Foam/gasket material coming from vents
Discussion in '2nd Gen Tundras (2007-2013)' started by Lineman4x4, Jul 23, 2019.
  1. Jul 23, 2019 at 12:17 PM
    Lineman4x4
    Lineman4x4 [OP] New Member
    2009 5.7 4wd
    Put A/C on high other day and every so often some pieces of foam/gasket material will come out in a perfect 1 inch in length piece. Air is ice cold, running fine, just curious where and how this is happening
  2. Jul 23, 2019 at 3:18 PM
    Murph28
    Murph28 New Member
    2010 Blue Streak Metallic Double Cab
    My 2010 is doing the same thing but the pieces are different sizes.
  3. Jul 23, 2019 at 3:21 PM
    Dang...first I've seen this reported here. Which vent? Same vent? Next time take some pics of the foam piece/s. Curious..
  4. Jul 23, 2019 at 3:22 PM
    Murph28
    Murph28 New Member
    It seems like the passenger side vents are the ones I have seen it come out of. The pieces are a gray/dingy yellow color.
    Black Wolf likes this.
  5. Jul 23, 2019 at 3:39 PM
    Definitely a mystery. Passenger side? Hmmmm....
    Let's see if anyone else has this issue.
  6. Jul 23, 2019 at 3:44 PM
    Lineman4x4
    2009 5.7 4wd
    20190723_183806.jpg Here is a picture
  7. Jul 23, 2019 at 3:52 PM
    I'm totally guessing that there's a foam seal used somewhere internally, maybe to minimize vibration or noise and as it ages, it dries out and the excess edges break off...
    Fishman57 likes this.
  8. Jul 24, 2019 at 10:03 AM
    radon222
    radon222 '21 CrewMax / '18 4Runner
    Ed
    NW Arkansas
    2021 CrewMax TRD OffRoad
    Stock for now
    Well hell! It was just the other day my wife pulled a chunk out the passenger side vent of my 2013 DC.
  9. Jul 24, 2019 at 11:03 AM
    Rubberdown
    That’s just the foam gasket in your vents to seal up against the ducts
    bvia likes this.
  10. Jul 24, 2019 at 11:39 AM
    apwisher
    apwisher New Member
    Everett, WA
    2007 CM SR5/TRD 4x4 White
    canopy, TRD Sway, audio
    you probably have varmints in the vents.
    Sas likes this.
  11. Jul 24, 2019 at 11:50 AM
    Octane957
    Octane957 New Member
    It seems like every Toyota I have ever owned has done this at some point. It's never a lot, but I think the foam the use to attach the vent ducts together just doesn't hold up well to the heat and cold over time. It's not a big issue, but still annoying.
  12. Jul 24, 2019 at 1:21 PM
    bvia
    bvia New Member
    2013 Texas Edition Tundra 2WD 4.6 DblCab
    None
    Had this happen in an S-10 and two C1500s...the 1500's included a sticky black mastic so the foam blew out of the vents and then stuck to everything, as did the mastic. What a great 2 months that was before I ripped it apart and removed all the sealing open-cell foam. The S-10 and other 1500 got cleaned out at the first evidence of foam in the vents.
    b
  13. Jul 24, 2019 at 2:32 PM
    It's normal. I had the same thing for a couple of weeks.
  14. Jul 24, 2019 at 2:56 PM
    pro2amendment
    pro2amendment Member
    Indiana
    2018 Tundra: 5.7L Flex, MGM Gray DC, Offroad pkg
    Bullet liner
    Ugh. So now our vent gaskets are seeping foam fluid? :)
