when loaded super heavy. Factory bump stops and longer shackles simply puts the spring in a compromising position when the frame meets the bump stop.
  15. Oct 26, 2021 at 9:35 AM
    MadMaxCanon
    I actually do really like the ironman setup with the new leafs and its a great deal, i have just recently been reading about some front coil issues like bowing and its making me hesitant.
    Same with the OME setup (which was actually my first choice with the Dakars) but i have seen a couple posts here with issues that looked like a nightmare to deal with.
    2mchfun and Backslider like this.
  16. Oct 26, 2021 at 12:03 PM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    Don’t people get 3+ in the front with ironman? Honestly 3 inches even in the front rides dramatically worse than 2. The angle of the arms becomes steeper which ruins it. You can fit the same tires at 2 inches that you can at 3 for the most part
    remember, extended bumpstops means reducing available up travel in the suspension. Factor that into your setup
  17. Oct 26, 2021 at 12:08 PM
    MadMaxCanon
    The ironman kit is advertised at 3.5" all around. I do use this rig for offroading which is the main reason for the lift, and partially for bigger tires. I was going to do 18x9 wheels with +25 offset on 295/70/18s, would the extra lift not be necessary?
  18. Oct 26, 2021 at 12:19 PM
    Elduder
    Elduder New Member
    No, it wouldnt technically.
    To add to what @Hbjeff stated. I'm running the IM4x4 FCPs. They do come out at 3.5 from IM. I lowered them to 2.5" and there was a noticable change in ride quality, for the better.
    Going off your statement, since you do offroad, the lift actually becomes a non factor for any off roading that compresses the suspension to full stuff.
    Basically even with a lift you will rub without the proper offset and tire size to avoid it, or you will have to cut to make it work. The suspension simply rests at a lower travel (droop) point so lifts help with on road driving where stuffing never occurs. As soon as you take a good dip or mogul offroad you'll rub the same as you would with 34s on the stock suspension. Both set ups would travel upward the same and ultimately rub the same.
    +25s with 295s will avoid most of the rub risk, but honestly you will still have some if you try hard enough. If you want to decrease the risk any further but want 34"+ tires, go 285/75r18 or 285/70r18.
    Rub typically comes from the outer most edges on the tires, no narrower tires will help.
    Skew12 and TRDblvd like this.
  19. Oct 26, 2021 at 12:21 PM
    2mchfun
    As for front bump stop extensions, you may want to look at Timbren active bump stops. Kinda pricey but nice.
  20. Oct 26, 2021 at 12:25 PM
    MadMaxCanon
    Thanks for that breakdown. When you lowered your front to 2.5, did you get excessive rake considering the rear is already higher from the factory and you theoretically would have added an additional inch of rake? Do you have pics?
  21. Oct 26, 2021 at 12:32 PM
    Elduder
    Elduder New Member
    Sorry, I should have stated im running their coils and shocks.
    The rear on my truck has the CB +2 Shackle, not the IM leafs.
  22. Oct 26, 2021 at 5:15 PM
    MadMaxCanon
    Well crap what if I just ran 5100s on 2nd clip and CB shims for 2" lift with a +2 CB shackle and called it a day and save 1500 bucks on UCA, leafs, coilovers and having to take off all my belly armor for install....
  23. Oct 26, 2021 at 6:02 PM
    2mchfun
    If me, and I was going cheap on the rear. Ironman greasable shackles, pins and bushings, then lift with block not shackle length. Then you keep factory bumps and your springs aren't getting pushed into negative arch. Plus you get a better than stock ride and don't lose spare tire clearance with a big thick chunky aluminum shackle plate.
  24. Nov 8, 2021 at 2:35 PM
    rruff
    rruff New Member
    2016 Tundra SR DC Long
    I have taller and wider tires and no lift at all. Never rubs. I did do a BMC though... but I probably could have avoided that by moving the wheels forward a bit... and I modded the plastic a good amount.
    A 2" lift is enough for 37s if you do it right.
  25. Jan 19, 2022 at 2:51 PM
    Cavalry5.7
    Cavalry5.7 New Member
    21 cavalry crewmax
    Stock
    Was thinking of doing your exact setup . People at Ironman 4x4 recommended i didn't lower the front height from 3.5 to 2.5 . Looks like it's working well for you.
    You haven't had an issue with springs bowing at that height ?.
  26. Jan 19, 2022 at 4:30 PM
    Elduder
    Elduder New Member
    Going to be completely honest, but its my opinion. I dont believe they know their product that well. They use a spring that is longer than just about any other standard coilover for our trucks. With it jacked to 3.5" it binds pretty bad and you can find plenty of people on here that have issues with the coil contacting the shock body at that setting.
    When I spoke with them they "couldn't preadjust it down the .5"" I requested because they claimed it wouldnt adjust that low. Mine are currently adjusted down the .5", which I did on my own. Have about 5k miles on them now without issue. They ride, way better adjusted to 2.5". I'm going to lower them another .25" to get a bit of rake back once I finish moving. I've got room to lower them all the way down to basically stock height.
    Cavalry5.7[QUOTED] and rruff like this.
  27. Jan 19, 2022 at 5:53 PM
    rruff
    rruff New Member
    To get 3.5" of lift you have to compress them more, causing greater potential for bowing. It think it's a spring winding defect combined with low clearance because of the large shock body that is causing this issue.
    Or suspensions in general. Saying they need to be at 3.5" is very odd and makes little sense. Unless it's marketing who wants you to have to buy UCAs and rear springs, which you need to do if you lift the front that much.
    The 590 lb spring rate is why they need long coils. OEM is near 700 lb, and most other aftermarket springs I know of are 650-740 lbs (King is 600).
    Good info, thanks for sharing. :thumbsup:
