Fluid Film Undercoating
Discussion in 'General Tundra Discussion' started by Normanthegreat, Oct 26, 2023.
  1. Oct 26, 2023 at 8:08 AM
    Normanthegreat
    Normanthegreat [OP] New Member
    Just got a quote to get my tundra undercoated with fluid film for $2300. The truck isn't the rustiest I've ever seen but I was wondering if yall think $2300 is a good price for "a weeks worth of work." I personally think it is but wanted to see what yall think.
    Also shoutout to Keith @dirtydeeds for the new muffler. I called that man about 100 times and he was happy to answer my questions every time. He should have charged for my calls.
  2. Oct 26, 2023 at 8:13 AM
    TundraMidwesterner
    TundraMidwesterner What?
    Northern Illinois
    2019 Magnetic Gray Metallic CrewMax TSSOR 4x4
    Katzkins, Rostra heated seats(4), Tint (all), TRD rear sway bar, TSS wheels, OEM black lug nuts and wheel locks, OEM LED black fog lights, Driver side grab handle, Rough country LED Bumper bar, Rough Country Hard tri fold tonneau cover, AVS ventshades, Bilstein 5100's on top setting in front, Ready lift 1 inch ready block in the rear with Bilstein 5100's. Fluid Film. ESP under seat storage. LED interior lights and cargo lights swapped. Rear USB charger port swapped for 12v port. Remote start. Leather wrapped steering wheel kit. TRD shift knob. Kenwood dmx1037s. Hertz K170 door speakers/ tweeters, Infinity Reference 7005A 5 channel amp, 2 JBL WS1000 10 inch subs. DDI Seat Jackers. RCI engine Skid and Vahalla's Shields (front and rear) 1/4 aluminum. Stillen intake. LED Pro Headlights with iHacker harness. Cartrimhome auto up and down window switches. Coupe's aluminum battery tie down. Color matched mirror caps. Color matched door handles. Chalk bag cup holder. NFab podium step bars, herculined. Powerstop z36 drilled slotted brake discs w/ceramic pads.
    For 2300 they must be grinding and repainting the frame first? I had mine coated two years ago when the frame was still fresh and all they needed to do was spray over the painted frame. That was only $175. some places charge closer to $200 in my area.
    Edit: looking at the pictures you posted, if you trust this shop to do a good job grinding ALL the way down and hitting with metal etching primer/paint then fluid film it may be worth it. If you don't have access to a lift to do it yourself. I'd be worried about how complete of a job they would do around things like your brake lines. it does look like a solid amount of surface rust.
  3. Oct 26, 2023 at 8:15 AM
    LarryDangerfield
    Tyler
    Northern Wisconsin
    You just wait
    For that price they should be scraping and wire-wheeling all loose rust, repainting everything so it looks new underneath, and then fluid filming everything after it's all painted up.
  4. Oct 26, 2023 at 8:22 AM
    Normanthegreat
    Yes well they seem like a very reputable shop. Have a lot of good reviews and do a lot of Toyotas so that's the reason I'm debating this. Also the owner seems like a down to earth guy. I dont have a lift or the space for a lift otherwise I would have done it myself. Definitely going to ask for pictures during the process tho
  5. Oct 26, 2023 at 8:23 AM
    Normanthegreat
    There not repainting it I don't think. But they are grinding everything down power washing and then undercoating.
  6. Oct 26, 2023 at 8:29 AM
    king.cong.1119
    king.cong.1119 New Member
    if this is to just applying fluid film, the price is ridiculously high, my local shop charges about $300-500 for the job.
    also keep in mind, fluid film gets washed away, so if you are going with fluid film, that has to be done on a yearly basis.
    For over 2k price, I would think you can get the entire frame repainted.
    Have you considered other options than fluidfilm? say CRC spray?
  7. Oct 26, 2023 at 8:29 AM
    TundraMidwesterner
    Northern Illinois
    my concern with not doing any kind of repainting or priming would be having to keep up meticulously with spraying more fluid film. Lets say you ran over a small tree branch laying in the driveway you didnt see after a storm or something that could wipe away a line in the fluid film. That raw metal is going to rust in a matter of a few days.
    king.cong.1119 likes this.
  8. Oct 26, 2023 at 8:30 AM
    NWPirate
    Zach
    WA
    I would get a quote on paper of exactly what they plan on doing, with prices.
    That way you have a legal document if they they don't do everything promised, that's a lot of money.
  9. Oct 26, 2023 at 8:39 AM
    BravoDeltaRomeo
    Bruce
    MB Canada
    2019 Cavalry Blue Tundra CM
    It's a terrible price.
    Xcumminsguy and Terndrerrr like this.
  10. Oct 26, 2023 at 8:42 AM
    Normanthegreat
    This was a concern of mine but I was also concerned about painting it because the rust will just continue to grow and the paint will flake off which is what's happening right now.
  11. Oct 26, 2023 at 8:43 AM
    whodatschrome
    whodatschrome New Member
    North of North Plains, Oregon
    lots of dents
    I would think for $2300 you could remove the frame from the truck, have it sandblasted, then galvanized, and then reinstalled.
    Lake.Life24 likes this.
  12. Oct 26, 2023 at 8:43 AM
    Normanthegreat
    I havent heard of CRC.
  13. Oct 26, 2023 at 8:44 AM
    Normanthegreat
    Lol that's what I was thinking as well tbh
  14. Oct 26, 2023 at 8:44 AM
    TundraMidwesterner
    Northern Illinois
    if its ground down to bare metal, there are corrosion inhibiting primers that would keep most of this down to a minimum. fluid film will act similar to penetrating oil and soak in.
  15. Oct 26, 2023 at 8:46 AM
    Normanthegreat
    So you're saying the fluid film would basically soak in through the primer and protect rust from flaking it off?
  16. Oct 26, 2023 at 8:53 AM
    TundraMidwesterner
    Northern Illinois
    in a perfect world you would grind past any rust to bare metal and the primer would adhere perfectly and you would be all set.
    In reality I would think grinding, painting and fluid film all combined with reapplication of fluid film every couple years (depending on use) would be your BEST case scenario. There are also products like Woolwax that may last a little longer. I don't think there is a perfect solution otherwise everyone here would swear by one option or Toyota would do it to begin with.
    my Tacoma was part of the frame recall and I'm trying to avoid going through anything like that again. All we can do is try to slow it down.
    I try and avoid underbody car washes with fluid film coating and it seems to be hanging on pretty well. I also keep a can in the truck and do touch ups whenever I work on something. Things like the front of the diff I'll recover myself a couple times a year with a quick spray. Some areas get washed off pretty easy just from driving in a heavy rain on the highway.
    it also should be noted that what a shop applies with a spray gun for fluid film sticks a lot better than what you get from the aerosol can
  17. Oct 26, 2023 at 8:54 AM
    blackoutt
    blackoutt YEAH BUDDY!
    Indy
    07 DC Long Bed - Old Man Tan
    OEM+
    Or....
    $160 with coupon code "flash"
    https://www.kellsportproducts.com/W...1-ONE-Gallon-Kit-with-PRO-GUN-Wands_p_45.html
    $299 near me, I didn't bother looking up discounts
    https://www.homedepot.com/p/Husky-2...tical-Electric-Air-Compressor-C202H/312074157
    I do mine on the ground or some small ramps. You could buy this and put a gallon of wool wax on every year for many years to come plus other vehicles too, AND have an air compressor for other jobs. BTW I've done 3 vehicles with a gallon, I don't know where guys are putting so much of this stuff but I suppose the more the merrier. Woolwax sticks better and doesn't stink as bad as fluid film.
    EDIT: I looked at some of the pictures in the zip file. You're going to want to clean that frame up and treat/paint it first.
    I've done it myself before with wire wheeling (not to bare metal), phosphoric acid rust converter, chassis saver paint, and rust oleum topcoat. Also without a lift, but it did take me about a weeks worth of work and makes a huge mess. $2300 is probably worth it if they are doing a full cleaning and restoration of the frame. The fluid film is just a small fraction of that total charge then. Get it all in writing.
  18. Oct 26, 2023 at 9:05 AM
    Bprose
    Bprose Old member
    VA
    17 Tundra CM TRD
    If they clean all that rust up and treat it, do yourself a favor and get a kit to diy it yourself next year.
    I just did mine a week ago, used about a half gallon of fluid film. I’ve got a cheap HF compressor and a $20 application gun off Amazon.
    Do it on some ramps on lawn or something, it’s easy but messy so you don’t want it on your driveway.
    Normanthegreat[OP] and blackoutt like this.
  19. Oct 26, 2023 at 9:18 AM
    Normanthegreat
    Do you know if you can fluid film over CRC?
  20. Oct 26, 2023 at 9:20 AM
    Normanthegreat
    Have you noticed any rust on the spots where the fluid film gets easily washed away?
  21. Oct 26, 2023 at 9:22 AM
    king.cong.1119
    I don't see why not but I have coated my frame with crc rust inhibitor and its a thick solid layer of wax, won't be easily washed away, and it stays on the frame probably forever.
  22. Oct 26, 2023 at 9:31 AM
    TundraMidwesterner
    Northern Illinois
    No but my frame/undercarriage was almost completely spotless. I bought my truck used from Texas then only saw salt the end of February-March the first year I had it, maybe one or two snow storms before the first time I coated it with minimal time on the road. Last year I had it touched up. The person I had doing it moved away (was just one guy in a single bay shop on his property) I was not planning on touching it up again this year but he is coming back to town in a few weeks and has some product left here and asked if I wanted a recoat so I may get it done again in the next few weeks. that will be 3 years in a row. his original recommendation was once every two or three years for touch ups. I'm probably going overkill on it but it doesn't look like too much or too little coating. I just had a buddy pay a shop to do a double coat on his new RAM and it looks like they dunked the bottom half of his truck in black sludge.
    Ram double coat:
  23. Oct 26, 2023 at 11:23 AM
    dondino
    dondino New Member
    don
    2007 Tunda Crewmax
    I wouldn't pay that type of money. I just had my 07 done in NH oil Black for 180.00. 2300 is insane.
    Normanthegreat[OP] likes this.
  24. Oct 26, 2023 at 11:35 AM
    Gainer
    Gainer New Member
    Columbus, OH
    2018 SR w/8' Bed
    Leveling kit, TRD wheels, remote start, Hellwig helper springs, TRD Rear sway bar. TRD Rear shocks, Dirty Deed 10" exhaust, S&B Cold Air intake
  25. Oct 26, 2023 at 11:47 AM
    Terndrerrr
    Terndrerrr 925000 miles to go
    Music City
    6UR-FE
    For $45 and minimal elbow grease, I clean my frame and spray it with Amsoil HD Metal Protector. 3 cans takes care of it. I started doing this every Fall right when I bought my truck, so I have never had to wire wheel anything.
    The HD Metal Protector smells bad, but it goes away in a day or two. Wear old clothes, an N95, and some safety glasses when spraying this stuff under the truck.
    Pro tip: if you apply this stuff outside, you will want to be aware of the wind direction at all times. :thumbsup:
    Jim LE 1301 and NWPirate like this.
  26. Oct 27, 2023 at 6:11 AM
    Bammer
    Bammer I'm disinclined to acquiesce your request.
    Monroe, CT
    2019 Tundra SR5 TRD Crew Max 4x4
    NHOIL. $265 every 18 months
