Firestone Riderite air suspension
Discussion in '2.5 Gen Tundras (2014-2021)' started by rds95991, Oct 3, 2019.
  1. Oct 3, 2019 at 3:21 PM
    rds95991
    rds95991 [OP] New Member
    2018 Super White Tundra CrewMax SR5 TRD
    Anyone have any experience with these?
    Thank you.
  2. Oct 3, 2019 at 4:39 PM
    Nm6300'asl
    Nm6300'asl New Member
    2022 DC SR5 4x4
    Oem tonneau, side steps, spray in liner. Trd skidplate.
    Nope, no one. They r garbage. Jk, they r the real deal.
    Jmad1997 and Tundyfundy like this.
  3. Oct 3, 2019 at 5:05 PM
    19TurdPro
    19TurdPro New Member
    2019 Tundra TRD Pro
    Yep. Easy install, good quality bags. I recommend a T fitting. I mounted the fill valve by the rear license plate. I've seen people do them underneath the gas tank lid and in the wheel well.
    I used them to reduce the hitch bounce from my trailer.
    Mwray8909 likes this.
  4. Oct 3, 2019 at 5:17 PM
    Windsor
    Windsor Why do I do this to myself?
    Homeless in Oregon
    2008 Tundra Crewmax 5.7L
    Some.
    They work well. Personally, if you can afford it, I suggest the self leveling kit with a T fitting added for an aux fill valve in a location of your choice.
  5. Oct 3, 2019 at 5:19 PM
    Zero One Actual
    Both Air Ride and Ride Rite are good companies. I actually have firestone bags and an airride wireless compressor. I purchased @Coachbuilder1 airbag spacers and it rides like a dream.
    Jmad1997 and Bigboitundra like this.
  6. Oct 3, 2019 at 6:42 PM
    easleycrawler
    Travis
    Easley, South Carolina
    17 Tundra SR5 DC Black 5.7
    I've got the Firestone ride rite on my truck. Highly recommend if you do any kind of towing.
  7. Oct 3, 2019 at 7:46 PM
    jeremyd
    jeremyd 2014 Crewmax SR5
    NV
    2014 SR5 CM 4X4
    ProComp 7" 35/12.50/18 -11
    I use my Firestone ride rite air bags all the time.
    aperezsh, Stocky Balboa and drobb like this.
  8. Oct 3, 2019 at 7:52 PM
    BTBAKER
    BTBAKER .
    Brad
    Castle Rock
    2022 Ram TRX Level 2
    I have them. They are awesome. It makes towing so much better.
  9. Oct 3, 2019 at 8:14 PM
    Windsor
    Homeless in Oregon
    Some.
  10. Oct 3, 2019 at 9:31 PM
    BTBAKER
    BTBAKER .
    Brad
    Castle Rock
  11. Oct 3, 2019 at 9:45 PM
    Windsor
    Homeless in Oregon
    Some.
  12. Oct 3, 2019 at 11:13 PM
    rds95991
    Thanks for the advise. Looking to get a trailer soon in the 4,000 to 8,000 loaded range.
  13. Oct 5, 2019 at 7:12 AM
    Sonicbluerider
    Sonicbluerider New Member
    Dennis
    2019 Tundra
    What model air bags?? Seens they have several. Putting a fourwheelcamper on .
  14. Oct 6, 2019 at 3:34 PM
    Sonicbluerider
    Dennis
    2019 Tundra
    is the 2445 the right kit???
  15. Oct 6, 2019 at 3:55 PM
    jeremyd
    NV
    2014 SR5 CM 4X4
    Yes
  16. Oct 6, 2019 at 5:08 PM
    6XC
    6XC OPS4
    '18 MGM Tundra SR5 TSS Crewmax 4x4
    Just noticed I have the Firestone bags installed on my truck. Bought it used about a month ago. Didn't think anything of the brass colored fittings on each side of the license plate. :eek:
    Bigboitundra likes this.
  17. Oct 6, 2019 at 6:04 PM
    Zero One Actual
    kbayashi likes this.
  18. Oct 6, 2019 at 6:06 PM
    6XC
    6XC OPS4
  19. Oct 6, 2019 at 6:09 PM
    Zero One Actual
  20. Oct 6, 2019 at 6:11 PM
    6XC
    6XC OPS4
    I ordered the Coachbuilder +2s so I'll need the spacers also. Hoping they can add them to current order to avoid extra shipping.
  21. Oct 6, 2019 at 6:16 PM
    Zero One Actual
    Yes, just email or call David tomorrow and he will make it right. I have the +3’s and Firestone bags and his airbag spacers. Rides perfectly. I am away from my truck for a few days but I will get pics when I can. I also installed my wireless compressor behind the left rear passenger seat so it is never exposed to the elements. It’s not loud at all and I can have normal volume conversation with passengers even while it is adjusting air pressure.
  22. Oct 11, 2019 at 3:37 AM
    Sonicbluerider
    Dennis
    2019 Tundra
    so what's a good air compressor!! looking at the 2158 or 2610
  23. Oct 11, 2019 at 4:35 AM
    snowmansimon
    snowmansimon New Member
    Simon
    New Brunswick, Canada.
    2019 Tundra SX Barcelona Red
    Firestone Air Bags, 255/70R18 BFG All Terrains.
    I installed the air lift bags which I found out have an internal bump stop. Stock truck and I was riding on the bump stop when empty. I removed them and installed the firestone bags and rides much better empty. The air ride bags had a similar feeling to using timbren bump stops.
    I haul an 1100lb slide in camper with mine. Rides great loaded up.
    HappyGilmore and Jim LE 1301 like this.
  24. Oct 11, 2019 at 4:36 AM
    lawfarm
    lawfarm New Member
    2018 Tundra SR5 Premium TRD Crewmax
    I have 1” lift blocks and 2” shackles in the rear. I used Firestone’s bracket spacer to space the inner bracket that rests on the axle tube, but did NOT use a spacer for the airbag itself. I did use the Daystar airbag cradles (which I highly recommend to preserve airbag life) I find that this is a better setup. When empty, the truck barely rests on the airbags, and it rides a lot better than it did pre-lift, without the harshness of the bags. When loaded, I can pump up the bags and get full support.
  25. Oct 11, 2019 at 4:40 AM
    Sonicbluerider
    Dennis
    2019 Tundra
    do use a on board air compressor?! if so which one??
  26. Oct 11, 2019 at 4:54 AM
    Welcome from NY.
  27. Oct 11, 2019 at 5:57 AM
    omgboost
    omgboost The Accountant
    East Coast
    2012 Sequoia Platinum
    Do any of the Tundras come with air suspension from the factory? I have it on my Sequoia and I must say, it makes it a comfortable ride. I always hear people say to not get airbags or replacing them out with regular suspension.
  28. Oct 11, 2019 at 5:58 AM
    Zero One Actual
    Look at the airlift wireless EZ kit. It’s the nicest most convenient one out there in my opinion.
  29. Oct 11, 2019 at 6:30 AM
    HappyGilmore
    HappyGilmore Ex 1st Gen Member
    Trent
    Lakewood CA
    2018 White Limited TRD 4x4
    Welcome.
    I have those Airlift on my truck as well and have the same problem. It hits those internal bumps just driving over a damn reflector in the road.
    Im tempted to take them off and put on Firestones.
  30. Oct 11, 2019 at 8:48 AM
    Zero One Actual
    That is why I went firestone bags and the wireless compressor, best from both companies.
