Fixed - Horn not working
Discussion in '2nd Gen Tundras (2007-2013)' started by jc702, Dec 27, 2021.
  1. Dec 27, 2021 at 11:38 AM
    jc702
    jc702 [OP] New Member
    jose
    Las Vegas
    So after reading plenty of threads, seems like the clock spring is the culprit.
    Fuse is good and when test the wires going to the horn when the steering is pressed, the voltage doesnt change.
    All of the other buttons on the steering wheel work fine just not the horn.
    Could it be a wiring issue or the entire clocks spring itself?
    wired an aftermarket horn to see if maybe it was the horn and still doesnt work.
  2. Dec 27, 2021 at 1:21 PM
    D4x4TRD
    D4x4TRD New Member
    Định
    Va beach, VA
    2012 Sr5 DC TRD 4x4 Blaaaaaack baby 4.6liter
    Blacked out front grill badge Bigger tires 305/60r18 Tonneau cover
    When my horn wasn’t working I changed the clockspring. Worked again. Everything else worked just fine. Just not the horn. Sometimes if I turned the steering wheel enough I could get it to work. But end result was change clockspring and everything worked good again. Mine is a 2012. The horn went out around 70,000 miles. I’m at 87,000 mi. Now and horn still working. Good luck.
  3. Jan 2, 2022 at 6:30 PM
    jc702
    jose
    Las Vegas
    Fixed, it was the clock spring.
    Took about 10 mins to do and works great thanks!
    D4x4TRD likes this.
  4. Jan 6, 2022 at 7:53 PM
    baraynavab
    baraynavab Toyo Junkie
    Atlanta
    I had a similar issue. Where I had not only my Horn but also my Cruise control not working. I swapped out a cheap $13 dollar clock spring from ebay. And everything worked after replacing it. BTW they were more expensive clock springs on ebay. I got the cheapest one and it did the trick. I bet its the same one compared to the higher $ ones. So dont waste your money on the more expensive ones.
  5. Jan 6, 2022 at 8:25 PM
    jc702
    jose
    Las Vegas
    That’s where I got mine lol
    They went up I paid $19
  6. Jan 30, 2024 at 7:56 AM
    jham101
    jham101 New Member
    So the horn on my 2012 tundra just went. The alarm on the car still works. Is there any way to diagnose this issue as a clock spring problem before I order the part? thanks
  7. Feb 1, 2024 at 9:50 AM
    GSil
    GSil New Member
    2013 SR5 DC Tundra
    the alarm working still is the test, and exactly what was wrong with mine. Clockspring replacement fixed it for me.
