Finished Katzkin leather upgrade, Degreez install except for switches
Discussion in '2.5 Gen Tundras (2014-2021)' started by LoMile_21, Feb 9, 2025.
  1. Feb 9, 2025 at 4:52 PM
    LoMile_21
    LoMile_21 [OP] New Member
    Rodney
    East Tennessee
    2021 White Tundra Double Cab TRD Sport 4x4
    Katzkins/Degreez, Revesol, trans cooler, oem step bar, bed rug, gator cover
    I finally finished my Katzkin and Degreez installation on my 8k mile '21 Tundra. Now I just need to decide where I'm going to put the switches. The Degreez install adds another level to the upholstery installation time. I've done other upholstery installs and this was the most difficult. I could only find one Tundra installation video for the unit installation and didn't agree with everything that was done.
    Some things to consider:
    . You may need another vehicle to drive during the installation, it's going to take a few days.
    . Take a day or so break between seats and let your hands heal. You're going to get cut.
    . Have some band aids and use some light gloves.
    . Have a well-lit, warm, clean area to work and get a headlamp.
    . You're going to need some tools.
    . Order stainless hog rings and the needle nose hog ring pliers and some good 8" side cutters.
    . Watch a lot of videos on the upholstery installation.
    . Don't start until you have everything.
    . Opinion: The Degreez vent is a vent and not an exhaust for the lean back which is a closed area.
    . I did not need a steamer although my basement has a woodstove and I had a pot of water on it. It was cold during some of the install.
    . You will need to disconnect the battery and will lose your trip miles and distance to empty. My radio settings remained.
    . Along with others, I agree to start on the rear seats first. Note your head rest notches.
    . Take a lot of pictures before tearing things apart.
  2. Feb 9, 2025 at 6:30 PM
    JohnWhicker
    JohnWhicker New Member
    Or pay a skilled hand $350 and get it done in few hours :) It worked for me.
    Great job by the way
  3. Feb 9, 2025 at 6:50 PM
    LoMile_21
    Rodney
    East Tennessee
    Yes. Definitely pay for skilled installation if possible and make sure they have done the installation on a Tundra, especially the Degreez units. Maybe find out who the dealers in your area use. I wanted to save my original seat covers so I decided to do it myself. I can see where some parts might get broken but fortunately, I didn't break anything, the prep videos definitely helped. I don't know about the crew cab but the double cab rear seat plastic covers are painful to remove, and they are difficult to come apart, but you have to remove them first. The actual installation of the leather I wouldn't mind doing again and even the seat heaters but not the Degreez.
  4. Feb 9, 2025 at 6:51 PM
    Ruggybuggy
    Ruggybuggy Seasoned Veteran
    Dave
    NW ON, CANADA
    2016 Tundra OR
    Get the console cover to match. You can buy them for $15-$20 on Amazon and EBay and they match my Katzkins perfectly.
  5. Feb 9, 2025 at 6:52 PM
    LoMile_21
    Rodney
    East Tennessee
    Yes. That is on my list. The one shown looks very nice.
    Ruggybuggy likes this.
  6. Feb 9, 2025 at 7:01 PM
    LoMile_21
    Rodney
    East Tennessee
    I did test the Degreez units before and after the leather installation. I'm not 100% sure but no way they are going to put out the same heat or heat as fast as seat heaters. You can only really hear the fans on the cooling/vent cycle, so the fan speed is definitely low on the heat cycle. I just don't see the heat being efficient on a really cold morning. Some of the heat or cooling will be ambient as the interior heats or cools. We'll soon see.
  7. Feb 10, 2025 at 6:57 PM
    LoMile_21
    Rodney
    East Tennessee
    I'm posting some images of the Degreez install for the lean back. On the bottoms I was able to locate near the center, there are only a few choices. On the lean back I had to notch the lumbar plastic supports and had to install the unit at an angle on the driver side. There seems to be some misinformation on the protrusion of the fan side tube through the foam. On the Katzkin information it states to cut off flush. On the videos they state to leave 1/2" or so through the foam for the pad. The problem is that the tube dead heads on the pad, so it is similar to placing your hand over a hair dryer to obstruct the air flow and the air is supposed to flow throughout the pad. It will still flow air but I'm not sure it's as efficient.
    As a side note, I have seen some complaints on the seat comfort. In cutting out the foam for the pads, I noticed some differences in the density of the foam. The driver side back foam was definitely softer than the others so I can see there might be manufacturing inconsistencies in the foam. If you add in the differences in the fabric vs leather, I can see where one seat may differ from another in comfort. I think the fabric was more comfortable, but I like the look and durability of leather. I'll add more if I think of anything. Maybe this might help someone. I'm not 100% on everything I did was correct, but I am ok with the results.
    HulkSmurf14, Rdrcr and Ruggybuggy like this.
  8. Feb 10, 2025 at 7:11 PM
    NotSpongeWorthy
    NotSpongeWorthy i member
    Ricky
    Valkenvania, PA
    2020 Tundra SR5 TRD Sport Crewmax
    Furry steering wheel cover
    This looks incredible. I think my Clazzio covers look good, but these look so much better. Another year or two and I’ll probably switch it up. First I need to find an upholstery shop in my area that isn’t run by meth heads.
  9. Feb 10, 2025 at 7:39 PM
    1lowlife
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    It does look nice..
  10. Feb 18, 2025 at 10:13 AM
    22OffRoad
    22OffRoad New Member
    2016 SR5 CM 4x4 TSS
    King Off Road Shocks, 33"s
    Looks great, write up has convinced me to pay an installer as well. Thanks for sharing!
    Black@Blue19 likes this.
  11. Mar 8, 2025 at 5:26 PM
    LoMile_21
    Rodney
    East Tennessee
    I had hoped to use the RainMan RMF-001 3-switch-panel insert for the Degreez switches in the console coin tray, but they are much too large to fit. So, I did what most of the other installers did and use the front of the console. I have seen pictures of the top but not of the bottom, so I included some pictures. The kit included a cardboard cut-out template, so I traced it out on a piece of blue painters' tape, cut it to size, and started the process of locating them. When I got it where it looked right, I drilled four holes at the corners to match the radius and used a artist gel pen to connect them for reference. I then heated the blade on a metal utility knife and cut them out. I final filed them to smooth them out. If you don't heat the blade too hot it cuts pretty good. I thought this would be a lot easier than trying to cut them out with a Dremel. I will say it was nerve wracking for me since the panel still looked new.
    Black@Blue19 and 1lowlife like this.
  12. Mar 8, 2025 at 6:24 PM
    1lowlife
    DADA
    2014 MGM DC SR5
    Nice, that's where I put mine.
    I installed them for my wife, but I use them a lot more than I thought I would..
