Fog Light Bulb Suggestions?
Discussion in 'General Tundra Discussion' started by Aggie2002, Sep 11, 2021.
  1. Sep 11, 2021 at 8:57 PM
    Aggie2002
    Aggie2002 [OP] New Member
    Arlington, VA
    2017 Tundra Limited TRD Offroad
    Fellow Tundra Owners:
    Recently my left fog light went out. I was wondering what y'all would recommend as a replacement light bulb for a 2017 Tundra fog light. Are there better bulb upgrades than the stock bulbs? Any suggestions on upgrading the headlight bulbs?
    Thanks,
  2. Sep 11, 2021 at 9:01 PM
    Ders
    Ders Washington
    Washington
    2014 Tundra
    MKW Chrome Off-Road Wheels 275/65R20 Tires Bilstein 5100 Middle Setting In the Front, 1/2 Block in the Rear Highway Products Gull Wing with Roof Rack Tracks Protech lumber rack LED headlight and foglight bulbs 30% Front window tints Boost Auto Tow Mirrors
    I have JDM Astars from Amazon. They aren’t the brightest but much better than halogens and they’ve lasted me 2years and counting.
    In fact all of my bulbs are JDM ASTARS except for the sun visor bulbs67190947-7B35-4434-91EE-2516A2B72A65.jpg
  3. Sep 11, 2021 at 9:11 PM
    TRDFerguson
    Jake
    Southeast Greater Basin, AZ
    2018 MGM CrüeMax
    Diode Dynamics SS3 are an awesome replacement assembly if you’re looking for better performance than stock, but we don’t know your budget.
    OEM LED headlights from 2018+ Tundras are the recommendation if you’re looking to go LED there as well. I can’t help you with a halogen build replacement though.
    We all try to do our best to help each other spend money here :spending:
    QuikreteTundra likes this.
  4. Sep 12, 2021 at 7:34 AM
    Aggie2002
    Arlington, VA
    Thanks for the replies. As for the budget I’m willing to spend a decent amount on bulbs if:
    (1) the preformance is a lot better than OEM stock; (2) great longevity.
    That being said, I plan to go with LED bulbs. Can my truck light systems go from a halogen bulb to a LED bulb. I plan to change the bulbs, not replace the light systems
  5. Sep 12, 2021 at 9:41 AM
    Ders
    Ders Washington
    Washington
    2014 Tundra
    I’ve heard good things about headlightrevolution.com for bulbs
    i chose the JDM Astars because they were much cheaper than headlight revolution. And i’ve been happy with the performance and life of the bulbs thus far
  6. Sep 12, 2021 at 9:44 AM
    Stumpjumper
    Stumpjumper Not a new member
    Fate, Tx
    2017 Tundra TSS 4x4
    Yes, I have Lasfits in mine. Much better then the stock halogens. I could not even tell the halogens were on. The Lasfits do a great job of lighting up the sides of the road.
  7. Sep 12, 2021 at 9:51 AM
    WILLINH
    WILLINH New Member
    BILL
    NEW HAMPTON, NH
    2019 TUNDRA
    62131BA5-BAD3-47C0-945E-2D03C7CF34E6.jpg 4A89B27C-7417-4DB9-9F21-A2F7792CE7BC.jpg Bought these from Toyota, they are led and match my pro headlights. They are pretty bright. Not too expensive. Sparks carries them.
  8. Sep 12, 2021 at 1:12 PM
    Aggie2002
    Arlington, VA
    Well the pro light system might be an option. I need to see if they will fit in a 2017 tundra.
  9. Sep 12, 2021 at 1:23 PM
    WILLINH
    WILLINH New Member
    BILL
    NEW HAMPTON, NH
    2019 TUNDRA
    The led fog lights certainly will. I just put the pro headlights in 3 weeks ago. They have them in chrome led also.
  10. Sep 12, 2021 at 1:24 PM
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    Yep, they fit. You’ll just need iHacker’s harness for the wiring and they’re plug and play.
  11. Sep 12, 2021 at 6:41 PM
    Aggie2002
    Arlington, VA
    Thanks. So if I go with the current TRD pro fog light set all I need additionally is the iHacker’s harness? Or will I need to get a new housing to insert the fog light into? Do the TRD fog lights come with LED bulbs or will I need to purchase these myself. Thanks again for all the help!!
  12. Sep 12, 2021 at 7:06 PM
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    Oh, if you’re just talking about the TRD Pro fogs, those are plug and play, no harness needed. The iHacker harness is just for the headlights, if you want to put OEM LED on trucks that came with halogens.
  13. Sep 12, 2021 at 7:16 PM
    Aggie2002
    Arlington, VA
    Sweet. I might as well goes with those. I assume I can use the same plastic/ rubber housing, correct? Is there are part number available?
    I feel so motivated that I might just buy the TRD pro headlights but for the 2017 tundra- I like the yellow daytime running lights. Where would I find the iHarness? Thanks again. I owe you a beer!
  14. Sep 12, 2021 at 7:58 PM
    WILLINH
    WILLINH New Member
    BILL
    NEW HAMPTON, NH
    2019 TUNDRA
    Trd pro fog lights are Rigid and square the fog lights I put in are just toyota led fog lights simple plug and play. 3625AFBF-3249-43FD-9EA8-81D86F14DBE7.jpg
  15. Sep 12, 2021 at 9:06 PM
    Rodtheviking
    Rodtheviking New Member
    Vancouver, WA
    Sequoia
    They do, I put them in mine.
  16. Sep 13, 2021 at 9:09 PM
    Aggie2002
    Arlington, VA
    Sorry about all the iHacker’s harness questions. Just trying to learn. Is this harness for connecting a LED light bulb when using your existing headlight assembly, or is the harness for connecting the a entire new headlight assembly to a older model Tundra?
    After some thinking I might want put the current TRD Pro headlight assembly on my 2017 truck. In this case would I need a iHackers harness?
  17. Sep 13, 2021 at 9:29 PM
    Mater
    Mater New Member
    Nick
    SD
    2016 MGM Platinum
    The iHacker harness is related to headlights. He does sell adapters for fog lights too, but you can also get them on Amazon. You would need an adapter if you decide to go diode dynamics or rigid. Here is the set I went with.
    Starkey Products Fog Light Wiring Adapters H11 to Deutsch Set https://www.amazon.com/dp/B01EXWDNTK?_encoding=UTF8
    Here is the link to diode dynamics products. These will use the existing round housing you currently have and should be a very quick and easy install. Plus they have good light output.
    https://www.diodedynamics.com/ss3-led-fog-light-kit-for-2014-2021-toyota-tundra.html
    and here is the link to the headlight thread if you’re interested in upgrading your headlights.
    https://www.tundras.com/threads/201...-2020-models-v-2-0.24416/page-35#post-2064413
  18. Sep 15, 2021 at 10:01 AM
    Aggie2002
    Arlington, VA
    Thanks!! SS3 fog lights are nice! If I get them, I will also get the Starkey wiring adapters as you mentioned above.
