Fog lamps - why only when low-beams are on? Has anyone modded this?
Discussion in '1st Gen Tundras (2000-2006)' started by roscoe, Nov 9, 2021.
  1. Nov 9, 2021 at 1:22 PM
    roscoe
    roscoe [OP] New Member
    Hi - first post, so hey to folks all around!
    Question - why do the fog lamps only work when the headlights are on low? Out here on these 2-lane roads in the West, the foglamps seem useful for seeing things low in the road at 70 MPH, when you have the high-beams on. Has anyone jumped the low-beam relay? Is there any reason not to have foglamps when in high?
    To anticipate one question - yes, I probably will install LEDs anyway, but still . . .
    Thanks!
  2. Nov 9, 2021 at 1:30 PM
    Taco-Spike
    Two Trucks
    Darkness and shifty` like this.
  3. Nov 9, 2021 at 1:33 PM
  4. Nov 9, 2021 at 1:34 PM
    frichco228
    frichco228 Valued Member
    2016 Crewmax 4WD, TRD Offroad
    Darkness and Taco-Spike like this.
  5. Nov 9, 2021 at 1:37 PM
    roscoe
    Yes - I see the Gen 2 and 3 mods, but those use a more complex relationship between the ECU and the lamps. I think the Gen 1 is simpler - perhaps you just run a circuit from the fuse block to the relay, bypassing the low-beam circuit?
    It never really made sense that they are disconnected for high-beam use. You use high-beams when there are no other cars on the road anyway, so there is no one to blind!
    lamboboy732 and 831Tun like this.
  6. Nov 9, 2021 at 1:40 PM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    Agreed, makes no sense. Probably one of the first mods I did to this truck.
  7. Nov 9, 2021 at 1:44 PM
    omgboost
    omgboost The Accountant
    East Coast
    2012 Sequoia Platinum
    Why? Because of varying state laws. Some states say only a maximum of 4 front facing bulbs may be illuminated when driving. So low beams + fog lights = 4. You turn on high beams and the others stay on, that's 6. You run into issues. Will cops bother you? Probably not but car companies will get bad press for selling a car that does not comply with a certain states law.
    lamboboy732 and Taco-Spike like this.
  8. Nov 9, 2021 at 1:46 PM
    roscoe
    Hmm. I actually would like it if the low-beams stayed on when the hi-beams came on. But they turn off in my 2001.
    That would be another great mod!
    omgboost[QUOTED] likes this.
  9. Nov 9, 2021 at 2:02 PM
    Dsptundra
    Austin TX Area
    2021 Silver Limited CM
    The main reason fog lights do not work with high beams is that high beams on in fog reduce visibility. The higher intensity reflects off the fog (or snow) and actually reduces visibility due to glare. Fog lights are meant to shine low, under the fog, and to illuminate the road markings so in reduced visibility you can still stay on the road. Amber fog lights are said to perform better from a glare perspective but some people disagree.
    SharkDog, Dr Doobie and shifty` like this.
  10. Nov 9, 2021 at 2:05 PM
    Illegal af, 10 headlights. Does it roll? Does it float? Does it hover? WHO KNOWS?!? :annoyed::rofl:
  11. Nov 9, 2021 at 2:12 PM
    Rodtheviking
    Rodtheviking New Member
    Vancouver, WA
    Sequoia
  12. Nov 9, 2021 at 2:14 PM
    Dr Doobie
    Dr Doobie Growing member
    Talkeetna,Alaska
    '07 RCSB 5.7 SC'd 4x4 SSM
    ^^^ this is the reason why fogs on low beam only
    jnqpublic and Dsptundra[QUOTED] like this.
  13. Nov 9, 2021 at 2:28 PM
    Baller
    Baller New Member
    '05 Tundra SR5 DC
    This is 99% correct. The only correction I would make, and maybe I'm just nit picking here, is that high beams don't have a greater intensity, they have a greater, more upward, pattern. He nailed it why you shouldn't run your fogs with high beams, though. Anyone that has a problem with fogs not operating with the high beams needs to quite thinking their fogs are light pods. Fogs are fogs, not off road lights. If you want more light, get a light bar or some other off road lights.
  14. Nov 9, 2021 at 2:39 PM
    roscoe
    Well, they are just lights, set lower. If it is foggy, you might want only them on (without even low beams). But if you want them for general illumination, there they are! I live in a place literally without fog, so it is a little silly to constrain their use simply because of a hypothetical situation.
  15. Nov 9, 2021 at 5:23 PM
    JAXABOI
    JAXABOI New Member
    2005 Sr5 Tundra
    My truck is full of lights... i mean full. Cubes out the ass leds all around. First thing I did when I installed an aftermarket switch box was hook the fogs up to their own switch. They no longer shut off with highbeams. Bright me on the road... youll see heaven for a brief moment. Lol best thing I ever did ngl ditch lights and 4 other cubes plus all leds nakes the sky blue at night
  16. Nov 9, 2021 at 5:33 PM
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    So many.......must resist......
    Hi06silver likes this.
  17. Nov 9, 2021 at 5:41 PM
    SouthPaw
    SouthPaw The headlight guy
    2000 Limited 4x4 AC
    ATTACK!!!!
    jk - we have to play nice ‘round these parts.
    bmf4069[QUOTED] likes this.
