Flat Tire and Crushed TPMS Sensor. Who is Right?
Discussion in 'Wheels & Tires' started by JJ2000, Apr 20, 2023.
  1. Apr 20, 2023 at 6:06 PM
    JJ2000
    JJ2000 [OP] New Member
    Guys,
    Couple of days ago, I had a flat tire on my 2019 Tundra. As a side effect, a TPMS sensor was crushed. A nearby car shop was able to fix the punctuation, but they explained to me that b/c the sensor is in pieces (I saw that), it cannot be installed back and therefore they won't be able to inflate the tire as lack of such sensor will cause air leaks. They sounded convincing, charged me $160 for a new sensor, and told me that I need to drive a few miles until the TPMS calibrates. Obviously that didn't happen. I drove back, and asked them to fix that - that time they admitted that they don't have a computer capable of programming TPMS for Tundras 2018+ and all I have to do is go to the nearest Toyota dealer to program it.
    Toyota tech stated that the sensor they put it is s a piece of crap and they can't do anything with it. He also stated that TPMS sensor (or lack of it) has nothing to do with air leaks / ability to inflate the tire. When I got back to the original car shop for refund, they turned it down stating that they charged me for a sensor, not for its programming.
    I p**d! Please advise who is BS me?
  2. Apr 20, 2023 at 6:11 PM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    The first place is hosing you hard.
    ColoradoTJ likes this.
  3. Apr 20, 2023 at 6:14 PM
    Azblue
    The Dirty T ( ^_^)_且
    Sounds like that shop bent you over. To the best of my knowledge, you can just put a standard rubber valve stem in. Also, I just delt with this on my wife's Venza. Took it to Discount tire, $60 per sensor installed and programed.
    ColoradoTJ, Y0TA PR0 and Gravy like this.
  4. Apr 20, 2023 at 6:20 PM
    RCwyoming
    RCwyoming New Member
    RC
    2019 Tundra 4X4 CM MGM
    Social media is amazing for situations like this.
    ColoradoTJ, Y0TA PR0 and Azblue like this.
  5. Apr 20, 2023 at 7:25 PM
    Y0TA PR0
    Y0TA PR0 Oil & Gas
    Rafael
    2017 TRD PRO
    ^this. They lied to you to make you buy a sensor.
    ColoradoTJ and Azblue[QUOTED] like this.
  6. Apr 20, 2023 at 8:12 PM
    rruff
    rruff New Member
    2016 Tundra SR DC Long
    You were screwed. The least you can do is tell us the name of the shop.
    And next time don't believe anything a shop tells you unless you have a good reason to trust them.
  7. Apr 21, 2023 at 4:58 PM
    crewmaxlmt
    crewmaxlmt How dare you!
    scott
    2020 Crewmax Limited
    Dispute the charge on your credit card. They basically sold and installed a non compatible item for your truck.
    Randy Morton, Gaston, rruff and 2 others like this.
  8. Apr 21, 2023 at 7:29 PM
    Musicmasterd12
    Musicmasterd12 New Member
    Southern Louisiana
    2011 4.6 Silver Sky Metallic DC
    Yea they lied. I’d def dispute charge on credit card and blast the company
    rruff likes this.
  9. Apr 26, 2023 at 11:47 AM
    OEM sensors are about $68.00 average. They definitely got you there. I'm not sure about the 2018, but on the 2020's, you don't need to program the sensor. The truck recognizes it. As long as its a correct sensor, you do it yourself. They are definitely full of crap...there is no difference between a TPMS sensor and a regular valve stem when it comes to inflating a tire and holding pressure.
  10. Apr 26, 2023 at 11:53 AM
    Gaston
    Gaston New Member
    Gary
    SE MI
    2021 White Tundra SR5 CM TRD Sport
    If the shop won't take the non functioning item back and issue a refund this is the route I'd take next.
  11. Apr 26, 2023 at 1:43 PM
    blackdemon_tt
    blackdemon_tt Battery Slayer
    Damn.... They got you. I also punctured my tire a long time ago, and drove 2 miles, maybe more I know I'm irresponsible, with a flat tire to a nearby tire shop. I watched them dismount the tire and remount the tire with no damage to the sensor. They haven't worked in years, and my idiot light is still on.
  12. Apr 26, 2023 at 1:48 PM
    texasrho83
    texasrho83 DGAF#1
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Shady ass shop!
