Frame rusting mediation
Discussion in '1st Gen Tundras (2000-2006)' started by DWKTUNDRA, Jan 9, 2023.
  1. Jan 9, 2023 at 4:32 PM
    DWKTUNDRA
    DWKTUNDRA [OP] New Member
    Dave
    2004 Tundra 2wd SR5 4 dr
    I missed the factory recall for 2004 Tundra Frame so i been patching spots (rear spring etc) to keep going. Its not unsafe.I want to treat the frame to slow the progression and curious what you folks have done. I know, google it, but I like to read what end users of products have to say about using metal treatment products. BTW, 2004 Tundra SR5 3.4l @ 266,000 loves me! My first post.
    w666 likes this.
  2. Jan 9, 2023 at 4:39 PM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    Can you post pictures so we can a better feel for what you're dealing with? I use Fluid Film amd PB Surface Shield to protect my frame but you may need something extra.
  3. Jan 9, 2023 at 4:53 PM
    Jack McCarthy
    Bill
    North of Boston
    02 Tundra AC SR5 V8 4x4
    Some of my work for the pic links that still work…
    Moar POR-15
  4. Jan 9, 2023 at 5:18 PM
  5. Jan 10, 2023 at 3:33 AM
    tvpierce
    tvpierce Formerly New Member
    Maine
    Hey Jack. Looks like you did the POR-15 back in 2012, yes? How did it hold up?
    Reason I ask is that I did mine about 4 years ago, and follow up each year with spray-on oil based treatment. To be perfectly honest, I'm really disappointed with the results -- in hindsight, I wish I hadn't done the POR-15. I should have just stuck with the annual coating. Now I have areas where the POR-15 is coming loose allowing rust to creap in. I'm able to control it with my annual (or sometimes twice annual if I get around to it) treatments. But in my experience, POR-15 was a lot of work for not much short term gain, and in the long term I actually think it did more harm than good.
  6. Jan 10, 2023 at 3:56 AM
    BlueCrushSC16
    BlueCrushSC16 New Member
    Charleston, SC
  7. Jan 10, 2023 at 4:28 AM
  8. Jan 10, 2023 at 5:30 AM
    N84434
    N84434 In the Frozen Tundra
    Milwaukee WI.
    2001 Limited TRD
    After rebuilding my frame 3 years ago, I painted it with Chassis Saver and have done an annual cleaning and then spraying with Fluid Film Rust Inhibitor. It's worked so far...
    Some info on it in my rebuild thread.
    Welcome aboard!
    Kwe1982 and txagg like this.
  9. Jan 10, 2023 at 7:08 AM
    Jack McCarthy
    Bill
    North of Boston
    It's held up really well but now really needs a touch up as it's flaked off in certain areas that have been either hit by rocks or exposed to sunlight (i.e. back of differential at either dawn or dusk).
    My approach was to use a die grinder and 2-3" wire wheel to remove all loose rust, then treat with the solvent spray to remove grease residue then the metal etch solution they have and finally apply two coats of POR-15 in the semi-gloss black color. That shininess went away after it dried completely and now looks very much like the original frame itself.
    It was a huge PIA to apply and I literally had to toss my clothes afterward and wear a hair cap to prevent the stuff from getting on my skin or hair working under the vehicle. It was worth it for all the years I didn't have to do more than a simple power wash to take off the excess salt.
    N84434 and shifty` like this.
  10. Jan 10, 2023 at 7:51 AM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    Agreed. I only put it on a tiny section where the frame brace is and it took a long time. I think it would be so much better with the bed off.
    N84434 and Jack McCarthy[QUOTED] like this.
  11. Jan 10, 2023 at 8:47 AM
    N84434
    Milwaukee WI.
    2001 Limited TRD
    It's almost imperative to remove the bed. Much easier to clean everything and access the bottom of the bed easily.
  12. Jan 11, 2023 at 11:16 AM
    speedtre
    speedtre New Member
    Inland Northwest
  13. Jan 11, 2023 at 11:20 AM
    Jack McCarthy
    Bill
    North of Boston
  14. Jan 11, 2023 at 11:25 AM
    speedtre
    speedtre New Member
    Inland Northwest
  15. Jan 11, 2023 at 11:30 AM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    Completely different product. It doesn't look anything like Blaster once sprayed. I've got a few cans of this I've been using in addition to Fluid Film.
  16. Jan 11, 2023 at 12:13 PM
    Blaster uses pretty much the same can styling for PB, Silicone, and Surface Shield products (at least)
  17. Jan 11, 2023 at 12:29 PM
    tvpierce
    Maine
    Yeah, it's essentially PB Blaster's version of Fluid Film & Wool Wax. I have a few cans of it. I haven't compared it side by side with FF or WW, but others who have say it performs favorably.
  18. Jan 11, 2023 at 12:30 PM
    I'd love to see Project Farm re-make their test with the top 4 treatments from the 1st video above, and compare it to the Blaster stuff...
    tvpierce likes this.
  19. Jan 11, 2023 at 2:10 PM
    TundraTed
    TundraTed New Member
    2020 SR5 TRD Sport Crewmax 4x4
    In order: Orvis dog cover for rear bench seat, OE gun safe, Husky liners front/rear, Tyger tonneau tri fold, Rough Country seat covers
    I only started using Fluid Film and PB Blaster last year. I can’t comment on longer term results yet, but PB blaster was easier to apply and the solution seems to be a bit more substantial. I could see the PB much better than FF during the application. Perhaps a better cap on FF would have helped, not sure.
  20. Jan 11, 2023 at 2:58 PM
    Hi06silver
    Hi06silver Fat. Thumbs.
    Ryan
    2006 DC 4x4 Waltrip
    5 inch TC Lift. Icon 2.5 Ext. travel coilovers- Icon Resi- shocks w/Firestrone air-ride 285/75/17 Toyo OC Ext. FN Overlander wheels Retrofit Projectors Kenwood H/U Natika Back-up camera
    Not sure if they've changed the thingy on the top of the blaster or not. Btw that dude works for PB Blaster now. Not that that sways his tests, he made a video on that whole deal...I hope it works better with the stupid trigger add-on I have 1 of the 2 pack left. First was a total disaster with fluid film.
    speedtre likes this.
