Flushing brake fluid
Discussion in '3rd Gen Tundras (2022+)' started by Jsmittyy, Oct 30, 2023.
  1. Oct 30, 2023 at 9:23 AM
    Jsmittyy
    Jsmittyy [OP] New Member
    2022 magnetic gray platinum
    Do you guys flush your brake lines? I’ve heard things about it being gimmicky and just a money maker.
  2. Oct 30, 2023 at 9:28 AM
    Bprose
    Bprose Old member
    VA
    17 Tundra CM TRD
    I have on several older vehicles. Like 10 yrs and older, you’ve got a 22 according to your profile, you shouldn’t have to worry about it for a long time.
    If you’re asking because of your other vehicles, maybe be a little more specific, pics if you have them.
    Jsmittyy[OP] likes this.
  3. Oct 30, 2023 at 9:32 AM
    Jsmittyy
    I have a 22 platinum and the dealership was trying to sell me a brake fluid flush for $225 and I thought that sounded incredibly high and I’ve heard of vehicles going their whole lives without one. 250k miles plus.
  4. Oct 30, 2023 at 9:36 AM
    iforceAZ
    iforceAZ New Member
    Maybe at 5 years.
  5. Oct 30, 2023 at 9:43 AM
    Bprose
    Bprose Old member
    VA
    17 Tundra CM TRD
    Wow, if you’re going to let dealership service your truck you should maybe look fora different dealership.
    Where are you located, maybe another forum member can recommend one.
  6. Oct 30, 2023 at 9:52 AM
    drewpweinerMD
    drewpweinerMD MPG’s are for your moms Prius.
    Jeremy
    2024 Limited TRD OR
    RB20 Slims, BAK X4s, Fabtech Level, Cooper 35's
    Brake fluid is hygroscopic - meaning it absorbs water naturally. Its a good idea to change your brake fluid at regular intervals
    Tundraaa3 and Eurodriver like this.
  7. Oct 30, 2023 at 10:03 AM
    Bprose
    Bprose Old member
    VA
    17 Tundra CM TRD
    I agree, I don’t think it would need to be changed within a year though, maybe the reservoir cap was off.
  8. Oct 30, 2023 at 10:16 AM
    TundraTT
    TundraTT Full Send
    23 Taco Trail 97 FZJ80 68 Goat
    Generally every 3 years or when changing pads is a good rule. Like someone stated already, brake fluid absorbs water. Water in lines are no bueno and cause corrosion and squishy brakes
  9. Oct 30, 2023 at 10:26 AM
    Kap1
    Kap1 New Member
    San Francisco, CA
    The Car Care Nut recommends to change brake fluid every few years or so when you're changing your brakes, forgot about the exact recommendation but yes it's a good thing to change brake fluid if you're planning to keep truck for a long time
    https://youtu.be/jpiXOBRkZs4?feature=shared
    Mattedfred, OHwendTrd and TundraTT like this.
  10. Oct 30, 2023 at 11:08 AM
    Oldandfat
    Oldandfat New Member
    Cannuckastan
    2024 SR5 TRD Offroad Lunar Rock
    I’m guilty of never changing it. I change oil, diff’s, transfer case, tranny, radiator, and steering fluid (not anymore)
    I have a brake fluid tester that told me my 11 year old truck was fine. But I paid 20 bucks for it off of Amazon so who knows if it’s accurate or not?
    I’ve talked to mechanics who,say,don’t bother.
    I change my pads and rotors. Twice a year (winter,tire,swap) I remove, clean, and lube the sliders.
    Hank Hill likes this.
  11. Oct 30, 2023 at 12:05 PM
    BoulderGT3
    BoulderGT3 New Member
    Glen
    2023 1794 4X4 BP/Saddle ADV Steps
    On track cars I flushed the brake fluid every day.
    I flush every 4 yrs on street cars. Every 2years on motorcycles.
    It should be $40ish for fluid and an hour of labor. They'll have the tools to cycle the ABS pumps. $225 is at the higher end. I just paid $175 at the BMW dealer. Unless you've had extreme use I'm not sure why you'd already flush on a 2022 if the brakes are solid.
  12. Oct 30, 2023 at 12:16 PM
    RichterScale
    Ron
    WNY
    2021 DCRB as base as it gets
    pin stripes (+5 hp)
    This.
    And if they're suggesting it on a truck that's under 2yrs old, they're either stupid or scam artists.
    Jsmittyy[OP] and Eurodriver like this.
  13. Oct 31, 2023 at 1:25 AM
    LaraMorgan
    LaraMorgan New Member
    Is it not dependent on mileage? Only on time?
  14. Oct 31, 2023 at 6:30 AM
    drewpweinerMD
    Jeremy
    2024 Limited TRD OR
    Correct. More humid regions = less time and vice versa
  15. Oct 31, 2023 at 7:09 AM
    OHwendTrd
    OHwendTrd Aging Member
    Josh
    21 SR5 3UR-FE
    ATF Cooler
    Learned so much with this video. Thanks for posting, car care nut always has solid information.
