Flasher Module Location?!/rant
Discussion in '2.5 Gen Tundras (2014-2021)' started by Aliceoffroad, Sep 9, 2021.
  1. Sep 9, 2021 at 1:33 PM
    Aliceoffroad
    Aliceoffroad [OP] New Member
    Jennie
    2018 DCLB 4x4 Tundra
    Too many to list
    Just got some new Morimoto headlights for the tundra to upgrade from the old eBay specials I had. I read all over the place everything about these headlights, pretty good reviews besides all the install problems. Welp, the install problem has shown itself. Hooked everything up and blew out the flasher module for my blinkers/hazards, it’s 100% the module, both interior and exterior fuses and relays are fine and there is no dash light or sound and obviously no blinkers all the way around however everything else works. I’ve looked everywhere I can not find this friggin module, it is NOT by the ECU or anywhere I can see under the steering wheel by the steering column. I’m at a loss lol. SOS
    Edit: I guess the 2018’s don’t have the separate module anymore? It’s integrated into something else? Does anyone know who what where how why?
  2. Sep 9, 2021 at 3:56 PM
    frichco228
    frichco228 Valued Member
    2016 Crewmax 4WD, TRD Offroad
  3. Sep 9, 2021 at 4:24 PM
    Damn....I didn't have any issues at all when I installed mine.
  4. Sep 9, 2021 at 4:51 PM
    Aliceoffroad
    Jennie
    Too many to list
  5. Sep 9, 2021 at 4:51 PM
    Aliceoffroad
    Jennie
    Too many to list
    WHAT. Can’t be, pics pleaseeee?
  6. Sep 9, 2021 at 4:53 PM
    I've had them for a year with no issues at all.
  7. Sep 10, 2021 at 6:04 AM
    Aliceoffroad
    Jennie
    Too many to list
    Oh your headlights... Thought you meant you replaced the module
  8. Sep 10, 2021 at 6:45 AM
    https://www.sparksparts.com/oem-parts/toyota-flasher-flasher-assembly-819800c020
  9. Aug 24, 2024 at 2:17 PM
    Bradmoles1135
    Bradmoles1135 New Member
    2021 Tundra SR5 TRD sport
    I created an account because I have been Googling for hours and cannot find where they moved the flasher relay in 2018. Did you ever figure it out?
  10. Aug 24, 2024 at 2:20 PM
    Danman34
    Danman34 New Member
    Danny
    2018 White Tundra TRD Sport
    There is no flasher module. Everything goes through the ECU.
  11. Aug 24, 2024 at 2:34 PM
    Bradmoles1135
    Okay. My left flasher is not getting any power (front, back, trailer, hazard). I have all LED’s in a 2021 SR5. Where can I check on the ECU for my left flasher?
  12. Aug 24, 2024 at 2:37 PM
    Danman34
    Danman34 New Member
    Danny
    No where on the ecu. You need to check each circuit individually. Or Check the fuse.
  13. Aug 24, 2024 at 2:43 PM
    Bradmoles1135
    No fuse burnt in kick panel of engine compartment. What “circuits” can I check? Would resetting the issue potentially fix it?
  14. Aug 24, 2024 at 2:49 PM
    Danman34
    Danman34 New Member
    Danny
    Each light is a circuit. You said one side isn’t working then listed a bunch of other items. What exactly is or isn’t working? I don’t know what resetting means. There’s nothing to reset.
  15. Aug 24, 2024 at 3:04 PM
    Bradmoles1135
    The left turn signal does not work on the front, back, or my trailer but the right does. If I put the hazards on only the right flashes. I know an EUC can be reset by unplugging the battery for about 15 minutes then reconnecting the battery
  16. Aug 24, 2024 at 3:14 PM
    Danman34
    Danman34 New Member
    Danny
    Did you change any of the bulbs recently? Or did it just stop working?
  17. Jan 10, 2025 at 1:13 PM
    Jsums
    Jsums New Member
    Not sure who this helps, have to replace my 2018 flasher module and couldn’t find anything till I found this.
    Oolypoolay likes this.
