Firestone Air Bags
Discussion in '2.5 Gen Tundras (2014-2021)' started by Beaudog, Oct 2, 2023.
  1. Oct 2, 2023 at 5:49 AM
    Beaudog
    Beaudog [OP] New Member
    Scott
    2020 Tundra Platinum
    Hi everyone, my 2020 Platinum has some major sagging issues with any serious load or my flat deck trailer hooked up so I am considering some air bags. I understand Firestone seems to be the best choice and the installation looks simple but does anyone have any tips or comments that might help guide me in this process? Thanks in advance.
  2. Oct 2, 2023 at 6:04 AM
    Mount the bottom in cradles not to the truck. So when the truck is on a lift there will be no stress on the bags.
    Daystar, Air Bag Cradle designed for full suspension travel, Fits All 6" diameter convoluted Air Bags, fits any full size of half ton truck, 2/4WD, KU09140BK, Made in America, Black https://a.co/d/21167ys
    ATV25, Joe333x and Northbound Train like this.
  3. Oct 2, 2023 at 6:27 AM
    rruff
    rruff New Member
    2016 Tundra SR DC Long
  4. Oct 2, 2023 at 7:58 AM
    apwisher
    apwisher New Member
    Everett, WA
    2007 CM SR5/TRD 4x4 White
    canopy, TRD Sway, audio
    I'm also looking into adding helper bags to my 2007. I've replaced the rear shocks with bilstein 5100s which i think lifted the rear about an inch or so. Will I need spacers for the bags?
  5. Oct 2, 2023 at 8:45 AM
    Downytide
    Downytide New Member
    GTA
    Lunar Rock with trail boxes
    No, use Daystar cradles, I'm probably about 1.5" taller than stock and it works perfect.
    ATV25 likes this.
  6. Oct 2, 2023 at 9:14 AM
    rruff
    rruff New Member
    Rear shocks don't lift anything... they just advertise that they can be used with a 1" lift. Actually, I guess the gas pressure might give you a tenth inch or so...
  7. Oct 2, 2023 at 11:22 AM
    apwisher
    apwisher New Member
    Everett, WA
    They did on mine. 0.75" in front and 1" at rear, just like they said they would. Leveled my truck like I wanted it to. This is what I got.
    Thanks, for this. I will get the cradles too.
  8. Oct 2, 2023 at 11:38 AM
    memario1214
    Colton
    Missoula, MT
    '21 Limited MGM CrewMax
    If you're still shopping bags/cradles we carry them all over here at Hotshot Offroad :thumbsup:
    And to support the comments by @rruff - A rear shock "shouldn't" provide any rear lift. That said, if you have shocks that are blown and/or are not providing any rebound support then a fresh set of shocks can definitely make that change. However, swapping fresh shocks to fresh shocks will not change ride height after settling unless one has significantly higher resistance to piston movement.
    Yotaholic and rruff like this.
  9. Oct 2, 2023 at 11:41 AM
    GeoJoe
    GeoJoe 2018 Tundra SR 4x4 5.7L Looooooooong Bed
    3/1 lift on 20" OZs with KOs, LED fogs, steps and a handle
    I have the Firestone Ride Rite setup. A few years after install the controller frizzed out. Firestone sent me a new one, no questions asked, no charge. My only regret is not getting the wired controller. The wireless one doesn't have enough range to reach from the cab to the box under the bed. But then again, maybe it's because of my loooooooooooooooooooooooooooooooooooooooongbed.
  10. Oct 2, 2023 at 11:48 AM
    apwisher
    apwisher New Member
    Everett, WA
    I'm pretty sure those Bilsteins are longer than stock shocks in the rear. That is where the lift comes from.
  11. Oct 2, 2023 at 12:06 PM
    memario1214
    Colton
    Missoula, MT
    I'm following your logic (and admittedly once upon a time I thought that was how it worked myself), but I can promise you 100% that's not how it works. You can put as long or short of a shock as you'd like in the rear end of these trucks, and as long as you are somewhere within the shock's travel at rest (as in not full compressed or fully extended) the ride height will not change but a couple of mm. Often times, right when you put a shock on and let the vehicle down the ride height will come in higher, but that is due to the shocks not getting compressed. A quick drive around will settle them in.
    The shock's primary job is to provide rebound and damping characteristics to the system. The lift, load carrying, etc is dictated by the coil springs up front, and the leaf springs in the rear.
  12. Oct 2, 2023 at 12:19 PM
    Winning8
    Winning8 New Member
    Da Bay Area
    2019 MGM DC 4x4 SR5
    Not if his old shocks are shot and all the gas leak out, the new shocks will lift the rear back to stock height.
  13. Oct 2, 2023 at 12:23 PM
    memario1214
    Colton
    Missoula, MT
    Joe333x likes this.
  14. Oct 2, 2023 at 12:30 PM
    Yotaholic
    Yotaholic Amateur Professional
    Lone Star Republic
    2011 TRD DC 4.6
    I have Firestone airbags on my otherwise stock rear suspension. They don’t seem to level the weight they claim to, but they definitely help. I have manual inflation valves for each side independently. I kept it simple that way.
  15. Oct 2, 2023 at 1:46 PM
    Danimal86
    Daniel
    Sacramento, CA
    2017 White Tundra SR5
    +1 for daystar cradles. If not, you have to remember to deflate the bags to 0psi prior to putting the truck on a lift (as per the manual)
    I started with a 12v compressor and a 7pin to cigarette lighter adapter to air up the bags and now have the airlift 74000ez onboard compressor. So nice to be able to lift/lower without leaving the drivers seat.
  16. Oct 2, 2023 at 2:28 PM
    _none_
    _none_ Poser
    2020 DC SR5 4x4
    I had firestone airbags with teh daystar cradles on my previous truck. Also ran the airbags inside the coils on a 4Runner. I wasn't a fan of either really. The ride was never as good as without the bags. Maybe others have a better experience.
    This truck i'm trying to avoid them. I'm currently running the RAS HD cranked up with pretty good success. The ride is still great, just end up with increased spring rate and pre-load. I have a topper and decked drawers, able to maintain about stock rake. If you are towing a heavy trailer frequently, maybe think of adding a weight distribution hitch.
  17. Oct 2, 2023 at 2:31 PM
    Yotaholic
    Lone Star Republic
    2011 TRD DC 4.6
    You have to find a sweet spot between airbag pressure and your rear suspension. If I have more than 12psi in my bags with no load it gets very bouncy for the worn out shocks I have.
  18. Oct 2, 2023 at 4:59 PM
    Beaudog
    Scott
    Thanks for all the info. I like the Firestones and will likely go with them as I don't haul heavy material a lot or tow a lot so just need something to level things out when I am. I heard that Firestone doesn't recommend the use of cradles with their airbags but lots of people seem to be running them with no issues so I'm not sure what that's about? I don't do any serious off roading so loss of articulation is not an issue for me. I'm mostly just on dirt and gravel roads on the farm and backwoods areas. I do like the ideas of not stretching the bags when on a lift though, that seems like trouble waiting to happen.
  19. Oct 4, 2023 at 2:02 PM
    737fixer
    737fixer New Member
    Son-of-B that's some fine looking dirt. Seriously, as a Phoenician it's like seeing a two-headed dog.lGYEmU0.jpg
  20. Oct 4, 2023 at 3:20 PM
    GeoJoe
    Hey thanks! This is clean compost. Interesting process, certification, etc. Cheap too! https://www.accgov.com/4457/Commercial-Composting
  21. Oct 4, 2023 at 4:20 PM
    blenton
    blenton New Member
    +70 for daystar cradles. As an added bonus, they make a pleasant, Monty-Python-esque clippity-clopp noise when you drive through a twist ditch and the bags leave the cradles then slot back in. My Firestones and Daystars have held up admirable for 100k+ miles.
    Why the trailer? That little thing should fit right in the bed like a Matryoskha nesting doll. Then you take TWO bedfulls of junk with you.
    If the bags aren't leveling you out, there' something weird going on. I've not run in to a situation where the bags weren't able to level things out; I may or may not have found a pallet of dry concrete mix in the bed at one point. No sag and I believe 50 psi in the bags. How they mysteriously go there I'm not quite sure.. They might have been lured by a small gaggle of block of cinder blocks in to the bed.
    My point is - I don't think most guys haul a pallet of concrete mix which is half the airbag's technical capacity, plus factory springs. If your bags are maxed at 100 psi and it's not leveled out, it's probably because you stole @GeoJoe 's mini-truck, loaded it in your truck bed, stole all his mulch compost to put in the bed of the mini truck, then used a tarp to make a redneck hot tub in the middle of the mulch in the bed of the mini truck that you loaded in the bed...
    GeoJoe[QUOTED] likes this.
  22. Oct 4, 2023 at 5:18 PM
    GeoJoe
    I thought about using the longbed to haul the mini truck, and then I'd need another even smaller truck to put in the back of the mini truck too.
  23. Oct 5, 2023 at 6:39 AM
    Yotaholic
    Lone Star Republic
    2011 TRD DC 4.6
    Well if 100psi is the max, then there’s no surprise it wouldn’t level a heavy load similar like you shared….I filled them to 50psi which is what I thought the max was. Operator error, as usual! :rofl:
  24. Oct 5, 2023 at 10:25 PM
    Novanosis
    Novanosis New Member
    I can recommend these. I've had them in since April and no issues whatsoever. Can't beat the price, the 5 star review is actually from me. I did not use the cradles.
    rruff[QUOTED] likes this.
  25. Oct 6, 2023 at 5:00 AM
    Pac12AfterDark
    Pac12AfterDark New Member
    Sick kei truck, do you like it?
  26. Oct 6, 2023 at 5:14 AM
    Ericbike6
    Ericbike6 So we're doing this shit today?
    Eric
    Austin, TX
    2019 Tundra TRD 4X4 sport
    Air bags, ARK liners, misc bullshit added also
    Another for the firestone air bags and cradles, one of the first things I did when I got my truck. Haven't gotten the dreaded rear spring sag yet, so maybe it's helping with the life of my springs?
  27. Oct 6, 2023 at 5:25 AM
    rruff
    rruff New Member
    About half the price of Firestone and Daystar, for basically the same thing.
  28. Oct 6, 2023 at 6:06 AM
    yakeng
    yakeng 3URFE Apologist
    2020 Tundra 4x4; 2014 Sequoia;
    ECGS Bushing; GCS Cooler RASHD; Fox 2.0
    I have Firestone airbags on my F-150 and they are certainly helpful for load assistance. One of the tubes on mine has started to leak after about 14 years of use and I need to redo it.
    Don’t do the license plate valves like I did and invest in an onboard compressor and switches that you can control from inside the vehicle.
    The manual valves are a PITA.
  29. Oct 6, 2023 at 6:21 PM
    Beaudog
    Scott
    Thanks for everyone's feedback. I have ordered the bags and will update once they are here and installed.
    _none_ likes this.
  30. Oct 7, 2023 at 4:16 PM
    White TRD 4x4
    White TRD 4x4 New Member
    I know you asked about airbags and already purchased them. However, I used to run these on my Tacoma and will likely put them on my Tundra before any long distance towing with my sailboat. They work great and you never have to worry about about airing them up or tearing a hole in them.
    Timbren SES Suspension Enhancement System SKU# TORTUN4 - Rear Kit
    Edit: or these off-road version which are shorter so they only start working after your springs sag a bit so they don't affect day to day handling.
    Active Off-road Bump Stops for Tundra, Colorado, Canyon & Frontier - R – Timbren
    lassiter1979 likes this.
