fitting 33s on my tundra
Discussion in '1st Gen Tundras (2000-2006)' started by jggeere, Dec 3, 2020.
  1. Dec 3, 2020 at 7:42 PM
    jggeere
    jggeere [OP] New Member
    jared
    2002 toyota tundra 4.7 4x4
    I am currently running 265/70/17 on my tundra with a 2 inch leveling kit (Bought the truck like that) but I want to put on a bigger tire, possibly 33s but I am new to everything and not sure how much I would have to lift the truck. Any advice?
    Edit: Whats the biggest tire I can fit without having to trim?
  2. Dec 3, 2020 at 7:46 PM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
  3. Dec 4, 2020 at 9:36 AM
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    With stock wheels the trouble is they have deep backspacing. If you want to run 285s you will need wheel adapters to space them out 1.25"
    You could look into 265/70/17 (almost 33) or 255/80/17 (skinny 33) tires. That way you can avoid wheel adapters and you'll not have much rubbing issues to address. You may have to trim slightly on the bottom corner of the bumper or trim the mud flap.
  4. Dec 4, 2020 at 10:46 AM
    Gmillz85
    Gmillz85 Ski Bum Extraordinaire
    greg
    2004 Salsa Red AC 4x4 Pro Edition
    She's a Pro
    -12et on the wheels is the magic number for no rub with 285s
    Darkness likes this.
  5. Dec 4, 2020 at 10:50 AM
    C.I.
    C.I. Surf, off road, sleep, repeat
    Cesar Pedrin
    Cabo, Mx
    2016 5.7 4x4 Bronze Crewmax
    Mods: Ongoing... probably never ending
    stock or aftermarket wheels?
  6. Dec 4, 2020 at 11:02 AM
    Gmillz85
    greg
    She's a Pro
    Aftermarket for me. Not sure if toyota made a factory wheel with a -12et
  7. Dec 4, 2020 at 11:40 AM
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    I prefer checking backspace over offset. Checking backspace is more constant (doesn't vary by width) and rubbing on the back side of the wheel is a show stopper, so maybe more important.
    That said, you're right, -12 works well for 8" or 9" wheel width for sure and anything wider than 9" doesn't belong on these trucks. If you go skinnier than 8" (who would do that) then you're in bad territory.
    jggeere[OP] and Gmillz85[QUOTED] like this.
