Fire Extinguisher?
Discussion in '3rd Gen Tundras (2022+)' started by Paul Moll, Feb 6, 2023.
  1. Feb 6, 2023 at 8:37 PM
    Paul Moll
    Paul Moll [OP] New Member
    Paul
    Idaho
    2023 1794 TRD off-road
    Has anyone figured out a good fire extinguisher and location to mount it in our Tundras? I live in Idaho and go into the high desert where there is brush that can catch fire from hot engine or catalytic converters. (Installing cat shield soon)
    I'd like to find something that fits behind the rear seat and is easily accessible.
    Suggestions or pictures appreciated. Thanks.
    2mchfun and RickyBobbysTundra like this.
  2. Feb 6, 2023 at 8:49 PM
    Outbound
    Aaron
    Northern Alberta
    I keep a 5lb one under my back seat.
    Wallygator and ColoradoTJ like this.
  3. Feb 6, 2023 at 8:50 PM
    It's not cheap, but I know Desert Does It has a bracket that mounts to their seat jackers.
  4. Feb 6, 2023 at 8:55 PM
    2mchfun
    I have mine at the base of the passenger seat. You can make a bracket for it easily.
  5. Feb 6, 2023 at 8:57 PM
    2mchfun
    In a roadside emergency situation, best to have your gear on pass side away from the traffic.
  6. Feb 6, 2023 at 9:19 PM
    Same...and in all my vehicles. Two on my rock crawler.
  7. Feb 6, 2023 at 9:19 PM
    Any photos of your setup?
  8. Feb 6, 2023 at 9:31 PM
    Tundra Fan
    Tundra Fan Got 17's?
    Toby
    Nor Cal (Placer Co.)
  9. Feb 6, 2023 at 9:46 PM
    reywcms
    reywcms New Member
    Rey
    Beaverton,Oregon
    2017 Tundra Platnium
    Too many mods to come
    Element fire extinguisher ftw
  10. Feb 7, 2023 at 7:15 AM
    OldMotoMan
    OldMotoMan New Member
    2022 Tundra DC SR5
    Yep, have heard good things about Element.
    https://elementfire.com/
  11. Feb 7, 2023 at 7:24 AM
    reywcms
    reywcms New Member
    Rey
    Beaverton,Oregon
    Got mine at the ready at driver seat
  12. Feb 7, 2023 at 7:36 AM
    coTony
    Tony
    Montrose, CO
    Same place I have mine in the Tundra and 4Runner
    2mchfun likes this.
  13. Feb 7, 2023 at 7:43 AM
    g6t9ed
    g6t9ed Novice Tundra Modder
    2017 Black CrewMax 1794 4x4
    Currently running a Bracketeer on both Tundra and FJ in the passenger seat. No issues so far and no passenger has mentioned issues with legs/feet getting bungled up with the extinguisher.
    Edit: Sorry, @Paul Moll. Realized that you stated pics as well.
    Here's mine from the usual seating position:
    And seat all the way back:
    And a closer look of the extinguisher and bracket setup:
    texasrho83 and 2mchfun like this.
  14. Feb 7, 2023 at 9:20 AM
    2mchfun
    Was gonna snap a shot, but heavy cold rain here and it obviously isn't a big deal really. Just have the factory extinguisher mount bolted to the Desert Does It seat jacker block. EZ because the hole is already drilled and tapped. Only small issue is the floor mat is not easily removed and inserted during routine interior cleanings. Anyway, attached is a picture of the unit I used. Over the years I have emptied somewhere between 5 and 10 similar units to assist others with automotive related fires. Worst one was a couple of college age females in a small hatchback that attempted an interstate u turn through tall dry grass and soft ground at a very slow rate. Always concerns me when I see people go to big events and park in the dry grass and such. When I was young, my dad ran out of gas on the highway and we did the walk of shame. Then I was cranking it over as he was sprinkling the carburator. It backfired and poof! Dad immediately threw his shirt on it, but that wasn't enough. Lesson stuck with me, and I have always been a fan of fire extinguishers. I keep them in cars, trucks, garage, camper, patio, kitchen, hallways. Plus I frequently give them as gifts to others who I see without what I think is enough. Screenshot_20230207-104241.jpg
    Cl8NL, 22whatwedo, Mater and 3 others like this.
  15. Feb 7, 2023 at 9:47 AM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    Same here. It takes up a fraction of space and weighs a lot less than a traditional fire extinguisher. Plus they supposedly work better.
    TampaRD Pro and mmasse like this.
  16. Feb 7, 2023 at 11:12 AM
    Mater
    Mater New Member
    Nick
    SD
    2016 MGM Platinum
    Rey, does that thing have an expiration date marked on it? It says on their website that it has an infinite shelf life. Curious if there are any marking on it..
  17. Feb 7, 2023 at 1:43 PM
    reywcms
    reywcms New Member
    Rey
    Beaverton,Oregon
    Please hold let me go check
    Mater[QUOTED] likes this.
  18. Feb 7, 2023 at 1:47 PM
    reywcms
    reywcms New Member
    Rey
    Beaverton,Oregon
    Negative on any expiration numbers. Great quality piece.
    TampaRD Pro and Mater[QUOTED] like this.
  19. Feb 7, 2023 at 1:52 PM
    snivilous
    snivilous snivspeedshop.com
    SW UT
    300k+ Supercharged 2008
    Disagreed. When I've messed with the element it's not at all intuitive how to get it going. We had some in a racecar and I did not like them at all, if I light on fire I don't have to think how to use a normal fire extinguisher nor do I require dexterity if my hands get burnt, the element needs to be uncapped and struck and all these steps require dexterity and visually aligning things. A child can use a normal fire extinguisher, an adult without experience with an element or incapacitated is going to take far longer to activate it.
    Joro43, Soupbean77, Donas and 6 others like this.
  20. Feb 7, 2023 at 1:55 PM
    reywcms
    reywcms New Member
    Rey
    Beaverton,Oregon
    Very valid points for sure
    Mater and RickyBobbysTundra like this.
  21. Feb 7, 2023 at 2:00 PM
    RickyBobbysTundra
    RickyBobbysTundra New Member
    Phoenix
    2023 Solar Octane TRD Pro
    Has anyone had to use a fire extinguisher on a vehicle before?
    I have not, but after speaking/reading with those that have, A lot of the little car fire extinguishers go out too quickly. I'm wondering if it'd be worth the upgrade of getting a larger fire extinguisher for the sole purpose of cya should you ever need more. Any thoughts?
    For me, glass breaker/crowbar and welding gloves (trying to rpy open a hot door) seem like just a good a fit as to rescue anyone in an emergency
  22. Feb 7, 2023 at 2:01 PM
    2mchfun
    Several times, see post #14
  23. Feb 7, 2023 at 2:03 PM
    RickyBobbysTundra
    Phoenix
    Thanks for the gentle reminder, not sure how I scrolled past. Definitely worth getting
    2mchfun[QUOTED] likes this.
  24. Feb 7, 2023 at 2:59 PM
    BoysandHisToys
    BoysandHisToys New Member
    Central Virginia
    2013 Tundra Crewmax Limited
    12” Bulletproof Lift, AFE CAI, AFE Exhaust, rock lights, Fas-Top tonneau and soft topper, Dasaita 10.2” radio, light bar, ditch lights, LED headlights and fog lights, LED interior lights, Amp Research rear bumper step, dashcam, BT ODBII reader and Torque app on radio
    I mounted mine in my decked drawer system. It’s not big enough to fully extinguish any fire, but enough to buy someone time to get out.
    TampaRD Pro likes this.
  25. Feb 7, 2023 at 3:29 PM
    TampaRD Pro
    TampaRD Pro Cunning Linguist
    Stanley
    Southwest Florida
    2020 MGM CM TRD Pro
    Lots.
    If you are going to the trouble and expense of putting any type of safety equipment in your truck (or anywhere else, for that matter) you should definitely take the time to train with it and figure out how to use it before you need it. I question whether and how an incapacitated adult can use an old school fire extinguisher at all or any easier than an Element.
    People are resistant to change, and they tend to stick with what they know and are used to. That's fine, too - any fire extinguisher is definitely better than none in the case of a fire in, on, or around a vehicle. Element type fire extinguishers have their limitations as well as their advantages, the better question to me is do the pros outweigh the cons in a vehicle type fire?
    The OP stated that they were concerned with creating brush fires from the cats or engine heat. An Element type extinguisher would not be ideal for that type of Class A fire out in open air, especially if there is a wind blowing that would disperse the gas. It still could help knock down a fire in brush to some degree but is certainly not the optimum choice for that circumstance.
    I went with an Element under my seat to specifically put out a fire in the enclosed space of the cab or engine bay that could be caused by an accident or electrical fire, which is a likely source of ignition for our trucks. The Element can be better for this type of incident as it does not displace oxygen in a space that may be inhabited by humans when deployed. If the doors are jammed and the windows up you will likely not suffocate yourself like you could with a CO2 extinguisher. Also, it doesn't create a breathing hazard, make a huge mess and destroy electronic equipment like a dry chemical extinguisher can when used in an enclosed space like a truck cab or engine bay. There is also benefit in the 50 second discharge time versus a shorter standard 5 lb. extinguisher discharge rate, as well.
    I do carry a standard 5 lb. extinguisher in my Diamondback Cross Bin box for use on the type of fires the OP mentioned. The right tool for the right job is always the best bet.
    Yes, on vehicles and in enclosed spaces on ships and land.
  26. Feb 7, 2023 at 3:40 PM
    Buckaroo
    Buckaroo New Member
    Central Ohio
    2017 Tundra 5.7L 4WD DC TRD
    2020 GD 2670MK Travel Trailer
  27. Feb 7, 2023 at 4:14 PM
    texasrho83
    texasrho83 DGAF#1
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
  28. Feb 7, 2023 at 5:40 PM
    TundraLtdCO
    TundraLtdCO New Member
    Daniel
    2022 Tundra Limited TRD
  29. Feb 7, 2023 at 6:19 PM
    TBS
    TBS New Member
    2021 SR5 CrewMax 4x4 Barcelona Red
    E50 extinguisher, Valhalla Plates, ESP Storage, Chrome Delete, Pwr Tailgate Lock,
    See post 25. Some good points there.
    On another note. In the video I noticed he was not really "sweeping" the fire like I was always trained. Again just a little change in technique might have made a bigger impact on the grease fire. Around the 30 second mark he almost had it snuffed because he started to sweep.
    I was a bit shocked with the wood fire. It seemed to snuff the flames but the heat from the coals seemed to restart the wood. It was a bit unexpected.
  30. Feb 7, 2023 at 6:59 PM
    Paul Moll
    Paul
    Idaho
    Thank you all for the great posts. This is very helpful.
    I have a 2.5 pound marine grade extinguisher on my UTV. Choose marine grade so that it's very weather tolerant. Inside the Tundra I don't see a need to go marine grade. But 2.5 pound may not be enough in some situations. The larger ones, 5 pounds for example, are quite a bit larger and probably more intrusive into the passenger compartment. Still need to check on what will fit where. But the one good take away I have is to keep it on passenger side of truck so as to have it on the non-traffic side. Good point.
    Eagleye and 2mchfun like this.
