Fitting 18”wheels on rough country 6” lift
Discussion in '3rd Gen Tundras (2022+)' started by Vennessa671$$, Feb 27, 2024.
  1. Feb 27, 2024 at 6:57 AM
    Vennessa671$$
    Vennessa671$$ [OP] New Member
    2023 tundra
    None
    Want to lift my 2023 tundra with rough country 6” lift but there telling me that I can’t use my 18”method wheels but I’ve seen on you tube other third gen owners use them on the same lift how or they doing that
  2. Feb 27, 2024 at 7:03 AM
    More offset?
  3. Feb 27, 2024 at 7:27 AM
    frichco228
    frichco228 Valued Member
    2016 Crewmax 4WD, TRD Offroad
    Their website gives specifics on wheel size, width and offset based on tires run and any other trimming needed. If you have other questions just call them
    https://www.roughcountry.com/product/configurable/toyota-suspension-lift-kit-71200
    Not sure what your goals are in lifting and use of the truck, but that is really high if you plan to use your truck as a truck. Then the fact that rough country is a low end lift and you will get what you pay for. Next, it is a bracket lift which has its own set of considerations and issues. So, do your research.
    BTW, you can fit 35s, even 37s with 2.5-3 inch lift and coilover lifts in that size ride and handle better than bracket lifts. They are also more reliable long term.
    GODZILLA and Rodtheviking like this.
  4. Feb 27, 2024 at 7:36 AM
    jeffcoseo
    jeffcoseo New Member
    Jeff
    Yeaaaaaaah. You can run any wheel you want. There might be More or Less rubbing. More trimming here, less there.
    But you can run 17, 18, or 20" wheels.
  5. Feb 27, 2024 at 8:05 AM
    teab
    teab 2023 Platinum w/ PRO bits
    Ty
    Denver
    2023 Platinum MGM 6.5
    TRD Pro Wheels, Go Rhino D6, Airlift bags/compressor, Talons Alum Cat Shield, Cheap-o Amazon Mud Flaps, Fastop Tonneau/Topper, Rear TRD Pro Shocks
    The Rough country Wheel knuckles for the 6" lift may not clear with a 18" wheel or something like that (probably offset as mentioned earlier). If RC says it won't fit....probably a reason they say it won't fit. But Hey OP @Vennessa671$$.....if you want to ruin the ride and usability of your truck with a 6" lift you're free to do what ever makes you happy. Maybe an 18" will work or maybe RC has a reason they say that. Also the Brodozer look isn't complete without 22's and Low profile MT tires that have fun names like "Mudfang" .. "Venom" ..."Terrain Beast"... "Lion Claw".... "Wildtraxx" etc. (I made a couple of those names up, but bet you can't tell which ones), so might as well go with at least a 22" rim or bigger. Just jabbing a bit...
    Breathing Borla and osu1978 like this.
  6. Feb 27, 2024 at 8:23 AM
    osu1978
    osu1978 New Member
    Can't wait to pick up a set of Mudfangs!
    teab[QUOTED] likes this.
  7. Feb 27, 2024 at 8:54 AM
    Rodtheviking
    Rodtheviking New Member
    Vancouver, WA
    Sequoia
    Don't cut the cross member.
    Sierradevil and Breathing Borla like this.
  8. Feb 27, 2024 at 8:56 AM
    Breathing Borla
    Northern Illinois
    going to ride like shit and get shit MPG, why go with a 6" Rough Country lift and not the 3" TRD lift that fits 35"s easy and is a quality lift ?
  9. Feb 27, 2024 at 8:59 AM
    teab
    Ty
    Denver
    Because 6" is bigger than 3"...Duh bruh!
  10. Feb 27, 2024 at 9:02 AM
    Breathing Borla
    Northern Illinois
    thats what she said:anonymous:
  11. Feb 27, 2024 at 9:06 AM
    teab
    Ty
    Denver
  12. Feb 27, 2024 at 9:10 AM
    b6graham
    b6graham New Member
    2020 Voodoo 1794 RW Wheels 315/70
    the curbs in the mall parking lot are quite large sometimes
  13. Feb 27, 2024 at 9:49 AM
    cmiles97
    cmiles97 New Member
    2018 Toytota Tundra SR5 4x4 XP
    XP package
    Sierradevil likes this.
