Fix for hyper flashing turn signal after replacing headlight
Discussion in '2.5 Gen Tundras (2014-2021)' started by Noclue, Oct 2, 2023.
  1. Oct 2, 2023 at 12:36 PM
    Noclue
    Noclue [OP] New Member
    2016 white tundra sr5
    I replaced my headlights assembly with led assembly now I have hyper flashing in turn signal. Does anyone know of a led compatible relay to replace the one that came on the truck.
  2. Oct 2, 2023 at 12:38 PM
    BoysandHisToys
    BoysandHisToys New Member
    Central Virginia
    2013 Tundra Crewmax Limited
    12” Bulletproof Lift, AFE CAI, AFE Exhaust, rock lights, Fas-Top tonneau and soft topper, Dasaita 10.2” radio, light bar, ditch lights, LED headlights and fog lights, LED interior lights, Amp Research rear bumper step, dashcam, BT ODBII reader and Torque app on radio
    Usually there is a resistor added to the circuit to prevent hyper flashing.
  3. Oct 2, 2023 at 12:44 PM
    Noclue
    I did see a resistor on the harness. But I still have the issue. I traced the clicking back to a relay under the dash left of the e brake
  4. Oct 2, 2023 at 1:18 PM
    BoysandHisToys
    Central Virginia
    Could be a bad resistor. I recently had that with one of my aftermarket tail lights. Replaced the resistor and working fine.
  5. Oct 2, 2023 at 1:40 PM
    Noclue
    Thanks will check into that
  6. Oct 2, 2023 at 2:31 PM
    mtucker
    mtucker New Member
    Escondido CA.
    2008 Double Cab
    Listed in my build thread
    I looked for a pop-in relay board replacement for my 2008 when I went to LED turn signals. I did not find one. Big ol' resistors in parallel with your LED bulbs should work, but replacing/changing the flash module is much cleaner. I took the turn signal board (yes, near the e-brake) and changed the current sense resistors (RS1 and RS2 designators on the PCB) to a higher value. I started off with about .12 Ohms since I had resistors I could parallel to get that (shown in picture), but occasionally I would get the hyper blink still so I changed to 0.15 Ohms and that was good (someone on a forum had suggested 0.15 Ohms and they nailed it). Tundra_flaher_resitor_change.jpg
  7. Oct 2, 2023 at 2:32 PM
    What set of headlights did you install?
  8. Oct 2, 2023 at 2:39 PM
    Noclue
    Junyan.
  9. Oct 2, 2023 at 2:46 PM
    Noclue
  10. Oct 2, 2023 at 3:29 PM
    Noclue
    Could this be what I need?
    Flasher; Flasher Assembly
    Part Number: 81980-0C010
    Other Names: Turn Signal Flasher, Flasher, Hazard Warning Flasher, Flasher Assembly Turn S Description: TURN SIGNAL. Fits Sequoia, Tundra Tundra. Sequoia.
    With drI. Combo-Flasher. With Daytime Running Lights. Cabin compartment, with daytime lamps.
    Instrument panel, with daytime run lamp. Instrument panel, 2014-17, with led running Imps.
  11. Oct 2, 2023 at 5:18 PM
    Noclue
    Think I found the problem. One row of my turn signal are not working.
  12. Oct 2, 2023 at 6:21 PM
    GeoJoe
    GeoJoe 2018 Tundra SR 4x4 5.7L Looooooooong Bed
    3/1 lift on 20" OZs with KOs, LED fogs, steps and a handle
    Make sure all of the connections inside the headlight housing are tight. I installed a new set and got a hyperflash. Turns out one of my bulbs was simply disconnected and that will cause it. You'll have to look deep in the housing to be sure.
  13. Dec 11, 2023 at 7:01 PM
    frieselu
    frieselu 13 years with a 1st gen; recent 2nd gen convert
    2008 Green CrewMax
    This was helpful for me, thank you. I had the same issue on my 2008. I followed this walkthrough and installed a couple of 0.15 Ohm resistors and that worked like a charm!https://www.youtube.com/watch?v=ORqtLwXfy-4
    Ruggybuggy and mtucker[QUOTED] like this.
