Frame rust
Discussion in '2.5 Gen Tundras (2014-2021)' started by rds95991, May 22, 2018.
  1. May 22, 2018 at 9:27 AM
    rds95991
    rds95991 [OP] New Member
    2018 Super White Tundra CrewMax SR5 TRD
    I have to ask. I've been reading lots of complaints from people who own Gen 3 Tundras who are complaining about frame rust damage. Most of these seems to be a couple of years old. Is that a concern? Has this been addressed in current Tundras?
    Thank you.
  2. May 22, 2018 at 9:36 AM
    040Tundra
    040Tundra Teddy 2013-2019
    Aaron
    Las Vegas, NV
    040 '16 CM LTD 4x4
    I have a16 and don't have one lick of rust
    15whtrd likes this.
  3. May 22, 2018 at 9:40 AM
    chphilo
    chphilo Tundra addict
    Western PA
    1st gen Tundras? Yes.
    3rd gen Tundras? No.
  4. May 22, 2018 at 9:40 AM
    15whtrd
    15whtrd Mr. Blonde
    I think it all depends on what state you live in. If they salt the roads or you live near the beach you should be protecting the underside of your truck anyways. Fluid film is a good option. I live in California but I’m far away from the beach to not have to worry about rust. When I first bought it, I did hit the underside with fluid film. I don’t notice any rust yet!
    MotoTundra likes this.
  5. May 22, 2018 at 4:06 PM
    rds95991
    Thanks. I spend a lot of time in the Tahoe area in the winter and run my vehicles through a wash with under carriage sprays when I come back down. Never had a problem with my other vehicles but some of these stories seem extreme.
    15whtrd likes this.
  6. May 22, 2018 at 8:13 PM
    DecalsByDesign
    DecalsByDesign Vinyl Connoisseur
    Eagle, CO
    2019 Quicksand Limited Double Cab
    Toytec Performance Aluma 2.5 Kit Nitto G2 295/70-18 Method MR306 18x9 +18 Kenwood DDX6906s Carven TR Muffler w/ Y-Pipe
    My 16 is starting to show small areas of rust. And I’m in CO :(. I did drive it to Iowa for 3 days over the winter and it just so happened to be a slushy icy mess. That could be the culprit.
  7. May 22, 2018 at 9:10 PM
    No rust what so ever and I'm on Texas coast do lots of beach drives, but I have signs of rust on rear seat braces that are bolted to floor board
    15whtrd likes this.
  8. May 23, 2018 at 5:03 AM
    MotoTundra
    MotoTundra The Ocho
    Don
    I bought my 2014 in November of 2013 so it has been through 5 rough Pennsylvania winters. I sprayed the undercarriage with Fluid Film prior to each winter. I don't have any notable frame rust, just a few tiny areas of surface rust where the lift arms at the dealer touched the bottom of the frame and a few nooks and crannies here and there that I may have missed with the fluid film.
  9. May 23, 2018 at 7:03 AM
    scruffy
    scruffy New Member
    Dmitriy
    2014 Toyota Tundra Double Cab Limited TRD 5.7 4X4
    MotoTundra and Watt maker like this.
  10. Jun 13, 2022 at 1:07 PM
    New_DoorDing
    New_DoorDing New Member
    2016 TRD Pro DoubleCab
    Unfortunately the undercarriage of my 16 TRD Pro also has what I would consider a lot of rust. 90% of it is along the weld lines of the black frame bars. I also noticed it on the two tow points on the front. I lived in Boston for 5 years where I specifically went to a car wash that did not use recycled water for the undercarriage wash. Knowing how much salt is dumped on the roads i would not miss a week without washing my truck and the undercarriage.
    So because I dont trust anyone else to do this correctly, I bought the drill wire brush attachment pack, the Rustoleum Rust Reformer, and high heat paint. All flat black of course. Throw on some safety glasses, a face mask, and clothes you dont care about. You’ll be filthy, but just follow the instructions on the can, grind away the chipping paint and most of the rust, pass a soapy wet cloth, let dry, spray rust reformer, allow 24 hours to dry, then finish off with the high heat spray paint to further protect that rust reformer layer. This is your undercarriage so all kinds of road debris hit down there. Protect the rust reformer layer. Remember, no one will do this job better than you will. This takes patience.
    Also, if you prefer, POR-15 will be the better option as it doesnt require a protective paint layer. Also performs the best out of all rust reformers on the market. Watch youtube reviews on it. Only Con i can see is its a gray color (not flat black like your frame). After watching this youtube review of all the stuff on the market, i went with the Rustoleum as it was what i could get the fastest and less work to apply.
    https://youtu.be/Ag46YUovPUc
    panicman likes this.
  11. Jun 14, 2022 at 4:59 AM
    Buckaroo
    Buckaroo New Member
    Central Ohio
    2017 Tundra 5.7L 4WD DC TRD
    2020 GD 2670MK Travel Trailer
    Living in Ohio and having had a 3rd gen T4R frame crumble, I coat my 2.5 gen Tundra and 4th gen T4R with Woolwax every couple of years.
    rebmo and Malinois38 like this.
  12. Jun 15, 2022 at 8:03 PM
    BulldogDan
    BulldogDan New Member
    Cement…Tundra #9
    Same here. Ohio road salt eats truck frames. WoolWax is a great product. It’s on the T4R I sold to my son and I recently bought a 2018 Tundra that came from Arizona and the frame looks spotless. WoolWax will be going it on this fall.
