FRAM oil filter is larger?
Discussion in '2.5 Gen Tundras (2014-2021)' started by WXman, Apr 6, 2022.
  1. Apr 6, 2022 at 7:17 AM
    WXman
    WXman [OP] New Member
    Kentucky
    2016 Tundra SR5 Crew Max 4x4 5.7L
    So today I did the first oil change myself on the new to me Tundra. It's got 93,500 miles on it, but I just bought it at 88,300 so this is my first time servicing this truck. Maintenance light was on also.
    Anyhow, the oil filter I picked up at Walmart is the FRAM "Xtra Guard" 10295. Full synthetic media, supposed to be their top of the line filter. I checked and double checked that this part number is spec'd for the Toyota/Lexus 5.7L V8.
    When I took out the existing oil filter (brand unknown) I noticed that it is a couple of millimeters shorter in height than the FRAM filter. Whereas the existing filter fit snuggly around the metal tube in the filter cap, the FRAM filter is ever so slightly loose. What's up with that?
    I installed the FRAM filter anyhow since the truck couldn't be driven until I did. After finishing the job I verified no leaks and good oil pressure.
    I won't buy a FRAM filter again I guess, but has anybody here noticed the same about FRAM oil filters on these engines?
  2. Apr 6, 2022 at 7:25 AM
    HD59019
    HD59019 New Member
    Robert
    2017 Tundra SR5
    I cannot confirm for the Tundra, plan to do my first as well next week, but with my FJ Cruiser the Wix & Fram filters were larger than the Toyota one. Never had any problems. Larger filter seems better in theory to me as long as it fits properly.
  3. Apr 6, 2022 at 7:37 AM
    Big_Ed
    Big_Ed New Member
    Spring, Tx
    2016 Tundra
    I always use the Toyota filter. They sell them at my Walmart.
  4. Apr 6, 2022 at 8:16 AM
    Bakershack
    Kelly
    Spanish Fort, AL
    2020 SSM 1794 4x4
    I would be concerned about the loose fit of the center tube within the filter holes. Oil should not be able to pass through there, bypassing the filter material.
  5. Apr 6, 2022 at 8:32 AM
    Rodtheviking
    Rodtheviking New Member
    Vancouver, WA
    Sequoia
    Just say no to Fram.
    Toyota or Bosch/Wix, Mobil 1 in a pinch.
    Rocko9999, 14burrito and Bakershack like this.
  6. Apr 6, 2022 at 11:01 AM
    WXman
    Kentucky
    That's what concerns me. It doesn't fit the same. It's probably 2 or 3 mm taller, so I assume it presses on the metal clip/bypass valve in the cap differently.
  7. Apr 6, 2022 at 4:43 PM
    Rocko9999
    Rocko9999 New Member
    Friends don't let friends use Fram. Go OEM.
  8. Apr 6, 2022 at 5:25 PM
    TundraMcGov.
    Jofus
    Burpinham, Babalama
    2015 MGM Limited 2x4 Sequoia
    If you buy Mama Toyota filters in the 5 pack or better yet the case of 10 the price per each is less than Fram. I think my last case purchase of Toyota filters a year ago was something like $4.90 each.
    WILLINH, WXman[OP] and Rocko9999 like this.
  9. Apr 6, 2022 at 5:34 PM
    IowaGuy
    IowaGuy New Member
    Arizona by way of Iowa
    2019 SR5 upgrade MGM
    In Process
    I wouldn't use a FRAM filter if they were free. You would be better off cutting a roll of paper towels to length and using that.
    WILLINH and Rodtheviking like this.
  10. Apr 6, 2022 at 6:50 PM
    Johnsonman
    Johnsonman New Member
    Austin
    Sequoia
    It sucks thru the middle so any looseness just gets sucked tight against the tube, bfd....
  11. Apr 6, 2022 at 7:01 PM
    GJD
    GJD New Member
    Truck
    DO NOT use Fram
    WILLINH likes this.
  12. Apr 6, 2022 at 7:12 PM
    landphil
    Phil
    BC, Canada
    ‘08 TRD doublecab
    There is no sucking involved with the filter.
    Well, there isn’t normally, anyway. What you do with yours isn’t my business, and I won’t judge.
    panicman likes this.
  13. Apr 6, 2022 at 8:04 PM
    parkerbows
    parkerbows New Member
    Jack
    2017 crew max sr5 trd off road
    Firestone air ride air bags
    I use the amsoil filter
  14. Apr 8, 2022 at 12:08 PM
    WXman
    Kentucky
    So between having the slowest drain flow I've ever seen, the ridiculous oil filter housing design, the filter I bought not fitting, and then the dipstick showing over filled even though I refilled by the book, I have to say that this oil change was the most hilarious one I've ever done on any gas or diesel truck I've ever had in the garage. Just pure ridiculousness.
    As a side note I learned you have to wait for hours before checking the oil because it takes forever to get the oil to drain down to the pan on these engines for some unknown reason.
  15. Apr 8, 2022 at 2:06 PM
    Rodtheviking
    Vancouver, WA
    Sequoia
    I did mine for the first time last week and I broke the freaking oil filter wrench I bought trying to get the stupid plastic filter housing off. Thank goodness I had an alloy one ready to go as I broke the plastic too.
    Silly design.
    Toyotoholic likes this.
  16. Apr 8, 2022 at 2:16 PM
    TundraMcGov.
    Jofus
    Burpinham, Babalama
    CAFE. It shows up in the weirdest of places.
  17. Apr 8, 2022 at 2:21 PM
    Toyotoholic
    Toyotoholic -4Life-
    Jmz
    17' MGM
    Pro suspension, sways
    The first time I did mine, it was so friggin tight and I couldn't get the plug out either. I thought the plastic cap was going to shatter if I continued. I decided to wait until I bought the metal housing and had the insurance to proceed. Sure enough, the cap was so tight I destroyed it to get it off... RIDICULOUS design. But that's what the forum is for! Got all the info, bought the right stuff, and now changing the oil is a simple job. 30minutes tops, most of which is just the drain time. I dab the housing threads and plug threads with neversiez and it's so painless to do. To the point where I actually enjoy changing the oil. Go figure.
    But I only ever use OEM TRD filters for the truck. No F'n way would I use Fram!
    WILLINH likes this.
  18. Apr 8, 2022 at 4:40 PM
    parkerbows
    Jack
    I put a door on my skid plate and have a fumoto valve. and metal filter cap. so easy now
    WILLINH likes this.
  19. Apr 8, 2022 at 4:40 PM
    parkerbows
    Jack
    mine was so tight the first time
  20. Apr 8, 2022 at 5:07 PM
    Rocko9999
    Weren't they all..
  21. Apr 8, 2022 at 5:07 PM
    parkerbows
    Jack
    sounds like it
    Rocko9999[QUOTED] likes this.
