FRAP outer tie rod with lift kit
Discussion in 'Suspension' started by Creese4u, Nov 27, 2021.
  1. Nov 27, 2021 at 7:50 AM
    Creese4u
    Creese4u [OP] New Member
    Coop
    14Platinum
    TRD CAI, 6” up.
    Hello, Fairly new to threading or whatever you call this. I don't live online like some others on here.
    I purchased a 6" lifted 2014 Tundra Plat 4x4 in 2018. Well, the outer tie rods are worn.
    These are not a standard tie rods for a tundra, apparently. I do NOT know what type of lift it is. I do NOT have a part number on the tie rod that needs replacing. The only thing on the tie rod is stamped "FRAP". I can tell the spindle is an upgraded, heavy duty spindle but that is about all I know.
    Is there any info out there that has a few various lift kit types, as in rough country, fabtech, etc, that might use FRAP tie rods? The ones on the truck are about 2" shorter than a standard tundra. Also, they feed in from the top. They also are straight, as opposed to the tundra curved peyronie's style tie rod.
    If not tie rod specific info, is there anyone who may know WHO may have info on various mods.
    This is my wife's truck and I would rather not have her driving my Duramax any longer than I have to.
    All in all, ANY info on these tie rods or lift kits is much appreciated. Thanks.
    Coop in TX
  2. Nov 27, 2021 at 7:58 AM
    Dsptundra
    Austin TX Area
    2021 Silver Limited CM
    Do you have any pictures? Might help with identification.
  3. Nov 27, 2021 at 8:36 AM
    Creese4u
    Coop
    14Platinum
    TRD CAI, 6” up.
    Took a minute but I think I finally got it to upload.
  4. Jan 17, 2023 at 6:09 PM
    NBJEEP
    NBJEEP New Member
    Did you ever find the solution for this? I am experiencing the same issue.
  5. Apr 17, 2023 at 1:31 PM
    ardarsh
    ardarsh New Member
    Ardarsh
    Tundra crew max 2012
    8 inch lift
    Hi,
    I have the same setup and tie rod issue, did anyone get the correct part number for the outta tie rod, where did you find from, any leads would be appreciated.
    Thanks
  6. Dec 6, 2024 at 12:40 PM
    Jasonchard
    Jasonchard New Member
    2018 Tundra SR5
    Level kit rims Tires
    Hellooo? What did you figure out?
