First generation dashboard cup holder
Discussion in '1st Gen Tundras (2000-2006)' started by 21TundraSX, Feb 18, 2023.
  1. Feb 18, 2023 at 2:01 PM
    21TundraSX
    21TundraSX [OP] New Member
    My cup holder will not fully close on my other 2000 Tundra SR5. Upon inspection, there are parts inside the sleeve that are broke. I'll need to replace the entire unit which will require part of the dashboard. Anyone have tips or is there a tutorial before I tackle this?20230218_161117.jpg 20230218_161108.jpg
  2. Feb 18, 2023 at 3:15 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    There's two 3(?)mm Allen head bolt/screws in the left hand side and right hand side of the slide.
    If you go to the passengers side, and slide the cup holder out, you can see the one on that side.
    Those are the only two bolts/screws holding in the cup holder.
    FrenchToasty likes this.
  3. Feb 18, 2023 at 3:17 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    There's another one on the drivers side.
  4. Feb 18, 2023 at 3:22 PM
    21TundraSX
    I'm aware of these Allen keys. They will allow me to pull out the cup holder, but I also need to pull out the sleeve which is attached behind the lower dashboard.
  5. Feb 18, 2023 at 3:27 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Oh... I haven't done that. Have you pulled the cup holder to see how it's attached?
    I can't remember off hand. I think that sleeve is plasti-welded to the dash?
  6. Feb 18, 2023 at 3:29 PM
    21TundraSX
    Yes, thanks. I'm hoping someone knows for sure how the sleeve is attached, and how to get to it.
  7. Feb 18, 2023 at 4:32 PM
    21TundraSX
    I guess I'll carefully remove the dash, and go from there. I'll work on it this coming week.
  8. Feb 18, 2023 at 5:48 PM
    Just a point of note: When you get the replacement, there should be a couple of screws (you can see in the top/inside) that'll let you remove the faceplace, if you need to replace the piece with the colored front. It'll make things easier.
    Toyota's exploded diagrams for the dash/instrument cluster make it look like it's sold as a complete assembly:
    https://parts.toyota.com/p/63229557/556200C010E0.html (Oak)
    https://parts.toyota.com/p/63050451/556200C010E1.html (Sandalwood)
    https://parts.toyota.com/p/63050451/556200C010B0.html (Dk. Charcoal)
  9. Feb 19, 2023 at 3:54 AM
    BubbaW
    Bubba
    Where Eagles Nest
    04 DC LTD 4X4 4.7 V8
    T150 Lover
    Have you removed the cup holder tray via the 2 screws ?
    The reason I ask is because there are 2 plastic spring loaded cams(my name) inside tray holder, one on each side, that have to rotate as you push tray back in. Perhaps one of them is stuck or an object has fallen in the way.
    With tray removed, you can stick screw driver or long tool to see if you can move/rotate the cams.
    As a side note for any 2004 owners dealing with this, our years use T10 torque bit to remove the 2 screws for tray removal
  10. Feb 19, 2023 at 9:09 AM
    BubbaW
    Bubba
    Where Eagles Nest
    T150 Lover
    Follow up if you're still around @21TundraSX or for others needing info....you'll have to remove what they refer to as the Lower Dash Panel Cover since cup holder/bracket is held in place with screw. The FSM does not mention step by step for that item. It will require removing glove compartment door and lower finish panel also.
  11. Feb 19, 2023 at 12:56 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    It's not that bad, just tedious to remove entire lower dash. I've had them out in both trucks but that was some time ago.
