Flat Towing
Discussion in '2.5 Gen Tundras (2014-2021)' started by Seadawg1, Mar 9, 2022.
  1. Mar 9, 2022 at 9:42 AM
    Seadawg1
    Seadawg1 [OP] New Member
    Larry
    Northwest
    2017 Gray Toyota Tundra, DC, SR5, TRD PRO
    Has anyone flat towed their Tundra behind a RV. I have a 2017 5.7 Automatic. I havre tried a search but came up empty. yhx
  2. Mar 9, 2022 at 10:04 AM
    frichco228
    frichco228 Valued Member
    2016 Crewmax 4WD, TRD Offroad
  3. Mar 9, 2022 at 10:21 AM
    Seafury
    Seafury Kickin names, and takin ass!
    Agent K
    SC Low Country
    2014 White 1794 "SnowWhite aka the Frost Queen"
    Bilstein 6112/5160, 3 CB front shims, SPC UCA's, CB +3 rear Shackles, total 3/2 lift, Dif drop, CB Carrier bearing drop, Fortin Evo One remote start from Tech12volts PnP, AMP research Powersteps PnP, Vent shades, Tinted windows, Black/Red lined cupholder inserts, Proclip USA dash phone mount with Scosche Magic Mount wireless magnetic phone charger, Stock wheels/tires for now.
    I am fairly certain the owners manual tells you how it is acceptable to tow the Tundra.
    I do not know as I have not needed to do this, and when any of my vehicles break down (hasn't happened in a long time now) I ALWAYS request a rollback truck.
    Flat towing is likely going to wear things out and probably damage some things.
    I would not even consider it personally.
    Seadawg1[QUOTED][OP] likes this.
  4. Mar 9, 2022 at 10:37 AM
    Kanobi13
    Kanobi13 New Member
    Yes please reference manual.
    Seadawg1[OP] likes this.
  5. Mar 9, 2022 at 7:11 PM
    04rktaco
    04rktaco New Member
    Lee
    California City
    2014 SR5 TRD crewmax 4x4
    All-pro rocksliders RCI aluminum skidplates TRD pro suspension TRD pro exhaust coachman 1inch lift shackles cooper tires
    Think rear tires need to be off the ground or disconnect drive shaft at diff and tie shaft up but owners manual should show you. Tundra is way too much truck to tow behind a motor home.
    Seadawg1[OP], hANNAbONE and Seafury like this.
  6. Mar 9, 2022 at 7:45 PM
    Kanobi13
    Kanobi13 New Member
    :smack:
  7. Mar 9, 2022 at 7:48 PM
    Kanobi13
    Kanobi13 New Member
  8. Mar 17, 2022 at 9:14 AM
    Seadawg1
    Larry
    Northwest
    Thanks all, I knew that was the answer, however I had read that it could be done, and I did not think that was right.
  9. Mar 17, 2022 at 9:29 AM
    Downytide
    Downytide New Member
    GTA
    Lunar Rock with trail boxes
    You can in a pinch, but you need to disconnect the rear driveshaft.
  10. Mar 17, 2022 at 9:51 AM
    Alternative in a pinch, you could flat tow the Tundra behind another vehicle in neutral with the engine running. Not sure what the situation would be where this would be the solution, but if the engine was running, the transmission pump is on and cooling the trans preventing damage.
