Fog lights didn't work
Discussion in 'Lighting' started by NewTundra, Jun 24, 2018.
  1. Jun 24, 2018 at 6:55 AM
    NewTundra
    NewTundra [OP] New Member
    Junior
    2015 SR
    None
    Have a 2015 Tundra SR that didn't come with fog lights. I got some used ones, plugged them in and nothing happened.
    What should i try?
  2. Jun 24, 2018 at 6:59 AM
    ardnutoz
    ardnutoz
    OZ
    SE-PA
    2018 Black TRD OR CM Limited
    Double check your switches... make sure highbeams werent on by mistake
  3. Jun 24, 2018 at 7:03 AM
    MGM2018OR
    MGM2018OR New Member
    Craig
    2018 MGM OR dbl cab ( gone but not forgotten )
    Check to see if there is a fuse for fog lights
    You added the new light switch with the fog light switch right?
    NewImprovedRon and NewTundra[OP] like this.
  4. Jun 24, 2018 at 7:04 AM
    NewTundra
    Junior
    2015 SR
    None
    It's like this one. For high beam i push or pull. For the fog I'm supposed to turn it.
  5. Jun 24, 2018 at 7:05 AM
    NewTundra
    Junior
    2015 SR
    None
    Not really all that car smart. Where in the fuse box will it be? Does it have a specific number?
  6. Jun 24, 2018 at 7:08 AM
    ardnutoz
    ardnutoz
    OZ
    SE-PA
    You may not have one in there jf it wasnt equipped. Look at the cover for location. Go to carparts store and buy the matching amp rating
  7. Jun 24, 2018 at 7:14 AM
    NewTundra
    Junior
    2015 SR
    None
    A what? Fuse?
  8. Jun 24, 2018 at 8:52 AM
    aRabidLunatic
    aRabidLunatic Professional Hobo
    Central Texas
    2015 Tundra SR5 Black
    You said the fog lights are used? Sure they're good?
  9. Jun 24, 2018 at 10:37 AM
    ardnutoz
    ardnutoz
    OZ
    SE-PA
    yes a fuse.. look at the attachment in #8 you should have a fuse and a relay somewhere.
    15whtrd likes this.
  10. Jun 24, 2018 at 11:06 AM
    15whtrd
    15whtrd Mr. Blonde
    Also the headlights need to be on for the fog lights to come on as well.
    NewImprovedRon likes this.
  11. Jun 24, 2018 at 6:34 PM
    xj2202009
    xj2202009 New Member
    x
    Lutz, Fl
    2017 tundra sr double cab v8 5.7L black 4x2
    looking to replace factory Radio with a pioneer avix588bhs
    you need the relay..@Roman could hook you up. for my 2017 sr I just had to get the relay, ground a wire to the frame. They come on and off with the headlights..
    Pudge likes this.
